1. VelvetFoot
    VelvetFoot Active Member
    797
    289
    New York State
    2026 Prius
    It gets fairly cold in the winter here (east of Albany, NY). In fact, right now it's 2 degrees.
    I think gas is 10% ethanol year round here (except for high test, which is ethanol free).
    I'm wondering how much of a hit winter blend fuel has on fuel economy?
    I realize winter is not a good time for mpg's, regardless.
    The interwebs seem to indicate it is a factor.
    Thanks.
  2. Probity
    Probity New Member
    27
    Covington LA
    2026 Prius
    Hard to quantify just the fuel itself effect on winter driving in colder climes. As you’ve found from your interweb searches, lots of things working against us re: miles per gallon/liters per km (or km per liter) in the winter – the US winter blend fuel itself (higher Reid Vapor Pressure = more lighter fluid (butane) in it, overall lower density), higher air density with colder temps (more aerodynamic drag resistance), longer times getting engine temps up, more electrical loads from heated seats/defroster/etc.
    Somewhat surprising numbers on the outsized contribution of higher air density with colder ambient air temps to reduced fuel economy – it seems to be the biggest factor. And of course, highway driving vs. putting around town in sub-freezing temps, headwind vs. tailwind, etc.
    Fuel Economy in Cold Weather | Department of Energy
    Learn the facts: Cold weather effects on fuel efficiency
    Atmospheric Effects on Aerodynamic Drag
    Anecdotally @Hammersmith (N. Dakota) and @KMO (Finland) could probably share their observations on winter city vs. highway drives.
    VelvetFoot and Sharol like this.
  3. Sharol
    Sharol Member
    162
    76
    Kansas, USA
    2023 Prius
    That's the most complete explanation I've ever seen. Thank you.
  4. fuzzy1
    10,502
    Different regions get different seasonal blends, so there isn't a single answer your question.
    Around here, all the usual octane ratings are E10. Customers wanting E0 must go to specialty outlets, such as marinas.
    VelvetFoot likes this.
  5. VelvetFoot
    797
    289
    New York State
    2026 Prius
    Not to be picky, but the original post recognized that winter wasn't a good time for fuel economy and asked specifically about winter blend fuel.
  6. Prodigyplace
    12,574
    11,787
    Central Virginia
    Here in south central Virginia, our family has seen winter blend fuel lower fuel economy on all our Toyota Hybrids. i currently see it with my 2025 Camry.\ and previously, with my 2017 Prius.
    E10 vs E15 has a big impact too. I only buy gas from a station that specifies E10 (up to 10% ethanol).
  7. Trollbait
    12,547
    Winter blend in the US has an energy content about 3% lower than summer blend. An exact number depends on the specifics of the gas; octane, reformulated or not, ethanol content, etc, being compared.
  8. BiomedO1
    3,704
    1,923
    SacTown, Ca
    Another factor is denser air coupled with longer warm-up times and slick pavements. An ICE car usually got better mileage in the rain - NOT our hybrids - that's how sensitive they are environmental conditions.
  9. fuzzy1
    10,502
    My ICE Subaru gets better mpg on dry roads, not wet. The thicker the water film, the more the drag.
    Trollbait likes this.
  10. Leadfoot J. McCoalroller
    8,103
    7,586
    Pennsylvania
    2018 Prius c
    And everyone forgets to air-up their tires when the temps drop, so there's an extra mpg penalty hiding there.
    You can lose a surprising amount of mpg to underinflation before the pretty "low tire" lamp activates on the panel.
    Trollbait and BiomedO1 like this.
  11. BiomedO1
    3,704
    1,923
    SacTown, Ca
    Sorry, should've stated more specifically, 'pre-ECU' cars. That's why they sold those water injectors kits to eak out a few extra mpgs back in the day along with those 'tornado' air swirl thingy-a-bobs.:cool::D:LOL::ROFLMAO::whistle:
    I know my old late 70's, early 80's CIVIC got better mpg during the rainy season.
    #11 BiomedO1, Dec 30, 2025 at 3:58 PM
  12. VelvetFoot
    797
    289
    New York State
    2026 Prius
    My last tank was 53 so I guess I shouldn’t bitch. There was a 300 mile trip on the thruway at 65, which seemed to have dragged it down. But it’s been cold. Not Canada cold, but cold.
  13. AgentPTFC
    AgentPTFC Member
    46
    29
    PNW
    2025 Prius Plug-in
    XSE Premium
    Yeah, I swap out my summer air for winter air every year. To save money I save the summer air to swap back in at spring time.
  14. fuzzy1
    10,502
    I had suspicions of that back in that era, but lacked any form of sub-tank mpg measurements to meaningfully explore or confirm or refute it. Once the OBDII port era arrived, a ScanGauge-II showed it to be not true on my cars of this newer era.
  15. Trollbait
    12,547
    An era four decades past.
    Wetter air can improve the engine efficiency under higher loads, but water injection was more about power improvements. That's why it started in WWII aircraft. While those used methanol, it was for cylinder cooling like water. Auto injector kits needed an alcohol for antifreeze during the winter.
