Featured Empty Tank Not Empty?
Discussion in 'Gen 4 Prius Fuel Economy' started by PriusPeep, Nov 23, 2024.
  1. PriusPeep
    PriusPeep Member
    122
    78
    New Jersey
    My 2017 Prius has a gas tank with an 11.3 gallon capacity, according to Toyota specs.
    Multiple times over the years I have waited until I have zero bars on the fuel indicator. I want to learn the single-tank range of my Prius and compare the impact of the weather/temperature.
    When I fill up I always get about 9.5 gallons. I have never filled up and reached 10 gallons on the gas pump display.
    Does Toyota purposely set the fuel tank gauge to display empty when there are actually more than 1.5 gallons remaining? That means you can drive about 75 miles after Prius is “empty.”
    Is it a safety precaution and/or a law?
  2. ColoradoBoo
    ColoradoBoo Senior Member
    1,241
    835
    Monument, Colorado USA
    Yes, I think Toyota does leave about a 2-gallon buffer on their tanks.
    But be careful letting your tank get low, especially in the winter. Water rises to the top when it's in gasoline. So if you use up the gasoline any water will then be inside the small gas line and what does water do when it's cold? It freezes and then your car is not going anywhere.
    This happened to me here in Colorado a while ago when we were having a bellow-zero spell. Now, I never EVER let the tank get below 1/4 in the winter.
    Christina Norris likes this.
  3. PriusPeep
    PriusPeep Member
    122
    78
    New Jersey
    Great practical tip.
  4. Trollbait
    12,547
    Don't think it's law, but is a safety precaution. Most manufacturers have the low fuel light come on when there is a gallon or so in the tank. So E is never fully empty. Then variations in the pump shut off switch, sloshing of the fuel while going in, and angle of the car when filling could lead to getting a short fill at times. Plus the listed volume counts the low point where the pump sits, and that only gets drained when fuel emptied until stalling.
    With E10 you don't need to worry about freezing fuel. Ethanol is an antifreeze, and keeps any water mixed with the gasoline. As long as excess water doesn't get into the tank. Note water is heavier than gasoline, but the fuel pump draws from the bottom of the tank.
    ETC(SS) and Fubar XIII like this.
  5. hill
    8,826
    E10 tends to turn to Varnish faster than alcohol-free fuel. Also (& biggest concern we have is) where a partly empty tank allows for condensation to form. Then you have another issue to deal with.
  6. bisco
    52,027
    why are we in the news forum?
  7. PriusPeep
    PriusPeep Member
    122
    78
    New Jersey
    After I posted I realized that I probably should have chosen another category. If possible, please move the discussion.
  8. Mendel Leisk
    41,561
    You can use the "Report" button below your initial post, ask the moderator.
  9. PriusPeep
    PriusPeep Member
    122
    78
    New Jersey
    Thank you. I made the request.
  10. hill
    8,826
    I'd give $100 to 1 odds the request will be much much faster than a request from the Prius chat store
  11. Fubar XIII
    Fubar XIII Member
    63
    Metro Detroit
    SAY WHAT?!?!?!?
    Hate to break it to you, Boo, but water is heavier than gasoline and sinks to the bottom, it does NOT float on the gas, regardless of temperature.
    I spent 8 years in the petroleum industry, tested fuel repeatedly for water. We always put the water test paste at the bottom. And on tanks with a sight glass (clear tube used to check level) the water is visibly different in color and always at the bottom. Makes it easy to drain, at least.
    The main reason to keep a tank full(er) in the winter is to keep out the humid air which will then allow the moisture to condense out of it when the temperature drops and allow it to accumulate in the tank over time. If it happens long/often enough, it will build up until the fuel pump starts picking it up. Then things get bad.
  12. Fubar XIII
    Fubar XIII Member
    63
    Metro Detroit
    I've seen docs that say you can only fill a fuel tank to 85% of its AIR capacity to allow the fuel to expand now that it is out of the cold underground tank. That is a federal requirement.
    As far as filling the thing, I've never gotten more than 9.5 gallons (US) into it, either. That time I had 25 miles of range showing, about 1/2 gallon left. My manual said the capacity is 11 gallons. I think it's just 10.
  13. Trollbait
    12,547
    Then with most filling with E10, the water only becomes an issue when there is an inordinary amount of it.
  14. BiomedO1
    3,713
    1,927
    SacTown, Ca
    Automotive fuel systems for the past two decades or more, has been pretty much closed loop systems. Any significant contaminates making it into your fuel tank was most likely pumped-in at a gas station. Water contamination isn't going to be an issue as your moving down the road; it's being thoroughly mixed-in as your bouncing down the road. Morning startup is another story, as your fuel settles out and separates.
    YMMV...
    FWIW: I've been able to pump 10-10.25 gallons into my tank, a few times - but I've been running zero bars for a while. You need to know your car and conditions your driving in, since the mpg varies widely based on environmental operating conditions.
  15. Fubar XIII
    Fubar XIII Member
    63
    Metro Detroit
    Something relevant I forgot:
    Gas stations have filters on their supply lines. For dirt, water and other contaminants since those honking big underground tanks are impossible to get to once buried. The odds of you getting any water into your tank directly from a gas station is negligible, especially if they follow the rules on filter replacements/maintenance. Now if the owner is a cheap, lazy bastard......
    The only realistic way to get water in the tank is through accumulation of condensation.
    For what it's worth: I don't really think it's all that temperature dependent, tho. The air needs to be very humid - like in Florida for example - then when the temp drops at night, the relative humidity rises to 100%, it condenses and accumulates. But in the 35 years I lived there, I never heard of a single proven example of water in the tank. (The E10 may help disperse it, I don't know.) Every time I heard of a "gas" problem it was always something other than the gas: bad pump, line issues, etc.
    My $0.02
  16. Iron Man Prius
    138
    25
    Three Touring
    I had 55 miles to empty, filled up and only was able to put 9.5 gallons as well. (The yellow gas level was touching the first white line on the empty side of the gauge for reference). 11.3 is still possible based on the miles travelled on that tank but I don't want to chance it. 11 gallons is completely bone dry I'd imagine.
  17. Billy56
    Billy56 Member
    75
    71
    Seattle, WA
    2020 Prius
    L Eco
    Fuel tank capacity is my primary complaint in my 2020 Prius L Eco. Many times I have driven about 25 miles AFTER driving range says ZERO. Most I could fill was 9.8 gallons. Very disturbing to me. Years ago on my Honda Insights, I would take a gallon can of gas with me and drive until the engine slightly sputtered, then quickly turn off engine, coast to side of road and put in gas. This way I accurately determined how far I can drive on empty. I have NOT yet done this in my Prius. I think somebody on this forum did this ????
  18. Mendel Leisk
    41,561
    Maybe work on that, lol.
    A good exercise: picture the voluminous gas tank, with a mere gallon (say one of those ice cream pails) of gas, sloshing around in the crevices, stirring up sediment.
  19. BiomedO1
    3,713
    1,927
    SacTown, Ca
    You can pretty much safely get at least 50 additional miles when your MTE hits zero. It may lockup your odometer and just display low fuel, after a few miles - not sure how your cluster is programmed. I know some of my rigs did that, so even if you pulled up google maps to the nearest gas station - you won't know if you can make it, because you no longer have a mileage counter.
    Hey; you can always ride with a gallon of gas in your back seat again. I'm just too old and particular to do something like that. Heck, I don't like getting a can of gas for my lawn mower - too smelly.
    Just my two cents.
  20. Robert21PrimeLTD
    84
    42
    Nashville
    How does all this square up with stale gas for our plug-in owners? This forum has suggested not filling up to avoid stale gas. Since purchased (used & 2 year old) I have only filled the tank twice because on long trips and only added 8.5 gallons max. The manual says that I have a 11.4 gallon tank. I keep the tank at 1/4 to 1/2 full and in the garage when not in use. The Nashville area does get very hot & humid in the summer and sometimes below freezing in the winter.
    As an aside, I never want to run out of gas.
