No fuel after head gasket replacement
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Jenkem_Enjoyer, Dec 12, 2025.
  1. Jenkem_Enjoyer
    Jenkem_Enjoyer New Member
    spokane wa
    As the title says, I just replaced the head gasket in my 2014 Prius V, with apx 275k. I've done several had gasket replacements, although this is my first on a prius. Everything went well (I thought) and seemed to go back together A-OK. Trying to start and I'm getting the following codes P300 (Multiple Cylinder Misfire) P301 (Cylinder 1 Misfire) P302 (Cylinder 2 Misfire) & P219A (Air-Fuel Ratio Imbalance).
    I can hear the fuel pump running when I open the door or try to turn on the car. Suspecting that I was not getting fuel to the rail, I popped open the connector on the fuel line and it was bone dry; nothing coming out. I initiated the fuel pump (tapping brakes) and nothing came out.
    I've done a lot of digging online, and I'm not finding anything. Do you need to prime or flood the fuel rail? If so, how?
    Thanks in advance.
    #1 Jenkem_Enjoyer, Dec 12, 2025
  2. Mendel Leisk
    41,849
    That sounds like the brake booster.
    Cylinder one and two are “traditional” head gasket failure points. Maybe the head/block interface warped? With 275k miles, it could could have had head gasket failure for sometime; they can fail as early as 150k.
    EGR cleaned?
    the misfire codes need an extra zero btw: it’s P0301, for example.
  3. BiomedO1
    4,058
    2,136
    SacTown, Ca
    The filter sock on your fuel pump intake may be clogged; so you'll have to pull it to check. I would check the fuel pump fuse and relay first.
  4. rjparker
    10,437
    6,544
    I don't think I have ever heard the fuel pump running on my v.
    First things first
    1. Do you get Ready when trying to start?
    2. Does the engine spin when pressing the gas in Ready?
    3. Do you know what the Brake Booster whine sounds like when opening the door after sitting overnight?
    4. If you get Ready and the engine seems to start on gas pedal, how long does it spin as the high voltage cranks it using a motor generator?
    5. Are you sure you opened up the fuel rail?
    Most problems starting after a head gasket job are mass flow sensor unplugged, pcv unplugged or other vacuum line disconnected.
  5. Jenkem_Enjoyer
    spokane wa
    1) the Ready light on the Ignition Button starts green then turns orange.
    2) The engine does not spin
    3) I realized, what i thought was the fuel pump, was the brake booster.
    4) Engine doesn't spin
    5) I'm 100% positive.
    Thanks
  6. Mendel Leisk
    41,849
    I know (from personal experience :unsure:) a disconnected PCV hose at intake manifold will prevent engine start up. And that’s so easy to miss. There may be similar.
  7. rjparker
    10,437
    6,544
    The Ready light is on the dash and says "Ready". It's not the power button.
    No Ready - no engine spin - no start.
    I would check the brake pedal causes the brake lights to turn on and would check the 12v to ensure at least 12.0 volts.
    If there was a momentary reverse polarity jump the engine fuse box's internal 125a fuse may be blown.
    #7 rjparker, Dec 16, 2025
    BiomedO1 and Brian1954 like this.
  8. Brian1954
    Brian1954 Senior Member
    2,385
    958
    South Central PA, USA
    Did you remove the hybrid battery orange safety interlock plug when you replaced the head gasket?
    FYI, the fuel pump will not turn on until the car goes into Ready. So that is the reason why you do not have fuel to the engine.
    #8 Brian1954, Dec 16, 2025
    Air_Boss and BiomedO1 like this.
  9. BiomedO1
    4,058
    2,136
    SacTown, Ca
    That is some KEY information that you left out of the first post and will take troubleshooting in another direction!!!
    Air_Boss likes this.
  10. Jenkem_Enjoyer
    spokane wa
    It's taken a bit for me to get back to this (Holidays) but here's where I'm at.
    I checked the PCV hose again, it's 100% attached. I checked every sensor and hose and see nothing detached. Everything seems to be as it was when originally disconnected. (There was a broken wire on the cam-shaft position sensor originally. But that got fixed early on and the associated code is gone.)
    I hadn't driven the prius for almost a month and had totally forgotten about the Ready light. I'm not getting the ready light when I begin start-up.
    I am getting 12 volts and have checked every fuse, all have continuity.
    I forgot the hybrid disconnect initially, but remembered and disconnected early on in the process of the head gasket change. Can't recall exactly when, however.
    I'm not 100% sure how I check for 120a on that 30a fuse.
    As you can probably tell, I'm not well versed in working on a hybrid. But I am appreciative of all the help and am actually enjoying trying to figure this out.
    Thanks again.
  11. Air_Boss
    Air_Boss Senior Member
    4,219
    1,188
    New Yawk
    Reconnecting the HV battery interlock is a two step process, connect, then slide the cover over.
    Jenkem_Enjoyer likes this.
  12. Brian1954
    2,385
    958
    There are three steps to install the orange safely interlock plug.
    1. Insert the plug into the socket.
    2. Flip the lever of the plug.
    3. Slide the lever. This last step is something not completed.
    Here is a diagram from a Gen 2 Prius.
    Jenkem_Enjoyer and BiomedO1 like this.
  13. Mendel Leisk
    41,849
    Hindsight, but I wonder is hybrid disconnect needed, for head gasket replacement. I don’t think any of the high volt connectors need disconnection.
  14. Jenkem_Enjoyer
    spokane wa
    I'm going to try this today. If it is really that simple, I'm going to kick myself and send you all very merry Christmas vibes. Lol!!!
  15. Jenkem_Enjoyer
    spokane wa
    Well, that was it. It's Christmas miracle!!! Haha! I feel like a real jack-nice person. Thank you all. I think I'll go hide my head in shame now...
    Air_Boss and Brian1954 like this.
  16. rjparker
    10,437
    6,544
    You check for voltage to ground on that particular 30a fuse with the car off. If ~12v is there the 125a fuse is good.
    I spelled it out further here
    Brian1954 likes this.
  17. Mendel Leisk
    41,849
    What was "that"? The safety plug?
  18. rjparker
    10,437
    6,544
    Had to be the hv disconnect. Nothing else would fix it as quick and invite shame.
    Air_Boss and Mendel Leisk like this.
