Update battery thread: is the Optima Yellow Top still the preferred choice?
Discussion in 'Gen 3 Prius Main Forum' started by Johnny Cakes, Dec 16, 2025.
  1. priumium
    priumium Member
    312
    76
    Sweden
    2013 Prius Plug-in
    This makes it obvious to me this company failed to comply with specs, as OE now seem to be Yuasa AGM.
  2. VelvetFoot
    VelvetFoot Active Member
    842
    301
    New York State
    2026 Prius
    For a Gen 5? Not in my '26, lol. Flooded.
    priumium and Prodigyplace like this.
  3. priumium
    priumium Member
    312
    76
    Sweden
    2013 Prius Plug-in
    Ah, but this is a G3 forum, that’s my reference. It’s the same form factor for G2 and G3. I have so far no other relevant experience.
    An interesting possible reason for placing the battery in the trunk is that small Ah batteries do not cope well with extreme temperature changes, as is the case when placed in the engine bay (engine is hooooot).
  4. VelvetFoot
    842
    301
    New York State
    2026 Prius
    doubtful. space, maybe weight. I had a BMW once, a 3 series coupe, I believe, with the battery in the trunk.
  5. Prodigyplace
    12,593
    11,791
    Central Virginia
    Are you saying you see problems with the Gen 4 battery under the hood? There was no unusual problem for a flooded battery when I had mine.
  6. priumium
    priumium Member
    312
    76
    Sweden
    2013 Prius Plug-in
    There are so many considerations when placing components for production as an engineer. 12V batteries are still using lead/acid. That tech is from 1920. Extreme heat or cold are equally bad.
    The engine bay on G2 and G3 could easily handle this form factor if this would have been prioritized. Many cars, including Volvo S80 2001 placed 12V in the trunk.
  7. priumium
    priumium Member
    312
    76
    Sweden
    2013 Prius Plug-in
    Not at all, just curious/talkative about general engineering decisions. The heat from the engine is actually good for 12V health in my climate, but not so much in other climates.
    Prodigyplace likes this.
  8. priumium
    priumium Member
    312
    76
    Sweden
    2013 Prius Plug-in
    I was not aware they moved this, I have only G2 and G3.
    This info actually makes me a little bit more inclined to also get a G4. ;)
    Any odd/special issues to look for, according to your experience @Prodigyplace (or any other G4 DIY reading this)?
  9. Prodigyplace
    12,593
    11,791
    Central Virginia
    My OEM battery lasted about as could be expected for a flooded battery. I notice my 2025 Camry had a flooded maintenance-free battery in the trunk area. There is a jump start point under the hood though.
    When I took my 2017 in for the first check in late 2016, the tech supposedly did not check the battery because "Prius us different" even though the battery had been under the hood for over a year by that time.That is one of many reasons why I do not trust my local dealership. I drove over 2 hours to a good one to have the wiring harness recall performed.
    priumium likes this.
  10. VelvetFoot
    842
    301
    New York State
    2026 Prius
    So, there's no tube leading to the outside?
  11. Prodigyplace
    12,593
    11,791
    Central Virginia
    I just checked. It is vented, likely because the rear seats fold down, making it part of the cabin area. See the rectangle below
  12. priumium
    priumium Member
    312
    76
    Sweden
    2013 Prius Plug-in
    You would need an awful lot of abnormal hydrogen release from the battery to even consider this being an issue, wherever the battery is placed.
    With a SMF battery, I find it rather funny they have a vent.
  13. VelvetFoot
    842
    301
    New York State
    2026 Prius
    Interesting. The battery on my Gen5 Prius is LN1 size. There was a recent thread where a LN3 was stuffed in there. Haven't heard back from the original poster on that yet.
  14. Prodigyplace
    12,593
    11,791
    Central Virginia
    It DOES make me wonder how plentiful a replacement will be.
  15. priumium
    priumium Member
    312
    76
    Sweden
    2013 Prius Plug-in
    (I just assume with full prejudice, that the concept of caring about this issue is based on fearbased regulation rather than science.
  16. Prodigyplace
    12,593
    11,791
    Central Virginia
    The Camry has a larger engine. Mine is the XLE with a lot of options too.
  17. priumium
    priumium Member
    312
    76
    Sweden
    2013 Prius Plug-in
    Plentiful? As in..?
    That vent seem to comply with some outdated regulation. Very few SMF/flooded batteries and even fever agm have this concept.
  18. priumium
    priumium Member
    312
    76
    Sweden
    2013 Prius Plug-in
    Never heard about LNx…. Please link source.
    Where is ISO / EU regulation when any battery can be any dimensions? Who benefits from this?
    It’s just such a waste of resources, and in my mind this is what happens when you let companies create their own standards.. CHAOS for everyone,
  19. Prodigyplace
    12,593
    11,791
    Central Virginia
    So it will likely be difficulty to find a replacement with a vent when a replacement is needed.
