How to open the rear door (Sounds simple, doesn't it?)
Discussion in 'Gen 2 Prius Main Forum' started by Andrew Vanis, Dec 26, 2025 at 7:45 PM.
Tags:
  1. Andrew Vanis
    Andrew Vanis Junior Member
    31
    Albuquerque
    How to open the [passenger] rear door (Sounds simple, doesn't it?)
    How to open the rear door if none - the ext handle, the interior handle, the cable, nor moving manually the lever on the lock actuator - fails to release the lock clasp from door latch striker bolt?
    The reason it doesn't open is likely my fault since it opened before I removed/repaired the lock actuator.....and now I'm in this predicament :-/
    the lock/unlock actuator now works and moves the lever on the handle.
    So either it is permanently locked or the handle release mechanism is faulty inside the actuator.
    In any case, the door is closed and it won't open.
    I've considered cutting the door sheet metal from the outside and destroying the lock actuator assembly for a manual release of the door (and then replacing the door.)....I'm hoping that is an alternate solution.
    Thanks in advance.
    #1 Andrew Vanis, Dec 26, 2025 at 7:45 PM
  2. PriusCamper
    PriusCamper Senior Member
    12,800
    5,185
    Pacific Northwest, USA
    No need to destroy the car, Just climb back there and start taking stuff apart from the inside and you'll get it open without much effort. I'm pretty sure on Gen2 you can jam a big screwdriver into the latch mechanism and force it open. Worst case scenario you use an oscilating tool to cut open the latch mechanism and then grab a used mechanism from the local junk yard for $20. But I bet you it you get it with force on the emergency latch mechanism before you have to do other options.
    #2 PriusCamper, Dec 26, 2025 at 7:55 PM
  3. Andrew Vanis
    31
    Albuquerque
    I see your 13k post so you must know your way around ...however.... the access to the lock actuator is blocked by the rear window channel track. that limits leverage and blocks access to a multi tool.
  4. PriusCamper
    12,800
    5,185
    You haven't explained why the emergency release has failed you?
    Ok I just looked again... Not sure what you mean by "window channel track" but if you mean the plastic cover/threshold at the bottom of the hatch back that covers the latch and its really truly jammed, just use a cut off tool to cut through that plastic and unbolt the latch mechanism so it goes up with the rear hatch when you lift it up.
  5. Andrew Vanis
    31
    Albuquerque
    I am dealing with the rear passenger door, not the rear hatch/truck shown in your linked video.
    Luckily I did not install the inside panel yet so I have access form the inside but haven't figured this one out yet.
  6. PriusCamper
    12,800
    5,185
    Oh... I understand... The rear hatch is often called a rear door. Had you said passenger side or driver's side rear door then more people would be able to help.
    Anyways, are the metal rods still connected to the the latch? Or are they disconected. You shoul be able to remove the arm wrest to gain access. Worse case scenario you'd make an opening big enough to get your hand inside the door knob to reach the actuator and release it. You migh have to remove the other one on the other side of the car to figure out how your arm and a tool are going to reach it and release it. Or got to a local wrecker that lets you pull parts and you can practice the job there without damaging your car.
  7. Andrew Vanis
    31
    Albuquerque
    How can the topic title be changed? I can see I can edit the body but not the title. Any help appreciated.
    What you describe doesn't match up with what I'm seeing inside the door, for example, there are no rods, there are cables and I can't see how removing the door handle would gain any access (though my interior panel is off so I have the best access possible in this case.)
    What Door knob are you referring to? I am familiar with the arrangement of the actuator since I already removed, disassembled, and reinstalled it so no need to go to wrecking yard to see how it looks. As I mentioned in first post, manual manipulation of the actuator does not release the latch/door.
  8. PriusCamper
    12,800
    5,185
    I've only worked on front driver doors and rear hatch latches on Prius... It's wear all the wear and tear is... Here's the image I found of what you're dealing with online... Why can't you attach a pair of vice grips to the end of one of those cables and apply a huge amount of force to the cable while also forcing the door open?
    Basically what I'm saying is its time to start applying so much force you start to break stuff.
    If I was still working in a shop with air tools I'd find a way to fit my air-chisel inside that door from the inside of the car and I'd turn that entire latch mechanism into smaller and smaller pieces until the door opens.
    Of course if I was still working in a shop I'd be so paranoid about something like this happening that I wouldn't of allowed the door to close and obstructed the latch mechanism in the first place because the level of ridicule my co-workers would put on me for making this a problem would be way worse than the problem.
    #8 PriusCamper, Dec 26, 2025 at 11:31 PM
  9. Andrew Vanis
    31
    Albuquerque
    The cable motion isn't the issue.
    Breaking it apart may have to be the approach.
    PriusCamper likes this.
