PHEV specific topic: oil change based on time ONLY
Discussion in 'Gen 5 Prius Care, Maintenance and Troubleshooting' started by Templeton, Dec 30, 2025.
  1. Templeton
    Templeton Active Member
    321
    114
    usa
    2024 Prius Prime
    SE
    I know there have been lots of oil change threads, but I was curious to get people's opinions on a specific aspect of oil changes for prius PHEVs (primes).
    I just heard an interesting podcast episode about the time (not the mileage) between oil changes. So, whatever you might choose to follow (toyota mileage recommendations, or more often), with the prius prime ICE not running much if you drive a lot on EV mode, after the warranty period has passed (where you might, for legal reasons, need to follow factory directions exactly), what are your thoughts about the opinions in this podcast from blackstone labs?
    tldr: These guys say that modern synthetic oils, even after being opened and sitting in a crankcase, can last for a long, long chronological time (this podcast focuses only on chronological time between changes, not on the miles driven between changes). And that most folks in most cases don't need to worry about time between changes, they should more focus on the miles (and the type of miles) between changes.
    Just curious what most prius PHEV owners on here think about this, since many of us drive a lot on EV mode, sometimes more than in HV mode. Audio episode here:
    105: No Time To Change - Slick Talk: Powered By Blackstone Laboratories - Apple Podcasts
    #1 Templeton, Dec 30, 2025
  2. VelvetFoot
    VelvetFoot Active Member
    1,161
    459
    New York State
    2026 Prius
    Not a PHEV owner, and didn't watch the video, but most equipment has hour meters, no?
    Too bad this couldn't be accessed via software, or even miles with engine running-you'd think it should be kept track of by the car.
    I suppose you could install an hour meter.
  3. Templeton
    321
    114
    usa
    2024 Prius Prime
    SE
    No huge need for an hour meter, as there are easy ways to keeping track of miles driven in HV mode (in a prius PHEV).
    But some people insist that oil goes bad just based just on time alone, and that is what I was interested to get opinions on. Especially since the blackstone folks seem to provide info that indicates otherwise.
    VelvetFoot and bisco like this.
  4. bisco
    52,331
    if i had known this when i owned a pip, i would have changed the oil twice in eleven years, instead of every year.
    that would have been a $1,000. savings
    PrimeDan and VelvetFoot like this.
  5. Templeton
    321
    114
    usa
    2024 Prius Prime
    SE
    Plus a good number of needless hours doing the oil changes, if you DIY them.
  6. Trollbait
    12,661
    Oil goes bad from oxidation. At room temperatures, that reaction is very slow, and even stops if cold enough. Then in a sealed bottle, the available oxygen is used up and oxidation stops.
    So oil can last some time in a non-running engine. But we also need to account for climate along with time. The engine isn't sealed, and warm/cool cycles will lead to fresh air getting into the crankcase with more available oxygen. It also can bring in humidity that adds water as an oxidation source.
    In the case of a PHEV, the engine use cycle needs to be considered. If only running for a short time when it comes on, that is the same as a short trip in an ICE car. This is severe use on the oil, as there is more water and even fuel sitting in the oil for long periods before being boiled off.
    Toyota's oil change schedule is too short for PHEVs; its what they use for ICE cars. Would be great if they, and everyone else, used a system like Honda and GM, which monitored engine operation to calculate remaining oil life. With that system, the Volt could go two years between oil changes. Which was probably still conservative.
    PrimeDan and Mendel Leisk like this.
  7. Templeton
    321
    114
    usa
    2024 Prius Prime
    SE
    Good points, but were you able to listen to the podcast ?
  8. Mendel Leisk
    41,849
    You want to take away my once-a-year fun...
    PrimeDan, bisco and Templeton like this.
  9. Templeton
    321
    114
    usa
    2024 Prius Prime
    SE
    And, unfortunately, this piece of info will take away even more of your once-a-year "fun".
    This oil expert says that changing the ICE oil filters every oil change is not good either:
    (slightly "dirty" oil filters do a better job filtering than brand new oil filters)
  10. bisco
    52,331
    i'm surprised big oil hasn't shut these guys down.
    it would be interesting if someone did a long term study of hybrids vs gassers. the only potential problems i see are climate and driving variables.
  11. Mendel Leisk
    41,849
    Honda's maintenance schedule (it's a little elusive, built into their in-dash Maintenance Minder system) stipulates oil filter change at every second oil change. That said, at our nearby dealership at least, if you ask them to just change the oil, leave the filter, they treat you like you're nuts. What I would DIY at the oil change-only-interval, was drain the oil and filter, reinstall that filter. Worked, and the oil change was more complete.
    BTW, I wonder if there's some brain-fart afoot in the video, at 4:52 the guy he quotes says "a dirty air filter...". I have heard the latter.
    Templeton likes this.
  12. Templeton
    321
    114
    usa
    2024 Prius Prime
    SE
    That is a very good idea: pulling the filter, draining it of used oil, and then reinstalling it (for changes when you plan to reuse the filter).
    About your air filter question, l think the oil geek guy is referencing another of his videos where he had experts on the video with him that were discussing air filters, fuel filters, and oil filters, so that is likely the source of the confusion.
  13. BiomedO1
    4,057
    2,135
    SacTown, Ca
    I believe we are really overthinking things. While the data may be correct for that instance in time; are we really going to monitor the car that closely? Regarding the dirty filter thing, what happens when it gets loaded up with junk and the by-pass valve opens up - it dumps all that debris into your motor. They're creating a solution for a non-exisiting problem by taking a narrow slice of data points. It's more advantageous to look at the entire set of data points, before coming to a conclusion. When I was a kid working the fryer in a fast food joint, after cleaning the filter, we used to dump a cup of powder into the fryer. It was suppose to coat the stainless steel filter and make to filter better. I'm NOT going to leave a dirty filter in on an oil change.
    I did NOT watch the video, because data points can be manipulated to prove their argument. Isn't it common sense that a partial clogged filter is going to filter better if it's partially clogged? Does this mean that we should NEVER change our filters??? We need to be looking at the entire data set and repeating the experiment - only then you can come to a valid conclusion. That's why scientific papers are peer reviewed. To play devils advocate; how clogged should a filter be, before you should toss it out and how would you measure that?
    I change my oil per OEM required intervals. When I get beyond my 5 year 60K mile ICE warranty; I'll more than likely stop annual oil changes and do 10K mile changes ONLY. Based on my current pattern, I've calculated that I do 7500 miles max. on the ICE in that 10K mile interval, that's rounding up on all ICE calculations. Actual numbers not rounding up places me right around 5K miles. So I'm OK with that and may also move to 5w30 oil to reduce wear - I'm in the warmer part of the lower 48 and don't see any down side to that. I exercise my ICE enough to require a fill-up every month. IMHO - anyone doing fill-ups >90 days should rethink how a PHEV fit's their life style.I believe someone here had a strong gasoline smell coming from their engine oil, when they changed it - that's telling me that they are NOT running their ICE long enough or hot enough to evaporate that contamination.
    Just my two cents.....
    #13 BiomedO1, Jan 1, 2026
    Trollbait likes this.
  14. Templeton
    321
    114
    usa
    2024 Prius Prime
    SE
    Not sure if that is the case. For example, if someone drives 5000 miles per year and yet changes their tires every year because they say "its better", is that necessarily smart?
    Ultimately, with a car or a phev that does not get a lot of hours on its ICE, if there is evidence that one's perfectly good synthetic oil can last a bit longer, it seems to me that such evidence is worth examining. And if engine or oil or filtration experts say that a filter will actually work better if changed slightly less often, it also seems to me that such evidence is worth considering.
    #14 Templeton, Jan 2, 2026
    BiomedO1 likes this.
  15. ColoradoBoo
    ColoradoBoo Senior Member
    1,266
    874
    Monument, Colorado USA
    Still lots of reported engine issues coming from Toyota nation with the V-6 engines in the new Tundras and some Lexus. Failure rate is about 3 times higher than the non-turbo V-8 and V-6 engines in the previous generation. Finally, folks are now suspecting it's the turbos causing issues.
    I don't know...just very thankful I didn't trade in my 2014 Tundra V-8 (5.7L) yet....I've been wanting to trade it in for a 1794 for about 4-years now but doesn't look like it'll be anytime soon. (And Toyota discontinuing my favorite color, that smoked mesquite, was just a bummer.)
    If I ever DO buy a Toyota with a turbo, that oil is getting changed every 2,000-3000 miles for sure.
    David, from the Automotive Press channel, recommends we just half whatever recommendation for maintenance intervals. So if our Toyota manual says oil change every 10,000, do it at 5,000.
    PrimeDan likes this.
  16. Templeton
    321
    114
    usa
    2024 Prius Prime
    SE
    Yup, l totally agree, for ICE cars, the 10,000 mile oil change interval is really kooky. I think it is bound to cause problems for long-term engine durability.
    But, 10,000 miles on a PHEV is quite different. Because you could easily have a PHEV that only runs its ICE for, say, 3,000 miles and the rest of the "10,000 miles" are all on pure EV mode. That is why l started this thread about synthetic oil change intervals on PHEVs and chronological time. If one has a PHEV and one wants to change the oil every 5,000 miles ICE miles driven, that could potentially be every 2 years, or maybe even longer.
    Is that OK for the oil or the engine? Experts seem to say that, in many cases, it is totally fine.
  17. BiomedO1
    4,057
    2,135
    SacTown, Ca
    I see what your saying; but the fact is that most people are 'one size fits all' and don't really examine their own particular circumstances. My only real problem with leaving an oil filter in, is you DO NOT know how much junk has accumulated in that filter and your NOT measuring it. So the safer course of action would be to replace it......
    Your tire example is a bit different because you can see and measure it - you can't look inside an oil filter without cutting it open or hooking it up to some sort of analyzer to determine it's blockage level. Spend the $5-$10 bucks and move on to more pressing matters. Cheaper than an engine replacement and the reason we do planned preventive maintenance in the first place.
    YMMV
    PrimeDan and Trollbait like this.
  18. Trollbait
    12,661
    I once changed the oil filter on the HHR a week before the oil; about 300 miles. It was a topside filter, and the weather turned before I got to crawling on the ground. The oil went from black to muddy brown by the time I changed the oil.
    Yes, the filter will filter smaller particles out as it clogs. It may even start working like a parallel filter as the bypass valve opens. But the valve is open, and the amount of particles being removed from the oil stream drops.
    Very likely the oil lasts longer than recommended in most cars. You should do oil analysis if you really want to push it past the manufacturer's point. A CT200h owner here that did extreme annual miles, learned they could do up to 30k miles between changes.
  19. Templeton
    321
    114
    usa
    2024 Prius Prime
    SE
    Yes, good point about the oil filter, kinda hard to verify it's level of blockage or non blockage.
    But engine oil has some easy signs: how many miles (ICE miles) have you driven on it? How does it look? Or, send it in for a quick test.
  20. ColoradoBoo
    1,266
    874
    I can see both sides, for sure, and know quite a few Prius owners who only change the engine oil once a year (because they only put 5,000 miles on them in a year.)
    Yes our ICE engines don't run 100% of the time we are driving, so there are miles on the hybrid that shouldn't count toward the oil change. BUT our ICE engines don't just start up and then are shut down when we get to our destination...they stop and start stop and start numerous times. All engine studies show starting engines is where the majority of the wear and tear happens, so we have to think about that, too.
    Remember the Quaker State Slick 50 oil additive scam? Supposed to "specially coat" the engine to prevent wear and tear upon startup. (They got sued, and lost, total snake oil.)
    otatrant and BiomedO1 like this.
