Prime 12v battery dead
Discussion in 'Gen 5 Prius Main Forum' started by dr_rock, Nov 30, 2025.
  1. Paul Gregory
    Paul Gregory Senior Member
    2,168
    573
    Alberta
    2024 Prius Prime
    XSE
    AI Overview:
    "Inflammable" means the same as "flammable"—it describes something that can be easily set on fire. Despite the prefix "in-" sometimes meaning "not" (like in "invisible"), in this case, it comes from the Latin "inflammare," which means "to set on fire" or "to put into flames"
    Prodigyplace likes this.
  2. notspam3
    notspam3 Junior Member
    60
    33
    Toronto
    2024 Prius Prime
    XSE Premium
    Since we need more confusion here is the Amazone description
    "NOCO GENIUS2: 2A 6V/12V Smart Battery Charger – Automatic Maintainer, Trickle Charger & Desulfator with Overcharge Protection & Temperature Compensation – for Lead-Acid & Lithium Batteries"
  3. Trollbait
    12,547
    Well maintainers are trickle chargers. They just have the means to not overcharge a full battery.
  4. rjparker
    10,198
    6,343
    Exactly. Search engine optimizer - use the terms someone is likely to use based on their age and expertise.
    These days any low cost charger has logic to prevent overcharging.
    Harbor Freight's under $10 charger is safe and often sells for less than $5.
    Only grandpa's rusted tool collection may have an unregulated charger - which in most cases won't impact an agm battery but is not great for vehicle ecus.
    The real killer is high parasitic draws allowing a full discharge of the 12v battery, often caused by aftermarket additions. Sometimes car manufacturers have code bugs causing high draws but even those are resolved if the owner gets the update.
  5. Gokhan
    Gokhan Senior Member
    6,259
    2,497
    Paramount CA
    It can say whatever it wants in the description, but Noco Genius is not a dumb trickle charger, which charges the battery indefinitely with a small current. It will stop charging altogether when it thinks the battery is fully charged. It will not restart charging until the battery SOC drops below a certain level (in about three days with Gen 4/Gen 5 Prius). The point was that you don’t want a dumb trickle charger that is always charging.
  6. Paul Gregory
    2,168
    573
    Alberta
    2024 Prius Prime
    XSE
    Right, Amazon is the ultimate source of correct descriptions.
  7. Paul Gregory
    2,168
    573
    Alberta
    2024 Prius Prime
    XSE
    "Trickle charger" is just what's most familiar to most buyers. The accuracy of the description is not a priority to whoever writes it.
  8. Paul Gregory
    2,168
    573
    Alberta
    2024 Prius Prime
    XSE
    I had a cheap battery maintainer in my Gen 3 Prius. It cost me $5 on clearance.
    It worked just fine for when my car was parked for more than a week. It had a constant 50 mA drain, which was good for about 9 days before the car wouldn't start.
    The reason I went with a NOCO on my Gen 5 was because I didn't have to open the hood to turn it on when I plugged it in.
  9. Probity
    Probity New Member
    27
    Covington LA
    2026 Prius
    Since this has gone far afield from OP’s question, I’ll add my 2 cents:
    I learned the difference (in Britain) between flammable/inflammable the hard way in the early 1980’s (before my company’s use of even MS Word 1.0 w/o spell-check). Did a study on a riser tensioner/motion compensator system explosion that occurred on a rig we were looking at contracting. These hydraulic systems use air-over-oil accumulators. In this incident, the hydraulic oil being used was combustible. There are also aqueous-based fluids with added lubricants that aren’t combustible. At the time, being young, American, and not understanding the real meaning of flammable/inflammable, in my typed-up report I repeatedly referenced the need for using a proper ‘inflammable’ hydraulic fluid. Luckily another English engineer proof-read it and told me “uhh, you’re saying silly stuff”. Looked it up, got embarrassed, lots of white-out later fixed it.
    From a U.K. HSE source:
    Inflammable: While the word may imply a non-flammable substance, it is a common misconception. Where a flammable object can be set fire to, requiring a source of ignition, an inflammable substance can catch fire all by itself and includes unstable chemicals like some types of compressed gas and explosive hazards. Due to its extreme volatility, it’s vital that inflammable substances are handled and stored correctly. While they may appear the same, the difference between flammable and inflammable substances is crucial to understand. Flammable substances can be set fire to (with a source of ignition), while inflammable can catch fire by themselves (without needing a source of ignition).
  10. Mendel Leisk
    41,558
    What have I done…:oops:
    Gokhan and Prodigyplace like this.
  11. ChapmanF
    18,259
    I also encountered something like that U.K. HSE definition @Probity supplied, years ago, but I think even that may be outmoded now, with the confusability of the two words leading the standards committees to prefer using other words to convey those distinctions.
    Probity and Mendel Leisk like this.
  12. Paul Gregory
    2,168
    573
    Alberta
    2024 Prius Prime
    XSE
    In all honesty, I can't think of a better way to refer to a bolt size.
  13. Brian1954
    Brian1954 Senior Member
    2,263
    896
    South Central PA, USA
    A bolt or screw is always designated by the outside diameter of the threads, not by the size of the head on the end of the screw or bolt. Just look at the website of any hardware store or do a quick AI search about the subject of screw size designation.
    The following, copied from a website, explains it well:
    Understanding Screw Specifications
    Imperial Screw Notation
    Imperial screws follow this format: Diameter - Threads Per Inch × Length
    Example: ¼-20 × 2" means:
    ¼ inch diameter
    20 threads per inch (coarse thread)
    2 inches long
    Metric Screw Notation
    Metric screws use: M(Diameter) × Pitch × Length
    Example: M6×1.0×30mm means:
    6mm diameter
    1.0mm thread pitch
    30mm long
    #53 Brian1954, Dec 31, 2025 at 3:23 PM
  14. Mendel Leisk
    41,558
    Well, that was another example. But yeah, if anyone mentions "trickle" charger, or coolant "flush", you're not obligated to correct them, doubly not, when the context makes it obvious. But if you have to you have to, I suppose.
    Ever watch South Main Auto? EVER heard him refer to a bolt by thread diameter? When your motivation is to find the right socket for the bolt, your priorities shift.
    #54 Mendel Leisk, Dec 31, 2025 at 6:40 PM
  15. Paul Gregory
    2,168
    573
    Alberta
    2024 Prius Prime
    XSE
    Each their own, I suppose. I refer to the 12 V terminal in the fuse box as a 10 mm nut. I can't imagine the thread size.
  16. Mendel Leisk
    41,558
    Uh, I then think that’s what we’re both advocating lol, at least I am.
    in other words: we agree. On something at least.
  17. Gokhan
    6,259
    2,497
    Paramount CA
    Someone asks what size that screw is, and you reply, “#2 Phillips.” To each their own, indeed. LOL
    Here is the bolt info from the OEM 1985 Toyota Corolla FWD repair manual. Do you see any wrench sizes? Sure, you need the correct wrench to install/remove the bolt, but the wrench size is irrelevant for torque spec.
    It is not to mention that there are many bolt diameter/thread sizes that could be associated with a given wrench size, just like all #2 Phillips screws with wildly differing sizes are associated with a #2 Phillips screwdriver. LOL
    #57 Gokhan, Jan 1, 2026 at 1:02 AM
  18. Paul Gregory
    2,168
    573
    Alberta
    2024 Prius Prime
    XSE
    Ya lost me, Mendel,
    not hard to do anymore.
