Can I bleed brakes old fashion way?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by hendr1x, Dec 20, 2025.
  1. notspam3
    notspam3 Member
    88
    45
    Toronto
    2024 Prius Prime
    XSE Premium
    Toyota mechanic buddy told me doing it the old fashioned way is a surefire way of springing new leaks on old brake lines, you can bleed the brakes by simply opening/closing the driver door which activates the pump for a short period. Has anyone else heard this rumour?
  2. Mendel Leisk
    41,850
    Having someone push the brake pedal is much more reliable. Which you do while you're in "invalid mode", which is explained very clearly in the aforementioned, linked, and recommended @NutzAboutBolts video. I'm losing interest in this, though
    Tombukt2 likes this.
  3. Brian1954
    Brian1954 Senior Member
    2,386
    958
    South Central PA, USA
    Do not ask your Toyota mechanic buddy to work on your car!!! What he told you is wrong. Activating the brake pump by opening the drivers door does NOT bleed the brakes. Please provide the name of the dealership that he works at so that other people can avoid that dealership. I would not let that mechanic touch my car.
    #23 Brian1954, Dec 26, 2025
