Signs/hints that your hybrid battery was on its last legs
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by rubia, Dec 28, 2025.
Thread Status:
Not open for further replies.
  1. PriusCamper
    PriusCamper Senior Member
    13,102
    5,310
    Pacific Northwest, USA
    NiMH electrolyte has a problem with crystallizing as it ages, which means it can store less electrons, as low as 50% of orginal capacity before car gives warning lights. It's easily eliminated by deep cycling the pack several times. Back in the 90's laptops used to run on NiMH and had this problem. Lithium batteries chemistry resolved it for the most part, but if you have a really old lithium battery for your laptop it can charge and discharge quickly too.
    VelvetFoot likes this.
  2. PriusCamper
    13,102
    5,310
    You don't know how to use a phone app? But you used to run sound boards at concerts and used to be an electrician? It seems pretty clear that your avoidance of learning to figure stuff out is a problem, not your actual skill level.
    indel likes this.
  3. indel
    indel Member
    279
    88
    Northwest Indiana
    The greatest motivation in consuming information on hubs like Priuschat is to learn what you don't know and go as deep as your interests would allow, in order to fix your vehicle. If one wants simplified information, a dealership will make it easy. But you sure as hell won't be learning anything interesting about how your vehicle works from them.
    Forums like Priuschat are entirely run by knowledgeable folks who have an interest in sharing their knowledge and wisdom with others, free of charge, akin to the open source movement for software. The last thing you want to tell these folks is that you have no interest in learning and want simplified answers. A horse can be brought to the water. It's up to the horse to drink.
    PriusCamper likes this.
  4. ASRDogman
    ASRDogman Senior Member
    7,844
    3,997
    :eek::eek::eek::confused::confused::confused:o_Oo_Oo_O
    Put salt in the oats, and you can make it drink.....
    (y)(y):whistle:
  5. rjparker
    10,577
    6,634
    When a battery has little capacity left it takes an equally small time to discharge or recharge it. Remember the car has a big charger and uses advanced monitoring of the battery. When a battery has a failed cell or two it may never reach fully charged. So we are talking weak (low capacity) versus failed (bad cells).
    Brian1954 likes this.
  6. BiomedO1
    4,216
    2,200
    SacTown, Ca
    Here's an example; the traction pack is made up of approximately 28 individual batteries (modules) chained together. You get a couple of weak modules, they won't take a charge as well as the rest of the modules. Conversely, they'll also output less than the other modules in series - ergo faster than normal discharge and recharge cycles. The charging ECU treats the 28 modules as a single battery, which we refer to as the traction pack.
  7. VelvetFoot
    VelvetFoot Active Member
    1,245
    487
    New York State
    2026 Prius
    I was looking at the soc % via obdc on my new Gen5. It goes up and down a lot. Perhaps there is a graphic on the car's instrument panel as well, but I haven't looked for it.
  8. jacktheripper
    jacktheripper Senior Member
    276
    550
    @rubia , feel free to stop by any Dr. Prius App certified shop and let them know Jack sent you for a life-expectancy test. You can find the full list of certified repair shops here:
    Dr. Prius certified installers around the globe– NexPower Energy
    Based on the test results, you’ll get a clear picture of your hybrid battery’s condition.
    Best Regards,
    Jack
    ASRDogman and PriusCamper like this.
  9. rubia
    rubia Junior Member
    43
    Saratoga Springs, NY
    You are displaying a level of ignorance that I would not aspire to, friend. You don't know me or my current situation or what I can or cannot handle and yet here you are: judging a complete stranger for no discernible reason but to be a jerk. Walk a mile, etc., and maybe stop "contributing".
  10. rubia
    rubia Junior Member
    43
    Reading comprehension again at a low. "No interest in learning" doesn't even come close to what's happening here. Or what was expressed. Some people have a need to be the smartest person in the room rather than truly being helpful in terms of just answering an actual question. That's an issue for them personally to work out, maybe in therapy. For those of us on the other side, being hit over the head with the "you should be grateful" bludgeon, it's tedious and achieves the opposite of whatever "sharing knowledge" is about.
  11. rubia
    rubia Junior Member
    43
    Kind of you, Jack. The closest one is five hours from here so it won't be something I can use, but I do appreciate your kindness.
  12. PriusCamper
    13,102
    5,310
    Congratulations! I'm here to help people every day for a dozen years and you're #1 most vague an unclear person about your personal abilities than anyone I've ever interacted with... And I'm talking about an average of a thousand interactions a year. That's quite an accomplishment. Very impressive!
  13. rubia
    rubia Junior Member
    43
    And you and your shitty attitude are a dime a dozen. Not impressive, not an accomplishment. Just typical. So, congrats, I guess.
    From the logline: "PriusChat is the one of the largest privately-owned car forums left on the internet. We hope you'll join our home to educated & critical discussion, *****falling outside of the fray of Internet trolls & unconstructive discussion*****."
    Oh, well. You tried.
  14. PriusCamper
    13,102
    5,310
    At this point I'll just simply report you to our moderator because regardless of if you're real or AI you have no interest in what your asking answers for in this thread. You're simply just looking to troll people and have shown zero concern for caring about your Prius, let alone learning about your Prius, which we're obviously here to help you with...
    #54 PriusCamper, Dec 31, 2025
  15. rubia
    rubia Junior Member
    43
    BULL SHIT. But please do report me. I've been trying to get my account deleted for days since people like you are so rude and unhelpful.
  16. PriusCamper
    13,102
    5,310
    I already reported you... I hope someday when you're sitting on the side of the road waiting for a tow truck you think of the link I sent you to a $20 device that you could of used to connect your phone to your vehicle to clear error codes and could keep driving to your destination without issue. More to the point, I feel sorry for anyone who genuinely wanted to help you because you clearly never wanted anyone's help in the first place.
  17. rubia
    rubia Junior Member
    43
    I'm sorry you need to be right so badly that my lack of gratitude has hurt your feelings so much but MY GOD. In this case, you are not helpful - it doesn't matter how much you know. You have not addressed my question AT ALL. Do you know if I can I afford a $20 device? Do you want to pay the $20 for me? To do what? To clear codes? Did I even mention error codes? NO. I didn't.
    I don't know what your issue is but it's nothing to do with me. A little humility would go a long way if you truly want to be helpful. And not for nothing, this is an example of the kind of misogyny that keeps these forums mostly populated by men. How is that helpful???
  18. PriusCamper
    13,102
    5,310
    Anyone with a computer who can post to priuschat, as well as also has access to a prius can find a way to afford $20 for a device that if kept in the glove box for emergencies can one day eliminate a $200+ towing fee. It can also give you valuable information about the health of your hybrid battery which is the question you asked us to answer... Or maybe you're just AI?
  19. VelvetFoot
    1,245
    487
    New York State
    2026 Prius
    I know it drives me crazy when a perfectly normal thread I create (in other forums, of course, never here :) ), goes off-track, but without being a moderator, you can't do anything about it. You can try to steer it back yourself, but that may or may not work. This forum doesn't seem to be super moderated, which can be a good thing. I've felt "ganged up" in other forums, had innocuous posts removed, etc, but as I said, can't do anything about it.
    Saratoga Springs, eh? I'm in Averill Park.
    My first Prius, a '26. I'm loving it.
    Happy New Year
  20. ASRDogman
    7,844
    3,997
    This is America, no one if forcing you to log in and continue to whine and cry while people are helping you
    but you refuse to listen.
    It's likely you'll be removed, but until then, I'll use the IGNORE function! :rolleyes::rolleyes::ROFLMAO::ROFLMAO:(y)
Thread Status:
