My 12V Battery is dying
Discussion in 'Gen 5 Prius Care, Maintenance and Troubleshooting' started by priusasa, Dec 13, 2025.
  1. BiomedO1
    3,716
    1,927
    SacTown, Ca
    According to the Napa website that's a 70Ah battery; whereas Toyota specifies 45Ah minimum. So not sure what your asking? Does it not strap-down properly?
    https://www.napaonline.com/en/p/BAT7548
  2. priusasa
    priusasa Member
    83
    36
    2023 Prius
    So my battery group size is LN3 as you can see
    But manual says "Use a battery that the case size is same as previous one (LN1)
    So, this car is Toyota Certified and I think they should have used the correct battery type at least. When I research more information about it, it should not able to fit there but its there. Interesting.
  3. Mendel Leisk
    41,561
    Are the dimensions roughly the same, the fiddly-design Toyota hold-down bracket fits (maybe with a washer or two)? It meets or exceeds electrical spec's? Then it's "correct".
  4. priusasa
    priusasa Member
    83
    36
    2023 Prius
    I am not sure how they fit it there, but other features exceeds since LN3 actually is bigger battery. So according to manual, its the only "size" is wrong.
    When I first realized that, which is today, I though that they are completely diffrent and you should not use different group type. But it was actually just a dimention thing.
  5. BiomedO1
    3,716
    1,927
    SacTown, Ca
    It does exceed OEM specifications; so the real questions is: does it strap-down and vent properly in it's OEM position? The 2023 Prius battery got moved back into the trunk; correct? If that battery is under the hood, you can forget about item #2.
    1. If it isn't properly strapped-down; it can rock around, loosen and/or break connections.
    2. It needs to vent properly, since it's technically located in the cabin. There should be a vent hose connected to the battery so it can vent hydrogen out of that compartment (by-product of charging) - explosive hazard.
    If that battery doesn't meet either of the above criteria, you've got a very good claim against the dealership for something that will actually meet both those criteria. That would make it a consumer protection and safety issue claim.
    Good Luck.......
    #65 BiomedO1, Dec 31, 2025 at 3:54 PM
  6. CooCooCaChoo
    CooCooCaChoo Senior Member
    958
    535
    Cow-lee-fornia
    2023 Prius
    Yeah, OEMs are Panasonic or some other Japanese brand, not Napa. You could hassle them to replace it, but most likely they won't budge because it's working and not defective.
  7. Mendel Leisk
    41,561
    FWIW, the Toyota designed battery hold-down bracket is incredibly intolerant of any variation in battery height. Just a mm or two, and the damn thing is rocking, requiring washer(s) under the bracket, or shims under the battery. Not sure why they had to be clever, the usual hold-down bracket style has long rods with a hook at the bottom that hooks down there, and generous thread length at the top, that a washer and nut have at least an inch travel.
    #67 Mendel Leisk, Dec 31, 2025 at 6:52 PM
    VelvetFoot likes this.
  8. VelvetFoot
    VelvetFoot Active Member
    801
    289
    New York State
    2026 Prius
    I went to this site, the first hit in a search, and observed that the only difference between L1 and L3, dimensionally is the length. L1 is 207mm and L3 is 274mm. I went out to the garage and measured. 274mm MIGHT be able to be squeezed in there. (I have my NOCO trickle charger (I did that on purpose) in there. I have no idea what the bottom tray looks like and what they may have done to it to make it fit though. Perhaps someone else knows.
    Did you take the battery out? It looks that way.
    edit: On the other hand, whatever they did, you can fit a higher capacity battery in there now. I'm on shaky ground, but it looks like it's a maintenance free battery and the NAPA site says it's a flooded wet battery, so does it still need that drain tube?
    edit2: I came up with this for the battery carrier. No idea if I'm correct. Perhaps one could just bend the right lip so it's flat. Still, would be very tight based on my measurements.
    #68 VelvetFoot, Jan 1, 2026 at 8:43 AM
