Best 2008 tires?
Discussion in 'Gen 2 Prius Main Forum' started by KCPetite1, Dec 22, 2025 at 1:23 PM.
  1. KCPetite1
    KCPetite1 New Member
    Friday
    I just had Pirelli Tires installed and don't like them. What you you recommend 185/65/15 or 195/65/15?
  2. priumium
    priumium Member
    258
    66
    Sweden
    2013 Prius Plug-in
  3. Mendel Leisk
    41,519
    185 i/65R15 is the Toyota spec'd tire; installing 195'65R15 will theoretically increase radius of the tire by 6.5 mm (~1/4"), which will have ramifications, such as drag increase, stability reduction, through off the odometer. All slight, but...
    It will increase ground clearance of course, again, a slight amount.
  4. Hayslayer
    Hayslayer Active Member
    407
    233
    The OEM 185/65/15 tire actually causes the odo to read slightly higher than actual land speed. (ie speedo shows about 62ish when real speed is 60) Going to a 195/65/15 makes the odo almost dead nuts accurate to actual speed. For a G2 prius, any stability change isn't noticeable. MPG will drop slightly, some due to the new odo vs actual speeds, some due to the 195 tire usually being slightly heavier, some due to the car sitting slightly higher.
  5. Mendel Leisk
    41,519
    No, the computers know the true speed (approximately), but intentionally overreport speed with the speedometer, in part due to legislation: the object being to ensure drivers are never going faster than the displayed mph. More importantly, the computers also record, and display, the odometer value faithfully, IF you stick with the stock size.
    In short, going to a larger diameter tire to "fix" the speedometer, is the tail wagging the dog, throws everything else off.
  6. bisco
    51,996
    michelin energy savers, if you can find them
  7. rogerthat
    rogerthat Active Member
    388
    124
    Georgia
    I've had great luck with Bridgestone Ecopia Plus.
  8. Hayslayer
    407
    233
    I apologize Mr knowitall. GMAFB, I mis-spoke when I wrote odo, which should be obvious as it makes no sense. Should be speedo. I'm going by actual indicated speed on my speedo vs a RADAR that is displayed near my work every couple weeks in a 50 mph zone. I know for FACT that every one of the multitudes of Gen 2s I've driven the SPEEDOMETER show DEAD on with the radar display after changing to 195 tires. Jesus christ............who the f talks about odometer accuracy when discussing tire size changes?
  9. Tombukt2
    13,045
    2,336
    I run195 65 15 cheapo tyres on purpose but they've the tread pattern if the 135 dollar Michelin whatever they are . Go about 45K cost 46 bux and sposedly meet lrr specs . It says so on the four color tire label which is wrapped on each tyre. Never seen that . 4 color print advertising attached to each tyre. I mean this ture brand does not advertise not like a falken or such . The speed limit is whatever im doing . The cops say that's thats
    damn Tom someone's pool musta sprung a leak he he he. Doh. Last year a guy lost 10.000 gallons whilst I was en route floffed a whole two houses .
  10. Mendel Leisk
    41,519
    I do for one. If your priority is spoofing the car into bumping the speedometer display by 2mph, then upsizing is the way to go.
  11. rjparker
    10,167
    6,319
    It would help to know what you don't like. One mans best tire is another mans worst. Want a better ride? Michelin. Want better snow and ice handling? Michelin but not the same one. Want better mpg? Same story.
  12. Zeppo Shanski
    Zeppo Shanski Active Member
    303
    159
    Chicagoland
    You should be aware that the “NO-Name” tires sold at all major tire stores are made by “Big-Name” companies. I bought a set of tires with the K-Mart name that were made by Michelin. At the same time there were K-Mart tires made by Cooper. I think right now that Firestone’s “House-Brand” tires are made by Bridgestone.
  13. Tombukt2
    13,045
    2,336
    Yes that's why I buy them.
  14. Goodcitizen
    Goodcitizen Member
    75
    30
    Cali
    I switched to 205/60/r15 and am very happy with them. I read about it on Priuschat in some much older threads. No more traction control kicking in from wet starts. If i recall from checking tire comparison tools they're about 10% wider. I get around 45mpg. Car is much more stable feeling on the freeway and doesn't follow grooves in the road anymore.
  15. Mendel Leisk
    41,519
    The calculation is straightforward: the first number is tread width, so 185/205, and yeah, that’s about 10%.
    there’s a variation in tire “height” as well. The second number is the percent that height varies relative to tread width. Accordingly, stock height:
    185x.65=120.25
    and:
    205x.6=123
    and 123/120.25=1.0229
    I believe that last number means your alternate tire will be turning roughly 2% fewer revs per any distance, versus stock. But it’s early here…
    #15 Mendel Leisk, Dec 24, 2025 at 8:22 AM
  16. Tombukt2
    13,045
    2,336
    Very similar OD between the two tyres so great . That's pretty standard really . Raised white letters too! Used that exact tyre on 74 SR 5 flared Corolla stock in 74. It's not a real popular tire size today . So it shouldn't affect your mileage or anything very much you're almost spinning the same diameter wheel and tire assembly that you took off within tenths if not mistaken. It's when you lift the car 40 mm then put the big 215s and so on is wen mpg dumps
