My son drove his Prius into 2+ feet of standing water
Discussion in 'Gen 3 Prius Technical Discussion' started by GasSavings, Dec 30, 2025.
  1. GasSavings
    GasSavings Junior Member
    Toronto
    you’re probably right. I can’t turn the engine over with an 18” breaker bar and 19mm on crankshaft pulley bolt. I shifted into neutral, but Toyota told me to lift the front wheels off the ground and try it again. Wouldn’t N neutral do the same thing?
  2. VelvetFoot
    VelvetFoot Active Member
    1,077
    402
    New York State
    2026 Prius
    What if n isn’t working and engine and trans are stuck somehow? I think it sounds logical.
    Edit: That bulletin mentioned about not being able to shift out of park. It was an old bulletin, but what if it was really in park, again, somehow?
  3. bisco
    52,225
    how is that sarcasm? if it was, it was not intentional
  4. BiomedO1
    3,966
    2,091
    SacTown, Ca
    Yes; they are assuming the engine and transmission is locked together. That's a false assumption since there's plenty of 'play' between the two. Then again, it's been under water so circuits could be bridging/shorting across or relays may not be releasing.
    It isn't a manual transmission where the clutch is engaged and the transmission is in gear. Even then, the car would 'rock' back and forth - due to transmission gear reduction and slack in the differential.
  5. VelvetFoot
    1,077
    402
    New York State
    2026 Prius
    Hope springs eternal.
  6. ASRDogman
    ASRDogman Senior Member
    7,723
    3,960
    Contact your car insurance company and tell them what happened.
    They could tell you to tow it to a certain place and they will look at it and tell you what's happening
    with the engine.
    If it's going to cost more than a few thousand to fix it, they will total it, at was stated previously.
    Then take that money and try to find an older Corolla, non hybrid, in decent shape.
    And teach your kid about NOT driving in flooded roads...
  7. fuzzy1
    10,563
    There is no mechanical disconnect in the sense of a traditional car. All rotating parts stay connected. Neutral just de-powers the two motor-generators (MGs), which are de-powered anyway when the car is off, so no change there.
    MG2 is mechanically locked to the front wheels. In Park, these are locked by a parking pawl (with very significant slop or backlash), which is released in Neutral or other gears. But releasing that parking pawl takes some special electrical or mechanical attention to it, detailed in some long-ago thread. There is no mechanical link to the shift knob.
    But MG1 should freewheel, so should allow you to turn the crankshaft. Or at least not interfere.
    Lifting the car front wheels off the ground, while in Neutral (or anything but Park) should allow the wheels-MG2 combo to turn freely also. Only one MG, either one, is required to turn along with the engine. Preventing the engine from turning requires locking both MGs. But MG1 doesn't have a mechanical lock, it can only be 'locked' by motor controls forcibly commanding it to 'spin' at 0 rpm, which can't happen when those controls have no electric power. Unpowered, it should freewheel.
    So a locked crankshaft suggests a lock within the engine itself.
  8. Mendel Leisk
    41,781
    When replacing the head gasket it’s often necessary to put a wrench on the crankshaft end bolt, turn it. OP’s engine is likely seized.
