PHEV specific topic: oil change based on time ONLY
Discussion in 'Gen 5 Prius Care, Maintenance and Troubleshooting' started by Templeton, Dec 30, 2025 at 11:45 AM.
  1. Templeton
    Templeton Member
    305
    98
    usa
    2024 Prius Prime
    SE
    fyi, l am in no way suggesting that. I prefer to change the oil every 5,000 ICE miles. This thread is more about the chronological time issue that comes up in PHEVs.
  2. Templeton
    Templeton Member
    305
    98
    usa
    2024 Prius Prime
    SE
    Agreed, hybrids are pretty tough on their ICE drivetrains. If l had a hybrid, l would change my oil every 5,000 miles driven total.
    But this thread is about PHEVs, which are a special case. When on full EV mode, the ICE is on vacation, it is not operating at all, no engine oil is circulating. And some folks put in far more miles on EV mode than they do on HV mode.
  3. ColoradoBoo
    ColoradoBoo Senior Member
    1,248
    841
    Monument, Colorado USA
    Ah, I can see the dilemma in that. I have that concern with the front differential in my Tundra....it only circulates the fluid around when I have the truck engaged in 4x4 low or high. Since the actuator is electronic, not engaging the 4x4 often enough can result in a truck driver wanting to engage, and the actuator isn't able to work. (Happens a lot in the 4x4....I have a co-worker with an older Tundra 4x4 and was a victim of it....spent a lot of time fixing it.) The "fix" I've learned from the Car Care Nut (Ahmed) and others, is just to turn on my 4 Wheel High once a month for a few miles, which I do. (I just find a long, straight road and turn it on...don't want to be turning corners with a 4x4 on hard pavement.)
    I do remember Ahmed saying that if you don't drive very much, then you shouldn't get a Prime Toyota or even a Hybrid as the ICE engine really does need to be running fairly often to keep it happy.....but where's the sweet spot? Once a week or so?
  4. BiomedO1
    3,727
    1,935
    SacTown, Ca
    Individuals' life experiences and "you can't trust your lying eyes" (Eagles song) - oil color change can mean a lot of things. The only real in- controversial test is an oil analysis and I'm too cheap to do that - since it's more expensive than a filter. Otherwise good thinking. Smell will also allow you to see if your allowing the engine to run long enough to evaporate gas and moisture deposits out of your ICE.
    I use to drive a diesel VW; that oil would turn black in less than 25 miles; whereas my Prime will go about a month and a half before the oil turns slightly amber enough for me to read the dipstick without using a clean tissue to determine it's level.
    YMMV
    ColoradoBoo likes this.
  5. Templeton
    Templeton Member
    305
    98
    usa
    2024 Prius Prime
    SE
    Right, but some people drive their PHEVs plenty. But they just do a lot of their driving in EV mode. That is the use case that l am trying to look at in this thread.
    #25 Templeton, Jan 2, 2026 at 11:27 AM
  6. Mendel Leisk
    41,573
    apologies for being pedantic, but: you’re essentially saying “internal combustion engine engine”.
    just saying “engine” would suffice?
    Templeton likes this.
  7. VelvetFoot
    VelvetFoot Active Member
    809
    291
    New York State
    2026 Prius
    Me too! I put in Delvac1 (Mobil1 for diesel) every 10,000 miles, as recommended by VW. It was still running like new at 225k when I sold it.
  8. Templeton
    Templeton Member
    305
    98
    usa
    2024 Prius Prime
    SE
    Yes, agreed, an eyeball visual inspection alone is totally insufficient to determine the condition of engine oil.
    But an inspection combined with good info on exactly how many ICE miles were driven and what kind of miles were driven (what ambient temps? lots of long trips? lots of short trips? paved roads? dirt roads? lots of towing? no towing? etc.) can cumulatively give a lot of info about oil condition.
    And, apparently, that (i.e., actual miles of use on the oil) is what matters most. While chronological time alone (with modern synthetic oils) seems to matter very little. At least, according to the oil and lubrication experts.
    #28 Templeton, Jan 2, 2026 at 11:32 AM
    BiomedO1 likes this.
  9. Trollbait
    12,547
    Even before synthetics became the norm, the point of the oil change wasn't because the oil went bad. It was because additives get used up. Some of those have consumption rates that line up with engine use. Others could get used up faster depending on the climate. The acid neutralizers can be consumed faster in humid climates. It's water getting into the oil than forms the acids.
    These aren't things that can be eyeballed.
    Was the diesel pre-ULSD? Sulfur is a culprit in coloring oil black. With the shift to even lower levels of sulfur in gasoline for Teir 3 emissions, motor oil is going to last longer.
  10. bisco
    52,035
    when i traded my 2012 PHEV, it had 87,000 miles. only 25,000 on the engine, and that with a 13 mile ev range.
  11. Templeton
    Templeton Member
    305
    98
    usa
    2024 Prius Prime
    SE
    That is amazing . A nearly new engine!
  12. bisco
    52,035
    and that was led me to trading it in, had the bad head gasket shakes
  13. BiomedO1
    3,727
    1,935
    SacTown, Ca
    Not sure, but I believe we were already on ULSD. I was a field service technician at the time and it made economic sense - 50K+ annual miles. I had the option of a company car; but I preferred my own custom rig. Again it made more economic sense to take the monthly cash plus mileage. I could do it cheaper than a company car, that I couldn't drill holes and make modifications to make my job faster and easier to accomplished. I've had multiple large corporations, ask for me specifically, outside my service area and routinely got calls from regional management and VP of service.
    When diesel prices started exceeding gasoline prices; I dumped the rig with over 250K miles on it - One of my co-workers bought it for what I had put into it, so I didn't get hurt and actually made money when you factor in what the company was paying me on a monthly basis. That stipend was suppose to cover depreciation, maintenance and insurance. I calculated that I saved the company at least 3 lease cars, so it was a win-win for both of us.:)
    #33 BiomedO1, Jan 2, 2026 at 2:52 PM
    Trollbait likes this.
