600W DC-DC 12V to 60V "alternator charger" on Prime 12V batt?
Discussion in 'Prime Main Forum (2017-2022)' started by LithiumMan, Dec 27, 2025 at 9:30 AM.
  1. LithiumMan
    LithiumMan Junior Member
    Columbus, Ohio
    Is it OK/safe to use, for example, the Jackery "DC-DC Alternator Charger" to charge my Jackery portable power stations while driving? The alternator charger has an ACC input sensor wire to assure, I believe, that the charger will only drain power from the Prime's 12V battery when in hybrid mode.
  2. BiomedO1
    3,682
    1,912
    SacTown, Ca
    I don't know about the Jackery power converter, but I've done a Bluetti converter unit. That Acc input will only cut-off the unit when the battery/power get to a preset threshold number. In other words, it' on all the time, including pure EV mode. Don't know if you can adjust that threshold cut-off number. I would set it around 12.3VDC-12.5VDC, since the gen4 batteries usually live right around 12VDC. I would also carry a backup jump box - but the car will start all the way down to 10.5VDC; if you pull the fuse to that Jackery converter. That way it doesn't swamp the system as your trying to get it into 'ready mode'.
    Make sure you have the properly sized wire for your cable run and properly fuse it. You don't want someone T-boning you and have an active line, ready to spark a fire. Anything over 50VDC can hurt you; 12VDC not so much - just a tingle if your really sensitive. Make sure there's plenty of ventilation around that converter box - DO NOT bury it under your junk; that's a sure-fire way of burning it out.
    Good Luck.....
  3. LithiumMan
    Columbus, Ohio
    Thanks, BioMed! So, it's OK to pull roughly an additional 600W (max) continuously off my Prime's (2017 vintage) DC-DC converter (HV-to 12V)? What if, while driving, I have other hi-draw accessories on, such as the heated seats, rear window defroster, climate control (heater) on high fan blowing?
    Also, in pure EV mode, I presume the climate control heat comes from an electric heat pump rather than from engine heat. Does the heat pump run directly off the HV battery or does it use the12V power source?
    Thanks for your help.
  4. BiomedO1
    3,682
    1,912
    SacTown, Ca
    The heat pump is driven by the traction battery and the Prius DC-DC converter is good for around 1000W. You'll need to watch whatever you have drawing off the 12VDC system alone. You'll get into trouble if you try to run a 12V to 120VAC inverter at the same time as charging your Jackery; you'll overwhelm the Prius DC-DC converter. Any appliance you can plug into the Jackery would be helpful - your going to use the Jackery's built-in protection system as a safety cut-off - so that 600W charger will charge your Jackery when demand is low. You can put the car into 'ready mode' before you start drawing high current from the Jackery, so you let that unit manage the power demands. It should draw off of it's internal batteries when you exceed 600W, while firing up your coffee pot or electric stove.
    I'm actually surprised that an electric blanket draws less than 600W, just warming up then pulses on-off to maintain heat - great for winter car camping, so you don't freeze your butt off.
    Good Luck.....
  5. LithiumMan
    Columbus, Ohio
    Yes, I'm using a VIVOSUN plant root heating mat for sleeping on in the car. It measures 48" x 21" and draws 100W (120VAC). Unlike an electric blanket which tends to have somewhat protruding internal heating wires that can easily get snagged and tugged on in a car full of belongings, the Vivosun is truly a smooth mat surface and is water resistant. Actually 100W is too warm--I've experimented supplying it with a lower voltage like 85V and that is more comfortable.
  6. LithiumMan
    Columbus, Ohio
