Signs/hints that your hybrid battery was on its last legs
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by rubia, Dec 28, 2025.
Thread Status:
Not open for further replies.
  1. indel
    indel Member
    273
    88
    Northwest Indiana
    Did anyone tell you before that this is the internet and that you are not entitled to anything? People on here are doing the best they can to help you. But your tone is rather disappointing.
  2. rubia
    rubia Junior Member
    43
    Saratoga Springs, NY
    I didn't reference any videos. Again, this was someone else, going off on a tangent I didn't ask about.
  3. rubia
    rubia Junior Member
    43
    My tone? Are you my father? You think I should be grateful that I've asked a simple question and instead of getting any actual answers that address my actual question, I've instead got to sift through a bunch of gear head nonsense that isn't actually helping me at all? Ok, dad.
  4. PriusCamper
    PriusCamper Senior Member
    13,044
    5,299
    Pacific Northwest, USA
    Get yourself one of these: http://www.ebay.com/itm/265484403768
    It allows you to connect your phone to your car and use apps like Dr. Prius app to test and monitor hybrid battery health. It also helps you clear error codes, which at some point may mean the difference between clearing those codes and continuing to drive rather than waiting for a tow truck.
    As for us being utterly useless... There's lots if good information in this thread. Perhaps if you have some specific questions or need for clarification, we'd be less useless to you?
  5. rubia
    rubia Junior Member
    43
    I asked the question. And then I clarified the question. And that's what started the thread - and it's the thread I called useless - the thread, not the people on the thread - because none of what was shared, save one comment, actually addressed my question. I'm done here.
  6. PriusCamper
    13,044
    5,299
    Thanks for your participation on PriusChat... We always encourage people to search and learn from all the threads on PriusChat BEFORE starting a new thread. There's decades of conversations on here that can answer almost any question, but if you start a new thread without doing your homework first you're going to be dissapointed with the cluster uck nature of our community.
  7. rjparker
    10,491
    6,581
    I will try again.
    Step 1
    Fast discharge is a sign of a weak battery and was one I saw when my oem pack was going bad. As it progresses you can get to the point where the engine won't stay off during a traffic light stop. That is weaker yet. When it further loses capacity it might be noticeably slower accelerating from a stop. Truly weak results in lower mpg of at least 5 mpg - sometimes 10 mpg.
    All the above without throwing a code or "the red triangle of death".
    Step 2
    Even when it throws a code and lights up the dash, the car will normally still run for a month or more. Your time is short.
    Step 3
    The real problem is when the hybrid battery is so weak (after coding in 95% of the cases) that it can not supply the nominal 201 vdc long enough to spin the engine to a start.
    I elected to change the hv battery after Step 1 had been a concern for two months. I did not want to tear it down and replace bad modules and spend days or weeks of effort.
  8. rubia
    rubia Junior Member
    43
    I'll try again, too.
    Fast discharge: I don't know what this means - not in this case. What is it in plain terms, how do I spot it, where is it noted, if at all, does it feel or look a certain way, etc?
    OEM - no idea what this is without googling.
    Pack - no idea. Battery pack, maybe? But I have no frame of reference for this. If it's not something I can see or check without additional effort or apps or equipment, it's not what I'm seeking in this line of questioning - because I am not there yet, not because it isn't relevant.
    Slow acceleration - yes, this is happening. But also, it's freezing outside, which is why I asked about temps. Is the cold a mitigating factor? It feels like it is.
    As for MPG, I don't even track it so I have nothing to go on at this point.
    (As for the rest, I can't address it because again, it's not where I'm at. Engine starts. No codes. All seems well but for a sinking feeling I have that might not be real.)
    #28 rubia, Dec 29, 2025
  9. rubia
    rubia Junior Member
    43
    Yes, I did my homework - as much as I could. And I posted my dumbed-down and extremely clear question because all the threads I could find were bogging me down in tech specs and details that I cannot use - and can barely comprehend - at this exploratory and very early stage.
    #29 rubia, Dec 30, 2025
  10. rjparker
    10,491
    6,581
    Watch the battery state of charge bar graph on the fisplays. In the user manual.
    First you have one of the most complex car's ever made with 20 plus networked computers and a conventional gas engine plus all the elements of an electric vehicle (ev).
    Many mechanics have big shops and are prosperous but still do not understand or work on hybrid related issues. So don't feel bad.
    You could pay $175 an hour for a dealers diagnosis. Without codes they would tell you the battery is fine. They are often the only hybrid mechanics in many areas. Even then, there may be only one or teo top guys at a dealer that truly understand and can repair them.
    Here you are getting free advice but obviously you are not experienced in a hybrid vehicle's terminology.
    OEM is a common word that is an abbreviation for original equipment manufacturer; eg oem factory battery in this case.
    Battery pack is right! There are 28 battery modules bolted together which makes it dangerous to work on and makes it expensive to replace.
    No, cold is not a factor. The hybrid battery warms up quickly as it charges and discharges.
    All you have to do is read it on the trip display. Instructions in the User Manual. Simply reporting it would be diagnostic.
    I believe you have a weak battery which is normal for a 13 year old hybrid. Most are replaced earlier than 13 years; Toyota only guarantees them for ten years.
    I would start saving for the time it needs one. That time is not now but could be next March or a year from March.
    #30 rjparker, Dec 30, 2025
    VelvetFoot likes this.
  11. rubia
    rubia Junior Member
    43
    Do I? In my question, I didn't describe anything that I was experiencing... I still don't know how to even note a discharge, so...? I have to look at my display and user manual but in the meantime, did you mean when I said it's slow to accelerate...?
    Sorry, I do know terminology but my point was that it's not layperson's terms, which is what I was looking for in my original question - real simple conversational stuff. Nothing technical. I used to be an electrician so I'm not starting with zero knowledge - just in this case I'm in a period where I need the most basic language possible for a myriad of reasons which I won't bore you with and thanks for understanding.
    This makes me feel a bit better - thanks for this.
  12. rjparker
    10,491
    6,581
    We both have 2012 Prius vehicles. Mine is 14 years old since I bought it in Nov 2011. Hybrids batteries do wear out but Toyota can't accurately predict the doa (dead on arrival) date. Neither can an app or a scanner.
    Yes, watch the battery state of charge bar graph on the displays. The engine running at stoplights is a sign of a weak battery. As is abnormally poor acceleration and degraded mpg.
    As an electrician you know house wiring, meters and breakers. That is Model T stuff compared to modern hybrid power electronics, batteries and controls.
    Top tip (UK term for best advice) to maximize free input:
    Start with the problems you are experiencing. "It shudders and makes horrible noises on startup it did not used to do" perhaps or "a mechanic said it was ok but I don't believe him" or whatever.
    List how many miles the car has and how long you have had it.
    How much longer does it need to last?
    What work has been done in the past?
    Its ok to say I read or heard something about hybrid problems like the battery and now I am worried.
    https://insideevs.com/news/782820/prius-battery-engine-trouble/
    #32 rjparker, Dec 30, 2025
  13. rubia
    rubia Junior Member
    43
    Oof. Usually people are more impressed when I tell them I was an electrician. Actually, it's even less impressive than housing - I worked in the clubs and doing live concerts/events/raves in NYC back in the day.
    I'm being cautious and looking at the major issues - head gasket and battery - but am in no position to do most of the DIY or Dr. Prius-related sleuthing that is suggested by commenters here. I wish it were different, but it's not. Even when people insist "it's easy". I can promise you it's not. Not for me, not at present.
    I actually just went through my EGR/head gasket/spark plug/etc panic and it didn't seem to be a thing but it's all so uncertain. I was much more patient on the thread where I asked about that issue as I was looking for technical info to relay to the one mechanic in a hundred mile or more radius who has actually worked on a couple of hybrids. (I live in the middle of nowhere in a sea of F-150s.) He said it looked fine but I'm wary because my luck the past few years has told me to be wary.
    I've just lately noticed sluggish acceleration - more than usual - as it's gotten very cold here and I see the charge bar going into the red more often than I've noticed before - but tbh I've not paid very close attention. The battery icon retains almost all bars to the top as far as I recall. I'll look again tomorrow and use my manual. For this issue, I just wanted basic info because I'm going to have to figure this out on my own and I have to do it by baby steps. I appreciate your help. I'll look into buying a Hummer, as you suggest.
  14. Mendel Leisk
    41,889
    It might be better to say (and think of it as) “the software I used said it was” such-an-such. Different test methods might give varying results, test conditions might be less than optimum.
  15. Mendel Leisk
    41,889
    That’s often the case. But not necessarily “utterly useless”.
  16. indel
    indel Member
    273
    88
    Northwest Indiana
    For my pre-purchase inspection, I specifically asked the dealer to inspect the battery health and EGR system parameters. This was their response, taken directly from the toyota owner's service log for the vehicle:
    "CUSTOMER STATES ~|~CHECK EGR AND HYBRID BATTERY ~|~ ~|~BATTERY STATE OF CHARGE WAS WITHIN SPECIFIED RANGE, EGR SYSTEM WAS FUNCTIONING AS INTENED, NO FAULTS PRESENT"
    Which means, they didn't do diddly squat other than scan the ECU for codes. When I called in to ask why, they told me they don't have the equipment. They still took $200 for the inspection though. A $13.99 purchase within the Dr. Prius app told me more than the dealership could. A dealership has no vested interest in taking the time to diagnosing the issue. The business is entirely based upon making bank as fast as possible by throwing parts at the car. I am sure if PA080 shows up, they would instantly jump to replacing the pack for $3299 plus $1200 in labor.
  17. rubia
    rubia Junior Member
    43
    To me, for my purposes, what I can use at the moment. So, yes - accurate. But not useless info, no.
  18. PriusCamper
    13,044
    5,299
    If you had simply said it was too much information and asked for something more specifc/re-phrased your question... But instead you told us our efforts to help were useless and then got surprised that some people might take offense to that. For me personally, I've got no issue with you or anything you said, just need some feedback on what I offered so I can do better when it comes to helping people on here in the future.
  19. PriusCamper
    13,044
    5,299
    Perhaps if you used google or chatGPT to understand these?
    OEM = Original Equipment Manufacture, which means the exact same part that was made for the car when it was brand new as opposed to a usually cheaper aftermarket part that works but is not made by the same manufacture.
    As for fast discharge, that's literally a display on your dashboard that shows how charged up or discharged your hybrid battery pack is. Check your owner's manual for more details.
    Battery Pack / pack = hybrid battery
  20. VelvetFoot
    VelvetFoot Active Member
    1,194
    467
    New York State
    2026 Prius
    Ok, to drag this topic a little more astray, how does it charge and discharge so quickly? My laptop takes hours! :)
Thread Status:
