Prius Prime -2018 - Windshield Wipers
Discussion in 'Prime Main Forum (2017-2022)' started by Andrew Murdoch, Jan 4, 2026 at 5:03 PM.
  1. Andrew Murdoch
    Andrew Murdoch Junior Member
    Toronto, Ontario
    2018 Prius Prime
    Upgrade
    Hey
    I'm having a bleep of a time trying to find compatible wiper blades. They have the 28" and the 14" in stock, but the connector is wrong, and I can't find any wipers with that narrow corrector, but I'm not sure what it's called. Does anyone know of a compatible wiper?
    I have a Prius Prime 2018.
    Thanks
  2. BiomedO1
    3,777
    1,968
    SacTown, Ca
    I'm going to assume that those are the stock OEM wiper blades. You can buy the replacement rubber inserts through the dealership or do a parts search using the OEM part number for after market rubber. They are pretty standard commercial rubber inserts, since I replaced mine with commercial silicone bus, tractor trailer inserts.
    If someone replaced the entire wiper blade assembly, non-OEM standard; good luck. You'll probably need to replace the entire wiper blade assembly again.
    My OEM blade assembly has a slot about 1/4-1/2 inch from the edge of the blade, to slip the rubber replacement out and slip the new one in. My neighbor's 2018 Camry has a different blade assembly with stainless steel (SS) backbone stiffeners that you needed to put onto your OEM replacement blade rubber; while mine was a simple slip-in - No SS backbone.
    Hope this helps.....
  3. Andrew Murdoch
    Toronto, Ontario
    2018 Prius Prime
    Upgrade
    Hey
    Thanks for the reply, I'm having my wife go to the Toyota Dealership, since I can't find any wipers that have the right narrow connector piece. I have to assume to that Toyota will, so that's the best I can do, I think. I've been to Canadian Tire, and Part Source, and they don't have compatible wiper blades.
    This is the connector I need, the third one down: https://hallsautospares.ie/wp-content/uploads/2022/02/wiper-adapter.jpg
    I don't know what that connector is called.
  4. BiomedO1
    3,777
    1,968
    SacTown, Ca
    Not sure; but that looks like my neighbors 2018 Camry blades with the SS-backbone. Mine is the first picture, but you should be able to just replace the rubber itself - not that entire assembly. It just slips in - refer to your operating manual for that procedure and make sure you place a towel or 2x4 on your windshield; in case that wiper assembly snaps-back. People have broken their windshield that way. That would be an expensive mistake for a $10 wiper blade.
    Good Luck....
  5. Andrew Murdoch
    Toronto, Ontario
    2018 Prius Prime
    Upgrade
    That connector is what broke, so I need the entire assembly, which is what is causing my headache, but thanks for the responses :)
    BiomedO1 likes this.
  6. BiomedO1
    3,777
    1,968
    SacTown, Ca
    For future reference; DO NOT do that in the cold. The plastic is brittle, so heat it up with a hair dryer and you should be able to remove it without breaking it. Dittto with installing it - it has more 'give', softer when warm.:p You gotta remember that unit gets really hot in the summer heat.
