Buying a used 150k mile Gen3 Prius in 2026
Discussion in 'Gen 3 Prius Main Forum' started by gafortiby, Dec 23, 2025.
  1. gafortiby
    gafortiby Member
    97
    58
    Colorado
    I am about to buy a Gen 3 Prius now in these last few days of 2025, but probably Jan 2026 due to holiday timing. My requirements are odd but real.
    • Budget $8.000 USD (in US market)
    • 160k miles or less (=nearly 0% chance of head gasket or oil consumption in next 50k miles)
    • Toyota but not Lexus
    • Hatchback/wagon
    • Automatic climate control
    • Backup camera
    • IIHS rating is GOOD for both side/front.
    As of December 2025, that means Gen 2 or Gen 3 Prius. Venza and Prius V fit my requirements but clean listings are outside my budget.
    So:
    1. Should I avoid white exterior because of the paint peeling problem? I actually would prefer white but not if it peels off. :LOL:
    2. Should I only buy 2014+ with VINs after revised piston and piston rings?
    3. Should I just get a Gen 2 instead?
    Back in 2015, I bought a 2012 Prius V and it has been amazing so far. I had not known anything about Gen 3 head gasket or piston ring problems at the time. I am only at 94k miles today, so I don't have death knock or oil consumption problems yet. I can DIY oil changes, coolant drain/fill, EGR and intake manifold cleaning, spark plugs, etc. I am also okay with replacing the Hybrid battery some day, hopefully after 2030 but earlier if necessary. The money to buy a new battery is in a separate budget.
  2. Tombukt2
    13,290
    2,398
    You a gamblin man fo sho. Luck to yas.
    gafortiby and bisco like this.
  3. Brian1954
    Brian1954 Senior Member
    2,371
    954
    South Central PA, USA
    • I put the odds of a Gen 3 Prius of having a head gasket problem at mileage of 160k to 210k at about 50% or more, definitely not near 0%.
    #3 Brian1954, Dec 24, 2025
  4. JC91006
    JC91006 Senior Member
    16,815
    8,596
    at 160k miles, a gen 3 would soon be needing a brake actuator and hybrid battery. And then you have to worry about a head gasket afterwards.
    My 2010 just got the brake actuator replaced at 165k miles and hv battery failed back in 2020. I just have to look forward to the head gasket failing one day.......but with timely coolant changes and water pump replaced, fingers crossed that it won't happen.
  5. ETC(SS)
    7,312
    I was about to say that you won't have to worry about the IIHS rating because the car is going to be a hangar queen buuuuut you're a G3 owner (victim) and you seem to know what you know.
    I'll leave the validity if an IIHS rating for a small car in a state that's over-represented by 4x4 trucks for another day. ;)
    I have over 200,000 in G3s and I never felt that they were death traps - but my work car is now a 4x4 (barely) and my personal car is a truck, because physics really doesn't care about people's 'feels.'
    WHAT I WOULD DO if I woke up in your shoes is give you back your shoes.
    THEN I would look for a 2014-15 BASE MODEL with maintenance records from a private seller.
    I would not get one with an OEM backup camera for the same reason that it's moronic to buy a car with a "gps" system.
    You're paying for yesterday's technology with tomorrow's dollars.
    Reserve $300-400 for some tin-ear audio shop to install an aftermarket system which will solve both your phone integration issues and give you a functional backup camera.
    Priuschat has a marketplace where G3's show up for sale by PC people - who are generally more likely to have taken care of their car.
    Realistically speaking in places other than the Southeast US, Priuses are over-priced, so you may want to spend more than 8K buying in.
    (I paid $2.039 a gallon for my last fillup)
    Your budget should 'guide you,' not rule you.
    Good Luck!!!
    ColoradoBoo, gafortiby and BiomedO1 like this.
  6. BiomedO1
    4,019
    2,109
    SacTown, Ca
    You're not going to find a 160K mile car that doesn't burn some oil; even with the revised piston rings. They will usually be down at least 1/2 quart @ 10K intervals or 1/4 quart @ 5K intervals - is the best you can hope for. So that rules out pre-2015 gen3s. Also heard there's a booming business of odometer roll-backs on them.
    Good Luck on your search......
    gafortiby likes this.
  7. ETC(SS)
    7,312
  8. Mendel Leisk
    41,824
    I fixed that for you. :)
  9. bisco
    52,286
    saving money on gas can be expensive. with 8k, i would buy a non hybrid
  10. gafortiby
    gafortiby Member
    97
    58
    Colorado
    Thanks for the engagement and useful feedback.
    • I'm surprised that gen3 engines will burn oil even with the revised piston rings, but I should have clarified I'm trying to avoid heavy oil consumption that will risk oil starvation on the engine--more than 1qt before 5k mile oil change internal. 1/4qt at 5k is livable on a 200k engine, since that means I don't actually have to top-off between oil changes.
    • I'm okay with aftermarket camera too.
    So, if my goal is to just run a car for next 50k miles, would I have better luck with a 2010 gen3 with 100k miles?
    OR are you all saying I instead should go for gen2 Prius or a non-Prius?
  11. rjparker
    10,411
    6,521
    I would give it a 75% chance of an expensive repair before 200k. Brake Actuator, HV Battery or Head Gasket especially on an unknown gen3.
    Given your luck is holding on your 2012 stay with it. You will have a big expense or two in your ownership on that one. I would consider a Rav4 hybrid in your price range if a hybrid has to be the second car. Better yet a conventional Civic, Corolla or Camry with due diligence.
    Remember any shop can repair a conventional model. Not so with a hybrid.
  12. gafortiby
    gafortiby Member
    97
    58
    Colorado
    Haha this is a good point about weight/height of car. But unless I jump into a Ford F350, I can't out-class my road neighbors here in Colorado. Which is why I'm avoiding low-weight cars like Prius C and Yaris. A 3000lb Prius is a compromise, which is why I'd at least need IIHS rating to be higher.
    Yes I'm keeping my 2012 Prius V. This purchase is to replace my Honda Civic, but the opinion of high-millage gen3 owners on this forum so far is to stay away from their babies? ;)
    #12 gafortiby, Dec 24, 2025
  13. bisco
    52,286
    idk how many problems we've seen with the revised parts. you want 50k and how many years?
    and determining if the seller hasn't added stop leak can be an issue
  14. indel
    indel Member
    261
    83
    Northwest Indiana
    I bought a 2012 Two with 142K a few weeks ago for $8500. So far, I have put 2000 miles and there is zero oil consumption. The coolant level has not changed and the battery health could be better, but it will likely last me a few more years. In the meantime, I spent $2000 more to buy a new EGR train, both water pumps, all new fluids, spark plugs, pcv valve, intake manifold and a new 12V oem battery. Once all those parts go in and fluids are replaced, the car is good for at least another 150K, if not longer.
    In all, I am happy with my purchase. It's a Prius I always wanted (red or white gen 3) and now I have it.
    Edit: Also, the MPG is 45. I am sure it will go up after I do all the replacements and clean the throttle body.
    #14 indel, Dec 24, 2025
    ColoradoBoo and gafortiby like this.
  15. BiomedO1
    4,019
    2,109
    SacTown, Ca
    Your still in the honeymoon phase and 10K out of pocket for a 13 year old car w/140K+ miles on the clock....
    I bought a new 2012 Prius C for $15K-$16K out-the-door. It started burning 3/4 qts every 10K oil change interval around 70K-80K miles (0w20 OEM rec.). I moved to 5w20 and burn rate reduced to 1/4 qts every 10K oil change interval; acceptable. I now know it was low tension piston ring related. It was a great car and the only real issue I had with it, until an uninsured motorist totaled it out.
    Just my experience and 2-cents......
  16. indel
    indel Member
    261
    83
    Northwest Indiana
    I understand and I am willing to put more work into the car as needed. And if need be, a complete engine rebuild. A new Prius is $35000 and still only comes with 3 year warranty plus a longer battery warranty. I am mentally prepared to deal with any future challenges.
    My other car is a 2006 Civic LX which I bought at 100K miles in 2012. Now the car has 292K and I have maintained it diligently. Still on the original engine which does not burn any oil. Though it has now started leaking through the valve cover, so the VC gasket job is due soon. Otherwise, knock on wood.
  17. indel
    indel Member
    261
    83
    Northwest Indiana
    It is my strong opinion that Honda has won out in engine longevity over Toyota. I rarely hear about Honda engines burning oil or having piston issues. I just cleaned the EGR valve on my 292K Civic and there was little to clean. I wouldn't get rid of that Honda if I were you.
  18. gafortiby
    gafortiby Member
    97
    58
    Colorado
    If I had a regular civic, I would keep it. But it’s a HCH II with bad CVT and bad hybrid battery.
  19. JC91006
    16,815
    8,596
    Not sure many people will share this opinion with you. There are countless Toyotas that are running after 300k miles, not so much with the Honda cars. Those engines are lucky to make it past 300k
  20. indel
    indel Member
    261
    83
    Northwest Indiana
    My first car was a 2000 Toyota Corolla (1ZZFE) which burned copious amount of oil. The first engine replacement lasted 1 month before it threw a rod, the second one 2 years. Apparently, Toyota still had not figured out the engine oil burning problem as late as third gen Prius. That's almost a full decade and half. Either they are just ignoring the problem or are incompetent. For the third gen Prius, countless people have been forced to do either a head gasket or engine replacement. While no one can reliably provide stats on Honda vs Toyota, these problems are factual and there is no denying them.
