Should I replace my 2yr old TPMS when changing tires?
Discussion in 'Gen 3 Prius Main Forum' started by Somu, Dec 31, 2025 at 7:45 AM.
  1. Somu
    Somu New Member
    am getting new tires on my 2013 Prius (225/45R17) to replace my current tires. I had the TPMS changed on them in Jan 2024. They have about 15K miles on them since that time. Do I need to get new TPMS sensors when I am getting these changed, or should I ask them to try and reuse the existing ones? New OEM ones appear to run 80-100 per tire, so am debating on the cost... what is the general recommendation, and are there acceptable non-OEM versions that are considerably cheaper? getting these replaced at my local BJs, if that matters...
    Thanks,
  2. JC91006
    JC91006 Senior Member
    16,776
    8,573
    The OEM Toyota TPMS will last you 10 years, however if you bought aftermarket ones from China, they will probably not last very long.
  3. BiomedO1
    3,713
    1,927
    SacTown, Ca
    Some cheap aftermarket will only last a few years, so the real question is the quality of the ones that was last installed.
    My expectation is at least 5-8 years out of a good quality sensor. That's also what I would expect from good quality tires too.
    Brian1954 likes this.
  4. priumium
    priumium Member
    266
    67
    Sweden
    2013 Prius Plug-in
    Never replace any TPMs unless there is a warning light, is my recommendation.
    It’s a big waste of monetary funds, especially if you are on OE.
    FYI for DIY engagement; it’s actually fairly easy to replace TPMs yourself - without any special tools.
    #4 priumium, Jan 1, 2026 at 10:08 AM
    ForestBeekeeper likes this.
  5. frodoz737
    frodoz737 Top Wrench
    4,709
    2,512
    33
    Short answer....no.
    Brian1954 and ForestBeekeeper like this.
  6. Mendel Leisk
    41,559
    Longer answer: Good Lord, no.
    I’m in Canada, where (as far as I know) TPMS is not mandatory, so maybe that colours my opinion, but I would wait till they die, and then “consider” getting them replaced, the next time new tires are needed.
    for what it’s worth: our ‘10’s still got functional, from-the-factory sensors.
  7. ForestBeekeeper
    ForestBeekeeper Active Member
    774
    306
    Maine
    I drive a 2011 and a 2017, both have the original units in the tires.
    I see no need to replace them.
  8. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,473
    2,437
    Taylors, SC
    I found TPMS systems to be useless, if you have a blowout. The flap-flap sound of the totally flat tire will warn you at the same time as any TPMS light on the dash.
    If you check the tires every month, you'll never need. Othe past 14 years that my TPMS was working, it only came on with the onset I f cold weather.
    I recently had a blowout and got new tires and the TPMS light came on. The tire shop asked me if I b wanted the TPMS sensors replaced. I said no.
    The TPMS light now stayed on.
    Instead replacing them, I turned off the light. ON Gen 3 P, just jumper positions 5 and 6 on the back of the connector block as shown in this photo.
  9. Mendel Leisk
    41,559
    Or just live with the light? There's typically one or two others on, say passenger seat air bag status; it can keep them company. I'm just averse to doing fundamental mod's, particularly ones I might forget the how-or-why, with another decade. :)
  10. JC91006
    16,776
    8,573
    There is a cheaper way to refurbish your original TPMS from Toyota. I have a friend that buys the original Panasonic batteries from online sources for about $4 each. Uses liquid silicone to seal them after they have been replaced, looks original when done and should last another 10 years since the batteries are the same Panasonic ones from OEM. Big savings compared to buying new ones from Toyota at $80 to $100 each
    Most people won't check their air in their tires regularly, just like they don't check the engine oil levels. So this TPMS is a good warning for most people when their tire is low on air.
