Bug deflector and window rain visors
Discussion in 'Gen 5 Prius Accessories and Modifications' started by CruisnGrrl, May 24, 2023.
  1. Blackat
    Blackat Active Member
    459
    320
    Colorado
    2023 Prius
    Limited AWD-e
  2. 2023p
    2023p Member
    148
    93
    Here
    2023 Prius
    the in channel versions from WellVisors company are available now, haven't gotten them but considering. they also use pre layer double sided tape but it's for the inside area
    Wellvisors In-channel Window Visors 4Pcs For Toyota Prius Prime 2023-2024 23 24 | eBay
    if anyone gets or has these, please report back, maybe with pictures too. thanks
  3. Djyoshi626
    Djyoshi626 Junior Member
    34
    LA
    2024 Prius
    I have a spare set of GR Window Visors (minus the driver rear) if anyone's visors flew off. I haven't had any issues with it other than the trunk recall where the dealer had to remove my rear visors to fix. One of my visors flew off when I stuck it back on so I ordered a new set.
    2023p likes this.
  4. kev604
    kev604 Junior Member
    53
    47
    Vancouver, BC Canada
    2026 Prius Plug-in
    Grabbed a set of OE window visors from the dealer. Install looks straight forward just two clips and double sided tape. Surprised to see these were made in Japan so expecting good quality. Will follow-up with pics once I get them on.
    2023p likes this.
  5. Pepe Mtz
    Pepe Mtz New Member
    Rhode Island
    2023 Prius Prime
    XSE
    Found this hood deflector on Amazon Japan but no deliveries to US, at least it exists somewhere
  6. kev604
    53
    47
    2026 Prius Plug-in
    Got the OE window visors done on the weekend I always put window visors on my cars. Quality on these are top notch made in Japan glad I went with these over less expensive aftermarket.
    Install is super easy there are two clips the clips don't actually clip on to the frame more to help the visor sit on to the window frame. The visor is held on only with 3M tape. Key is to make sure the visor is lined up with the window frame before it sticks down then just slowly pull off the tab and apply some pressure to the sticky parts and done.
    Overall I love the aesthetic love how it sits nice and flush and the color is perfect too it's clear with a slight tint but not too dark.
  7. BiomedO1
    3,664
    1,897
    SacTown, Ca
    In my experience; you need the check the double stick tape every fall. The leading edge tends to loosen up and start flopping around, due to the hot summer heat any you blasting down the road at over 75 mph. So buy a small roll of that double-sided adhesive tape to fix that. The best time to do this is when it's still warm outside. The hotter it gets the loser the adhesive gets.
    Looks great; also check it, if you hear dash board rattles - It could be that visor rattling around in the wind.
    2023p likes this.
  8. otatrant
    otatrant Active Member
    333
    204
    San Francisco
    2023 Prius Prime
    XSE Premium
