My son drove his Prius into 2+ feet of standing water
Discussion in 'Gen 3 Prius Technical Discussion' started by GasSavings, Dec 30, 2025 at 7:10 PM.
  1. GasSavings
    GasSavings Junior Member
    Toronto
    My son’s a new driver, just got his G licence, and loves his Prius. He’s blaming his nav or failing to respond correctly for driving through deep standing water getting off the Highway, vs pulling onto the shoulder. Be that as it may, he drove through this deep water (top of hood) that, after him, stranded a Ford F-150 and several other cars. At least he made it through the water bog!
    He managed to drive another 1.25KM, almost home, and “the car started shutting down in stages”, first the stereo, then the dash, then the whole car shut down.
    He managed to park it safely and called me at 11:30pm for help. The car seemed dead (12V) so we used a jumper pack and got it to try and start many times. Sounded like a really rough, misfiring rattling (heat shields) mess. We boosted from under the hood, (fuse box terminal) and at back of car.
    We took out the air filter and it was (really) water-logged. :-/
    No luck so we flatbedded it home (only 1KM!) and it sat in the driveway at -12 degrees Celsius 10.4 F and frozen. We finally installed the new AGM battery we bought 2 years ago, after fully charging it over night.
    Got a Green Ready Light (!) and was hopefull but one clunk sound (to me it seemed frozen or seized and then flashing green ready light and nothing. The flashing green ready has been the common theme here!
    Pushed car into garage with space heaters and model y set to 21 and “camp mode” and got temps up to 10 degrees or 50 F.
    Tried to start again after 26 hours, and got a rattlingly quick misfire then flashing ready light.
    Pulled the plugs before the start event thinking we’d blow the water out of cylinders but no such luck.
    Drained the oil and replaced with heated oil at 113 F thinking it couldn’t hurt to try but it didn’t help. There was a foamy film on the drained oil, but not a lot.
    Marked crankshaft pulley with sharpie, put a 19mm socket on an 18” breaker bar, and couldnt’t turn over the crankshaft even with the plugs out. Can the MG1 jamb the engine trying to start? Maybe engine is still frozen? I don’t know what to do other than give it more time to thaw out?
    other than the non-ready light, lots of clicking from HV battery area.
    The car is in excellent shape and only has 51k miles on it. We both really like the car and are afraid Toyota will write off the car and write us a cheque which we don’t want. He said he’d like to drive it another 10 years, and I don’t blame him. This little car has something about it we love, we don’t want to give up on it, can’t afford to replace it, but can put money into a repair if needed, but we’re just puzzled as to what’s going on.
    Lastly we tried Maintenance Mode. Tried to start for maybe .25 second and that was that. Nothing.
    Would really appreciate some real world feedback from anyone that has been through this and not just ChatGTP because that hasn’t helped us much.
    Thanks so much!
    P.S. I hope I’m in the right forum, sorry if I missed that
    #1 GasSavings, Dec 30, 2025 at 7:10 PM
  2. ASRDogman
    ASRDogman Senior Member
    7,626
    3,926
    May it rest in peace......
    Very likely you bent at least 1 rod because water was in the cylinders, and also the engine.
    At the very least, you probably need a new engine.
    But with all the water everywhere, eventually you have more electrical issue from corrosion....
    BiomedO1 likes this.
  3. frodoz737
    frodoz737 Top Wrench
    4,707
    2,508
    33
    Your Insurance Co. will likely total it.
  4. BiomedO1
    3,704
    1,920
    SacTown, Ca
    Yep; most likely hydro-locked, bent and/or broke something.
    You need to replace the engine - water does NOT compress like air.
  5. bisco
    52,021
    i think the service manual might cover flooded prius
  6. GasSavings
    Toronto
    I came here looking for troubleshooting techniques not sarcasm but I haven’t received much yet. Let’s see what tomorrow or the next day brings. In the meantime it’s thawing in the garage.
  7. ASRDogman
    7,626
    3,926
    :eek::eek::confused::confused:(n)(n)
    If you wanted someone to hold your hand and tell you all is okay and 10 hail dead woman's will make
    it all okay, you've certainly come place to the wrong place.
    Everyone is trying to tell you like it is, from experience.
    There are things that could be said about the incident, but I think we try to be nice....
  8. VelvetFoot
    VelvetFoot Active Member
    790
    288
    New York State
    2026 Prius
    My owners manual actually has something on flooding. I don't think very helpful though. This is for a GEN five.
  9. frodoz737
    4,707
    2,508
    33
    Have it towed to the Dealership and get it checked out. You might get lucky.
  10. BiomedO1
    3,704
    1,920
    SacTown, Ca
    If can't turn the crank shaft, how do you expect Mig1 to crank the engine?
  11. GasSavings
    Toronto
    Not at all, just looking for something else a DIYer can try before taking it to a mechanic.
