2003 Gen 1 Dies While Driving
Discussion in 'Generation 1 Prius Discussion' started by evilroot, Jun 27, 2025.
  1. vaughnstark777
    190
    33
    Roy, WA
    2001 Prius
    I
    Then you are good.
  2. Q*bertZ
    Q*bertZ Member
    167
    greenville south Carolina
    2002 Prius
    What is the bleeding procedure?
  3. vaughnstark777
    190
    33
    Roy, WA
    2001 Prius
    I
    I think the last time I did it I found it on YouTube, but if you can see liquid flowing into the reservoir, then it’s being pumped there so you don’t have a problem with an air bubble.
  4. Q*bertZ
    Q*bertZ Member
    167
    2002 Prius
    I've done 5 or 6 of them in Gen1s and one in a Gen 2.
    That AM2 Fuse will get you in a Gen2.
  5. Q*bertZ
    Q*bertZ Member
    167
    2002 Prius
    Have the errors returned?
  6. Q*bertZ
    Q*bertZ Member
    167
    2002 Prius
    Update: I drove it an hour today with no further problems.
  7. Q*bertZ
    Q*bertZ Member
    167
    2002 Prius
    And started it up again and the error is back. It was raining today. Moisture problem? This car is possessed. P3000 P3100 P3101 P3191 P2194. Then the key wouldn't work in the ignition. Said the engine failed to start. But didn't die again when I was driving it. It acted up after I tried to restart it at a gas station. Didn't even get gas. How can I check the sub codes if I don't have tech stream? How difficult is it to get tech stream?
