What system parameters would be interesting to observe while driving?
Discussion in 'Gen 5 Prius Main Forum' started by VelvetFoot, Dec 20, 2025.
  1. VelvetFoot
    VelvetFoot Active Member
    1,135
    448
    New York State
    2026 Prius
    I currently have engine rpm, oil temp, coolant temp, traction battery soc %, and aux battery Voltage displayed on the infotainment screen.
    There are more possibilities, relating to inverter temp, coolant pump rpm, etc, but what parameters would be desirable/useful?
  2. Paul Gregory
    Paul Gregory Senior Member
    2,217
    586
    Alberta
    2024 Prius Prime
    XSE
    Carscanner Dash.jpg I'm using
    Car Scanner ELM OBD2 which lets me build a digital dash from hundreds of possible sensors.
    #2 Paul Gregory, Dec 20, 2025
  3. PriusCamper
    PriusCamper Senior Member
    12,987
    5,282
    Pacific Northwest, USA
    Amps going into and out of the pack and voltage difference between blocks in the pack. The higher the amps, the greater the voltage difference. And Dr. Prius app provides this data and more all on the same screen.
  4. ChapmanF
    18,458
    Using an app you selected?
    I wonder what its value labeled "oil temp" really is.
  5. PriusCamper
    12,987
    5,282
    zero value
  6. VelvetFoot
    1,135
    448
    New York State
    2026 Prius
    Why wouldn’t there be an oil temp sensor?
  7. VelvetFoot
    1,135
    448
    New York State
    2026 Prius
    This has value when you’re rolling down the road?
  8. ChapmanF
    18,458
    There never has been one in the engine, at least through Prius gen 3. Whether one could have been added for gen 4 or 5, I don't directly know. The wiring diagram would answer that question.
    There have been apps reporting an "oil temp", I think even for generations we know have no engine oil temp sensor, so that invites a question what is really being shown there.
    It could be a transmission oil temperature (gen 3 has such a sensor). It could be some other PID that somehow got the wrong name in the app. Or it could even be reading some bytes out of an ECU response that don't represent a known PID at all.
    I feel like I recently saw a thread with a photo of a display showing "engine coolant temp" and "engine oil temp" and the numbers were substantially different, which seemed like another reason to wonder.
  9. PriusCamper
    12,987
    5,282
    As your battery pack gets older after a decade or more its essential information.
  10. Danno5060
    Danno5060 Active Member
    393
    201
    Wyoming
    If you're driving in the mountains, maybe engine coolant temperature.
  11. rjparker
    10,412
    6,521
    Both engine coolant temperatures with user settable audible alarms. An indication before its too late with an audible so you don't have to watch it.
    VelvetFoot likes this.
  12. VelvetFoot
    1,135
    448
    New York State
    2026 Prius
    Both: Is that engine and inverter?
  13. VelvetFoot
    1,135
    448
    New York State
    2026 Prius
    sensor-oil-pressure-temperature-8944806010
  14. VelvetFoot
    1,135
    448
    New York State
    2026 Prius
    Looking through some screen shots I made:
    How about catalyst temp?
    Hybrid system voltage and/or current?
    HV battery power?
    SOC% max and/or min?
    Vehicle acceleration? (For me, VelvetFoot, that's a joke :) )
    12 V battery temperature?
    12 V battery current?
    Inverter temp?
    Max Inverter temp (did not see a min)?
    Electric water pump target and actual rpm (does one pump handle engine and inverter cooling loops?)
    ECU internal temp?
    Fuel rail pressure target and actual?
    Battery temperatures (I saw 6)?
    Battery heater temperature (?not sure if that was real or not)
    I couldn't see Tire Pressure/Temp readings on Car Scanner.
  15. ChapmanF
    18,458
  16. KH111
    KH111 Member
    79
    Travelers Rest, SC
    2024 Prius Prime
    XSE
    How do you get engine parameters to display on the screen, and which screen are we talking about?
    KH
  17. VelvetFoot
    1,135
    448
    New York State
    2026 Prius
    Car Scanner and OBD Fusion can display on the middle screen via CarPlay or Android auto.
  18. VelvetFoot
    1,135
    448
    New York State
    2026 Prius
    In other news, I think I’m going the idiot light approach. If something is wrong, the car will tell me.
    PrimeDan likes this.
