3D Printed Prius Gen 5 Custom Tray - Glasses Holder with Lid
Discussion in 'Gen 5 Prius Accessories and Modifications' started by priusasa, Nov 23, 2025.
  1. AgentPTFC
    AgentPTFC Member
    46
    29
    PNW
    2025 Prius Plug-in
    XSE Premium
    I would love to add this to my car. On my printer using PLA it estimates over 2 days of printing in the current orientation. Is it possible to provide a model that doesn't have the extra supports added? I'd like to print in a different orientation to see if it shortens that time and filament amount.
  2. priusasa
    priusasa Member
    83
    36
    2023 Prius
    I dont think there is faster than what I oriented. The file I shared on Makerworld, you can delete "cube" objects and leave actual object alone. That would save you just a little bir of time but, if you rotate the object and slice, you will see that it takes more time because it created new supports. Also if you change the oriantation of the object, you will see layer lines visible and it wont look good when the print is done.
    If you really speed up, you need to cut the object half and print 2 pieces. But I have not tried this.
    For me, it takes 13 hour to print. Even if I wanted to print pla, I could not make it less than 13 hour.
  3. Roberto Amador
    Roberto Amador New Member
    Long Beach
    2024 Prius
    Limited AWD-e
    Can you share the 3d print files?
