The effect of removing wheel covers
Discussion in 'Gen 3 Prius Fuel Economy' started by C Clay, Dec 23, 2025.
Tags:
  1. C Clay
    C Clay Member
    349
    67
    Lexington, KY
    I left the wheel covers off because I wanted to drive to work and back and make it quick to re-torque the lug nuts. I don’t necessarily like the black wheel phenomenon of the last 15 years it seems, but the wheels underneath these wheel covers aren’t bad. I’m thinking about some Center caps. For 2014, what size are the caps? also do you give up much gas mileage in the aerodynamicy lost in removing the wheel covers?
    As always, thank you scholars for the lively discussion.
  2. Mendel Leisk
    41,701
    Before 2012 the rims were silver (apparently Toyota Classic Silver Metallic (1F7)). My thought: they saw owners removing the covers, opted to discourage that by uglying-them-up more, going from utilitarian-silver to utilitarian-black.
    I would get the specific Toyota cap spec'd for the 17” rim, if your pockets are deep, or eBay knock-off. I went for the latter: they “claimed” to be genuine but it was not the case, fit was poor but I fixed with a Dremel. You might have better luck now, assuming the imperfections have been sorted out in the ensuing years since I bought some..
    For the 17” rim the centre cap is Toyota part no 42603-52110. That will fit the 15" rims as well. I'm using center caps thus, albeit on the more photogenic 15" Prius Plug-In rims for snows:
    #2 Mendel Leisk, Dec 23, 2025
    C Clay likes this.
  3. Mendel Leisk
    41,701
  4. priumium
    priumium Member
    335
    79
    Sweden
    2013 Prius Plug-in
    I would assume OP talks about branded complete wheel covers for steel rims? I had those on a Corolla 1992. I might misinterpret.
    My 2005 came with JM rims with red Toyota plastic cup styled hub covers. Naturally I managed to destroy two, by leaving them on the ground… :(
    I have never found that design again. Bought hard stickers to attach to generic covers, not completely satisfied…
  5. ColoradoBoo
    ColoradoBoo Senior Member
    1,256
    855
    Monument, Colorado USA
    I've seen quite a few Prius' whose owners have removed those lovely hub caps....doesn't look too awful bad. Probably because, if you hit a curb and scratch one up, Toyota wants an ungodly amount of money for a new one. (You can buy 8 aftermarket hub caps for one OEM, last I checked.)
  6. C Clay
    C Clay Member
    349
    67
    Lexington, KY
    priumium and ColoradoBoo like this.
  7. priumium
    priumium Member
    335
    79
    Sweden
    2013 Prius Plug-in
    Ok, I was wrong. The Terminology for all things attached to wheels is very confused, in my non native English mind.
    Those should be called hub caps. ;)
  8. Mendel Leisk
    41,701
    Totally agree: they’re caps over the small central hub opening, hence “hub caps”.
    Unfortunately the term has popularly morphed to meaning full wheel covers.
    Merkey likes this.
  9. C Clay
    C Clay Member
    349
    67
    Lexington, KY
    Wait- the center caps I just ordered and was showing off in the photo.
    I’m asking if removing the wheel covers partially shown in the photo attached (odd AI generated photo, the first photo I could find on my phone, enjoy!) 5732428E-680A-4CD6-8489-5A61B292006D.jpg
  10. priumium
    priumium Member
    335
    79
    Sweden
    2013 Prius Plug-in
    It’s Koko, mainly since steel rims now are rare, but what would anyone call the entire wheel plastic covers now?
    In Swedish it’s now called wheel sides, unlikely poorly translated.
    #10 priumium, Jan 2, 2026
  11. priumium
    priumium Member
    335
    79
    Sweden
    2013 Prius Plug-in
    Center caps = hub caps.
    That lovely AI pic is of full wheel sides, they are covers for steel rims?
  12. C Clay
    C Clay Member
    349
    67
    Lexington, KY
    So the original question, was does removing these decrease gas mileage to an extent. I think they might, maybe 5% or less. A mile or two. I just took them off the last time I rotated my wheels because I wanted to come home from work and quickly check the lug nut torque. I don’t especially like black wheels, but I do like the ability to check the air pressure more easily, get my fingers in there and takeoff the valve cap. What I wasn’t anticipating is it looks like the automatic car wash I go to is slowly going to black paint. First world problems I guess.
    priumium likes this.
  13. Mendel Leisk
    41,701
    Model year 2010/2011 had silver rims, likely Classic Silver Metallic (1F7), which looked half decent with centre caps (traditionally and more succinctly known as hub caps). I remember looking at 2012's at a dealership, the wheel cover style had been revised/slimmed, and silver rims had become ghetto black. o_O
  14. VelvetFoot
    VelvetFoot Active Member
    945
    341
    New York State
    2026 Prius
    2010 was around the time that clear taillights went out of style among the boy racers. :)
  15. CR94
    CR94 Senior Member
    2,715
    1,182
    Northwestern S.C.
    A real hubcap is bigger than those center caps, but smaller than full wheel covers. They used to be typical of lower-trim US cars (which reliably had steel wheels), but are now rarely seen except on police cars and other fleet vehicles.
    VelvetFoot likes this.
  16. Mendel Leisk
    41,701
    Agree, and cop cars is what comes to mind.
    CR94 likes this.
  17. Mendel Leisk
    41,701
    On our morning walk:
    VelvetFoot and CR94 like this.
  18. VelvetFoot
    945
    341
    New York State
    2026 Prius
    Baby Moons?
    CR94 likes this.
  19. ASRDogman
    ASRDogman Senior Member
    7,670
    3,942
    They are not hub caps, they are wheel covers...
