Traction Battery Questiion
Discussion in 'Gen 2 Prius Main Forum' started by nwpa, Jan 21, 2007.
  1. Tideland Prius
    16,554
    <div class='quotetop'>QUOTE(Frank Hudon @ Jan 28 2007, 11:21 PM) [snapback]382196[/snapback]</div>
    hmm, I'm assuming it points down? Cause I jet water behind the mudguard to get rid of the sand and crud from our roads. I usually leave it there for 10-20 seconds until the water becomes clear.
  2. Frank Hudon
    Frank Hudon Senior Member
    4,147
    <div class='quotetop'>QUOTE(Tideland Prius @ Jan 30 2007, 06:12 PM) [snapback]383096[/snapback]</div>
    I think your safe doing that I mean you could conceivably drive thru puddles that deep. Next time you have a piece of cardboard lay down and have a look up under there and you'll see it.
  3. Tideland Prius
    16,554
