200,000 Mile Club
Discussion in 'Gen 2 Prius Main Forum' started by usbseawolf2000, Jan 3, 2009.
  1. 200Volts
    200Volts Member
    439
    46
    Northern CA
    2012 Prius V model 5 is now at 254,000 miles. Lifetime mpg 43.2
    No major maintenance. Just replaced the PCV - almost eliminated the low speed/light throttle knocking.
    Mobil 1 oil, K&N air filter.
    My personal Prius total mileage is now 135 + 399 + 254 = 788,000 miles.
    djasonw and srellim234 like this.
  2. naptaro
    naptaro Junior Member
    nyc
    205,000 Mile 2004 Prius Here!
    My dear Blue (She/Her) spent the first 13 years and 150,000 miles in Maryland garage kept and dealer maintained.
    Then she spent 4 years in San Francisco street parked.
    The last 3 years in New York City street parked.
    The last 7 years 100% of the maintenance and repairs were done by me, in the street and occasionally underneath an overpass.
    1) Did you replace the HV battery pack?
    Yes, at 170,000 miles I got the red triangle of death. I then tried to condition the battery, which turned out to be a terrible idea because the battery had already failed. I managed to explode the entire battery, black smoke and everything. I feared I totaled the entire car. Then I dropped in a battery that some guy from Baltimore sold me, and she was back on the road immediately. A true marvel, it's as if the engineers knew someone would do ill-advised things to the [then] highly experimental battery and packed it with electrical safeguards. It's been 30,000 miles and she's running fine.
    2) Did you replace the 12v lead-acid battery?
    Yes, twice always with Toyoa OEM 12v.
    3) Did you replace the hybrid transaxle fluid?
    Yes, first time at 80,000 miles, Second time at 180,000 miles.
    4) Did you replace the brake pads?
    Yes, at 100,000 miles, and currently still have 6mm left. This car appears to heal itself.
    Incredible considering I also spent 4 years in San Francisco with unreasonable hills and braking demands.
    5) Your lifetime MPG (if available)?
    47mpg in summer with AC Auto function on
    35mpg in dead of winter (New York City), if I drive in the suburbs I still get 42mpg in the dead of winter.
    6) How often do you change your oil? What brand / product did you use?
    Every 3-5,000 miles, I've used the cheapest 5W-30 Full Synthetic I could find.
    Since she hit 200,000 she was making a slight knocking sound at cold start and only in the dead of winter. I switched to whatever the cheapest 0W-20, a thinner oil that was default for the same prius in Japan since 2004 [I read the manual in Japanese]. She doesn't make that sound anymore. It's only been a few thousand miles but she isn't burning oil yet with the thinner oil.
    I use toyota filters or aftermarket denso filters.
    The best advice I got on this matter is that it's more important to do it at 3000 miles than to buy expensive filters and oil.
    7) How about post a picture of 200,000 miles on ODO?
    I would upload if I knew how to do it on this website.
    Additional Repairs and Maintenance
    1) I hit a deer once and had to replace the front hood. I went to a scrap place to get the parts and did it myself. Spent about 400$. Super simple super light parts. Fun fact the hood and the entire front bumper fits inside the same prius.
    2) Catalytic Converter was stolen in San Francisco (a badge of honor). Serendipitously I shipped the car back to the east coast because I was moving back. I installed an aftermarket magnaflow for 400$ by myself. She has had zero codes for 30,000 miles now. I don't think the Toyota OEM Cat was worth it since it costs more than the car.
    3) I went without AC for many years, the deer accident started a slow leak. I finally replaced the condenser myself for under $100 Toyota OEM. I had the AC gas recharged at Toyota. She's still leaking but works fine.
    4) I spent about 2 years with the engine light on because of a three way control valve malfunction. Drove fine, no hit to MPG either. I finally replaced the 3 way control valve myself. I made the mistake of using aftermarket. It failed in under 1000 miles lesson learned. I got a Toyota OEM part and replaced it. That was 3 years ago and no engine code since.
    Draining and refilling the coolant is tedious. I tried using vacuum pumps but ultimately, I did it the old fashioned way and had the ICE run continuously in maintenance mode and burped all the bubbles out.
    5) I replaced the front passenger side wheel bearing myself. Getting the bearing out of the knuckle took me many days and many experiments. If I were to do it again I would have a mechanic press out the bearing and put in the new one. Or just buy a new knuckle. The bearing has been fine, it's a Toyo aftermarket part.
    6) At 200,0000 miles I switched out the spark plugs and the coil boots. denso plugs and NGK boots. It didn't need it, I just wanted the peace of mind.
    7) At 200,000 miles I cleaned the EGR.
    8) Have been using Bridgestone Ecopia tires from Costco for about 30,0000 miles. They're fine, try not to think to deep about this as long as it's low rolling resistance.
    I learned everything I know about cars with this car and fully plan on driving to 300,000 miles.
    I want to replace all 4 struts because its just time, not because of safety.
    Maybe put in an entertainment system if I feel like killing some time.
    I have another one, a 2009 prius gen 2 100k miles. She had a front bearing issue and uneven braking issue. Otherwise she is still on the original HV battery. IMG_0773.jpeg
    Frankusa94, Fred_H and djasonw like this.
  3. Stu9
    Stu9 Junior Member
    84
    Near Mearns
    In my newly acquired gen2 it is 202000 it needs an hv battery though as the ev range is bad ie half a mile off that.
    I may attempt to clean the fan later though just for the hell of it.
    For a laugh I phoned Toyota the other day to price one...£3255 (uk). There is a localish guy does recons at £1100 for the gen 2 with I think a 3 year warranty.
    But yes I am at 202000 miles.
  4. dolj
    dolj Senior Member
    8,499
    4,313
    Wellington, New Zealand
    I hope that price is for supplied and fitted, but yeah, that takes your breath away.
    Do they take back your old battery and give you a core refund of any kind?
    I think you misunderstand.
    A Prius is a hybrid, not an EV. It is not designed to go any significant distance on the battery alone. Many variables dictate whether the engine comes on or not.
    [EDIT] You might want to update your profile with your correct Gen 2 model year.
    #804 dolj, Mar 23, 2025
  5. Stu9
    Stu9 Junior Member
    84
    Near Mearns
    Sorry yes that is right, I guess when I read that you seemingly can get around 12 miles with a good battery I though I would try it. But being in a 20 year old car with 200000 the battery has seen better days.
    Yes it is not really designed to be an ev I forgot that. I think when I saw the ev button I though just for a laugh I will see how far it gets.
  6. dolj
    dolj Senior Member
    8,499
    4,313
    I don't know if you could ever get 12 miles in EV. If you force EV mode with the EV button, you might get 3 miles if you keep the speed under 26 MPH (real speed, not what the speedo reports, which in the UK is likely overstated by 10%).
    Some good uses for the EV button are to stop the engine starting when it first goes READY (you have 7 seconds) so that you can move the car around on your drive or in and out of the garage. Another is manoeuvering in a semi-enclosed space like a car parking building or an underground carpark at a shopping centre or a supermarket, for example. There are probably a few others I'm forgetting, but generally, you are doing short manoeuvers at a slow speed and infrequently.
  7. Stu9
    Stu9 Junior Member
    84
    Near Mearns
    I know, why I tried it I am lucky if I got around 500ft.
  8. JoeB
    JoeB Junior Member
    17
    Rockaway NJ
    2009 Prius, powder blue
    1) Did you replace the HV battery pack? Yes, twice. Once was greenbean, which lasted about 35,000 miles. The second was from a national chain with a shop that was 7 miles from work. I got the 1 year warrenty pack on their suggestion, and it has been doing well for 5000 miles so far.
    2) Did you replace the 12v lead-acid battery? Yes, twice.
    3) Did you replace the hybrid transaxle fluid? Yes, once, at 185,000 miles.
    4) Did you replace the brake pads? No, originals still are on the car.
    5) Your lifetime MPG (if available)? 225,000 miles.
    6) How often do you change your oil? What brand / product did you use? Every 5,000 miles. Generic synthetic 5W-30.
  9. Car diagnostic donations
    Usa, northeaster
    I have my little prea a gen 2. 2nd owner. Bought @ 170k a couple years back. Now has 200k+ Very minimal rust on undercarriage for her age and being a northern car her whole life. I plan on keeping this little old gal until the end. Recently, just have done a good amount of front end work. Getting ready her for the 300k mark. Struts, sway bar links, wheel bearings. Soon c/v joint flush radiator, change transaxle fluid. She now has a few other issues I'm working through. Like center dash lcd display short or failed. Getting a junkyard one for 145.00 and warranty for 30 days. Also, inverter coolant pump fail. So will be changing that and or flushing that system as well. I will keep this page posted! Love these little cars! Long live prea! I have been using 75k+ high mileage synthetic blend 5w 30. Have lots of plans for her lasting past 300k+ I am a firm believer in Toyotas 4-cylinder motors as throughout the years have owned a 86 truck standard 4cyl a 87 same, and 93 same. Sold the 86 to a friend @ 600k he put 200k on original motor and drivetrain and I bought back @ 800k then sold again. I'm positive this truck surpassed 1 million miles on original motor and drivetrain. Just normal ware and tare parts. Clutch, brakes fluids, alternator etc. I later also owned a little 93 Corolla 4cyl that had 180k+ and ran better than my newer Dodge Magnum lol. Sold for same amount I bought it for and got tens of thousands out of it virtually maintenance free. Love my YOTA 4 cylinders can't speak for any of the rest personally.
    #809 Car diagnostic donations, May 9, 2025
  10. asjoseph
    asjoseph Samuel, '04 Ruthiemobile
    97
    34
    117
    lancaster, california
    ... cresting 205k on the clock. Still, unless I refuel out of state? Pumping California unleaded, can't manage beyond 37 mph. Pretty much the same fuel consumption on the rebuild. Off the showroom floor, to 195k, my Gen II was always an oil burner. After the rebuild, engine's so much tighter. Runs a whole lot better, too -
  11. zoooch
    zoooch New Member
    new england
    2007 Prius 211,000 miles
    no
    yes
    left it at the dealer tonight for this
    yes
    45.2
    every 5k like clockwork, highest premium synthetic available
    I will!
  12. Zeppo Shanski
    Zeppo Shanski Active Member
    304
    160
    Chicagoland
    2005 G2: white, plain and ordinary, bought used from dealer, 1 previous owner, 5-stacks OTD.
    1) Did you replace the HV battery pack? Do you maintain it?
    YES, just this spring. $1,650 OTD, changed in my driveway.
    2) Did you replace the 12v battery?
    YES, a coupla 3-years ago.
    3) Did you replace the transaxle fluid? How often?
    NO.
    NO.
    Currently 60-mpg. When bought +/- 42-ish-mpg.
    Regularly +/- 3,000-laps.
    Does your Prius consume oil?
    NO.
    On sale premium brand 0-20 synthetic, Lucas Oil Stabilizer, Rislone, Hy-Per Lube, Wix or Purolator filter.
    7) How about posting a picture of 200,000 miles on ODO?
    8) Did you install an oil catch can? How often do you inspect or dump it?
    NO.
    9) Have you cleaned the egr circuit? How frequently?
    YES, this spring when swapping out the big battery.
    10) Any other maintenance?
    New tires June, 2020, replaced air/cabin filters w/ every oil change, changed plugs twice since purchase at +/- 140,000-laps, front wheel bearings somewhere past 180,000-laps.
    #812 Zeppo Shanski, Dec 22, 2025
  13. Classic Car Guy
    Classic Car Guy Active Member
    459
    126
    Northwest, USA
    Hi there,
    Well my car is 175k nearing 200.
    What oil do you guys use on a Gen 2 with 175k living in Pacific NorthWest area which is 30-52 deg on winter?
    Thanks,
