Lower glove box not easily opening
Discussion in 'Gen 3 Prius Technical Discussion' started by BoydII, Dec 27, 2025.
Tags:
  1. BoydII
    BoydII Junior Member
    OK
    Good afternoon all,
    when I bought this Prius, the bottom glove box didn’t seem to want to open unless you pushed it to the left. Once I get it open, there seems to be nothing wrong or anything in the way. I have replaced that filter on more than one occasion so I’ve had to look back there.
    I can’t seem to figure out why it doesn’t seem to want to easily open and close.
    on the left side where the button is, the door is proud about 3/8 of an inch or so and is not flush with the button. It moves if I push it back and forth.
    any pointers?
  2. ASRDogman
    ASRDogman Senior Member
    7,808
    3,980
    There is a "shock" on the right side, as you look at it, perhaps it is stuck?
    There are two positions for it fit on.
  3. BoydII
    OK
    It seems to overlay. It’s a little wobbly and in the first slot. Seems to lean more to the right.
    right side is flush and left side is a bit proud.
  4. ASRDogman
    7,808
    3,980
    Proud?
    Make sure the door is attached correctly where the two slots are at the pivot point
    on the bottom of the door
    Brian1954 likes this.
  5. StarCaller
    StarCaller Senior Member
    1,279
    730
    Cedar Crest, NM, USA
  6. BoydII
    OK
    Sorry…. Using finish carpentry terms. Proud means it’s sticking out a bit. It’s in both of the pivot holes. Still off though.
  7. BoydII
    OK
    Here are some photos. I have to push from the right to get it to drop down.
    So the door sticks out a little bit on the top left. I suspect that pushing the button doesn’t push the releasing far enough to make the right side completely release.
