Breathing/Enviornmental Issue 2017 Prius
Discussion in 'Gen 4 Prius Main Forum' started by Sam Will, Dec 28, 2025.
  1. Sam Will
    Sam Will Junior Member
    san diego
    I have a 2017 standard model Prius. I really like it, just bought it a few weeks ago, but I am having a lot of breathing issues when driving, and its quite frustrating after spending a good amount of money purchasing. I am having symptoms of sore/burning throat, stomach becoming upset, lungs feeling irritated, and even I believe my eyes might be burning.
    To try and resolve, I flushed the AC condensation line with a "AC Refresher kit" with little benefit, I replaced the cabin air filter with a top of the line filter having charcoal, ect. Any ideas what could be causing this issue, could a leaky hybrid battery cause fumes in the vehicle? Though it seems to happen when driving only, dont notice it in the AM after car is sitting.
    Let me know if you have any ideas, thanks! Im going to bring it into a great mechanic, but in 2 weeks...... Not able to at the moment.
  2. jdenenberg
    jdenenberg EE Professor
    3,953
    1,949
    Trumbull, CT
    2020 Prius
    LE AWD-e
    I had similar issues a few years ago in my 2004 Prius. Whenever I went on a long trip, I developed hives. The problem turned out to be mice in the HVAC air duct. It took a major cleaning of the AC system to clear up the problem, not just an AC Refresher Kit.
    JeffD
    VelvetFoot likes this.
  3. Sam Will
    san diego
    Thanks for the reply. Yeah, I was looking into local car detailing locations, but not sure what to have done. Maybe steaming the vents, or something else. Not quite sure yet....
  4. bisco
    52,286
    look for an environmental air quality firm
  5. Mendel Leisk
    41,826
    Aforementioned rodents, or tenacious mold in AC system.
  6. Sam Will
    san diego
    Do you know how to rid of mold in the AC system? Seems like I could go a lot of ways
  7. Mendel Leisk
    41,826
    Might involve opening up the dash. Not sure how effective the piped-in stuff is. @rjparker advocates the latter, may weigh in with suggestions/tips. @NutzAboutBolts has an AC cleaning (with the spray product) video #22 here.
  8. VelvetFoot
    VelvetFoot Active Member
    1,139
    449
    New York State
    2026 Prius
    I have very little experience with this, but I did have smelly air when I initially turned on the A/C on a '22 MINI. It would go away after a while, but always come back.
    I live in a relatively cool place and rarely use A/C.
    BMW (MINI by BMW) has had problems with this over the years and I recall the fan would run for a while after turning the car off to, I think, bring things to equilibrium with the outside air so mold forming condensation wouldn't be created. I believe my GEN 5 manual said my car does something similar.
    I bought some A/C cleaning stuff from the local parts place, Advance Auto, a big chain.
    I followed directions, mostly, taking out the cabin filter and spraying in there with the heat and fan on high---I think, lol. I believe I sprayed a little into the air outlets as well, as directed.
    I had no puddling of water on the car floor, and condensate dripped on the ground when the system was running, so the condensate line wasn't clogged, so I didn't have to hunt around for that. Everything was quite cramped.
    It had its own smell that dissipated after a while.
    It wasn't just a fragrance spray, it was specifically for A/C mold/mildew.
    It seemed to work.
  9. rjparker
    10,413
    6,521
    First thing is to look in the evaporator area by removing the cabin filter. Mice will setup on the cabin filter first.
    The Toyota cleaner does work against "dirty sock syndrome" (a type of fungal growth on the evaporator) but the symptoms must match. Typically occurs in any ac system including home indoor units after an ac has been off for many days or weeks and the evap dries out. The first warm humid day using the ac causes condensation to wet the dried fungal growth creating a distinct "dirty sock" smell. The foam cleaner will work for this common situation if applied properly. Don't use the fragrance which can be irritating by itself. Similar foam products are used in home systems.
    Otherwise, I would be concerned about flood damage. Check under the carpets throughout the car.
    Then rodent nests further in the ac ducting beyond the cabin filter. Hopefully not as this requires removing much of the dash.
  10. VelvetFoot
    1,139
    449
    New York State
    2026 Prius
    The below is what I used.
    It was cheaper than the BMW product and I didn't have to drive far, lol.
    Might as well buy from the dealer though-you only want to do it once, if you can.
  11. rjparker
    10,413
    6,521
    Assuming dirty sock syndrome:
    When you think about cleaning a small tightly grouped set of coils with fins and doing it without good access, high pressure water or even brushes, the only hope is a foam with sanitizer that expands pushing dirt and growth around and then dissolves into a liquid and drains. The instructions say inject from the condensate line up into the evap (backflushing) HALF of the can, wait until it liquifies, drains out and then inject the rest. Basically rinse and repeat. Run the ac on max over a decent drive to further rinse using condensate.
    Now think about a sticky dish with egg residue dried up and all you can do is soak it for a few minutes, drain it and do it again without using a sponge or dish cloth. You are lucky if half the goo is gone. Do it again one month later after complaining and maybe its better.
    Yes you could spend $1200 in labor and have it removed, hand clean everything along with the ducts, and then vacuum and recharge the ac system, but it makes sense to try foam again.
    I have found that once its clean it can stay that way for years.
    #11 rjparker, Dec 31, 2025
  12. Sam Will
    san diego
    Actually, Im now wondering if this is an inverter issue ( Im at work so havent been able to check the inverter pump today).
    Reasoning: Alert codes on dashboard
    1- Hybrid system Malfunction visit your dealer
    2- Pre collision system malfunction vist your dealer
    3- Periodically am seeing " Braking Power Low" (which improves after driving) braking is loose kind of spongy
    4- Code C1300 - (if power issue, then maybe why this code popped?) - went to O'reily so only this code popped
    NOte: I replaced old 12 volt with a new 12 volt batter and still having same issues, was hoping all due to bad 12 volt. Braking did seem to improve a little after new 12 volt, but short lived.
    Maybe: The breathing issues, nausea, burning throat is coming from overheating from the inverter associated with this? (Heard from someone this may cause this, they arnt an expert with Prius's though) = was hoping this was just a heat exchanger issue, but havent seen any drop in coolant, and I have all these other issues related to braking, potentialy hybrid, that it leans more in the inverter realm?
    I am in San Diego area, and want to drive up to Arts Automotive in Berkeley, but am worried this is too far to drive with the current situation, potential inverter issue. Seems like I need to get a diagnostic/code tested, but not sure where to go down here, or even in the Los Angeles area. Or if driving like this will be real bad for the car overall.
    Would just stay down here and get it looked at in full, but not sure what prius shop or mechanic to go to in the Southern California area.
  13. Sam Will
    san diego
    I wish it was just dirty sock! Seems more than that...... still trying to figure out, kind of frustrating after buying from a reputable Toyota dealership and having all these issues 2 weeks in. I would understand if I had bought from a random dealership, or a private seller, but I thought toyota dealerships is where you go to get a trusted, vetted product.
  14. Misterman74
    Misterman74 New Member
    25
    Fresno
    2018 Prius
    Take high resolution video of your symptoms. take it back to dealer and show them.
    California has lemon laws for a reason. Stop working on it. Take it back to them. I wouldn't even argue for them to fix it. Id absolutely demand my money back. They say no? Lemon law lawyer.
    edit: pop the hood. With a flashlight look at all the fuse boxes. See any chewed wires? Toyota uses soy based wire insulation. And mice LOVE it. your symptoms sound like allergies to rodents.
    Sorry. I feel bad for ya. Take it back. DEMAND A CREDIT, refund or lawsuit.
    -i have over half a million subscribers tends to do the trick-
