What headlight bulb do I need?
Discussion in 'Gen 2 Prius Technical Discussion' started by Kzbd, Nov 28, 2025.
  1. Kzbd
    Kzbd Junior Member
    22
    Yeah you didn't use one of these plug and play jobs that use the ballast, did you?
  2. Tombukt2
    13,091
    2,349
    Mine plug up to the round d4s connector bulb goes on holder mine also have fans on this car. And in this 07 I did not bypass I can but did not because hid wer working . I just changed bulbs . And let my ole lady get back to her dashing. The 08nis same but bypassed . Same set of bulbs . Alla is no. Longer I think cannot find. Aux seems in same boat .
  3. Kzbd
    Kzbd Junior Member
    22
    Alla is still selling bulbs just not the pig tail one that runs on 12v
  4. Tombukt2
    13,091
    2,349
    I'm beginning to believe that if your ballast goes bad 12 volt still passes through it or something along those lines . I put the one wires on a car the other day and 1 side was out bulb worked on other side . Applied d4s conversion bulbs both sides like new ...weird
  5. Kzbd
    Kzbd Junior Member
    22
    That would be cool
  6. Tombukt2
    13,091
    2,349
    Look carefully you'll find those for 50 bucks I was going to buy a set of those a few months ago when they first came out just the bulb itself no pigtail ford4 connector . 8 just bought the aux branded I've been buying awhile . They should be fine try it with you're fault ring ballast . I bet it ignites. Ut don't know for a fact
  7. Kzbd
    Kzbd Junior Member
    22
    Sorry been a crazy few weeks and I'm not getting notifications for some reason. What brand have you been buying for a while?
  8. Tombukt2
    13,091
    2,349
    Aux Beam company Amazon like 5 yrs now .
