26-27 Refresh
Discussion in 'Gen 5 Prius Main Forum' started by Cactus, Jan 5, 2026 at 7:00 PM.
  1. Cactus
    Cactus Junior Member
    30
    Mountville PA
    Anyone have any news on a refresh for 2027?
  2. Gokhan
    Gokhan Senior Member
    6,272
    2,512
    Paramount CA
    TSS 4.0, but without Arene, will likely replace TSS 3.0 in the 2027 model year, as it’s only a software update over TSS 3.0.
    2028 will likely be identical to 2027.
    2029 will likely be the year for Gen 6 with TSS 5.0, extensive Arene use, and a newly designed engine with a higher thermal efficiency. There could also be a BEV Prius.
    schja01 and VelvetFoot like this.
  3. bisco
    52,063
    it will be interesting to see if they tweak any of the outside. hard to believe it could be improved on.
    i wonder if a prius bev without a new bev platform would be a good idea.
  4. Gokhan
    6,272
    2,512
    Paramount CA
    I doubt it. Remember that the Gen 4 Prius Prime PHEV (2017–2022) saw zero external refreshes because it is such a beautifully designed car. The Gen 4 Prius HEV (2016–2022) saw some major external refreshes (one or two?) because of the weird design choices they made for it. The Prime only had its white internal accents in the early model years later removed, though, which didn’t look good. Here is a recent photo of the Turquoise Jewel. I mistook a black one from the side for a Tesla Model 3 a few weeks ago:
    One more nice thing about the Gen 4: It is bigger than an SUV inside! I sat in a Hyundai Kona SUV last week, and it felt claustrophobic with my head almost touching the roof, and I am short!
    Some new Toyotas, like the 2027 Highlander, are coming in both the HEV and BEV forms.
    GcinFl and PrimeDan like this.
  5. bisco
    52,063
    you're living in the past. gen 3 had a better hatch, but it's not coming back
  6. Trollbait
    12,568
    And then the gen4 hybrid had Prime parts it could borrow for the reface.
    The Kona is a size class or two smaller than the Prius.
  7. Gokhan
    6,272
    2,512
    Paramount CA
    Gen 4 HEV and Gen 4 PHEV have different body styles, with different drag coefficients.
    Kona is an SUV.
  8. Trollbait
    12,568
    The Kona is a compact SUV; possibly subcompact. The Prius is a midsize car. The interior seating dimensions near identical between them.
  9. Gokhan
    6,272
    2,512
    Paramount CA
    The Turquoise Jewel is only five years old. I hope I am not living that far in the past.
    That said, I traded it in for a $150,000 Corvette in my dream the other night. Then, I saw new Gen 5 Prius PHEVs around, including a nice red one, and I regretted not getting a Gen 5, but I was hoping that I would be cool in the Corvette and was checking its handling. Given that it was a dream, I couldn’t make it handle well. I was also feeling bad about no longer having the nice turquoise color. Then, I woke up and was relieved.
  10. VelvetFoot
    VelvetFoot Active Member
    836
    296
    New York State
    2026 Prius
    I saw a yellow one at a local car show. Some special model. Big black wing on it. Hideous.
    Then again, a guy at the local diner has a silver and black one-gorgeous.
  11. Mendel Leisk
    41,610
    If Gen 4 is an SUV, Gen 3 is a Ford Transit.
    If I’m driving in dreams the roads tend to get preposterous, for example: slowly/inexplicably banking more and more, 20 degrees, 40, 70…
  12. VelvetFoot
    836
    296
    New York State
    2026 Prius
  13. Mendel Leisk
    41,610
    Speaking of Ford Transit, Google’s AI says most Transits are 16” rim. Meanwhile, any gen 5 Prius hybrid for sale up here (not the plug-in iteration) has 19” rims. Different priorities I guess.
    (on a phone turn it landscape to see location)
  14. bionicbadger
    bionicbadger Junior Member
    Alberta
    2027 Toyota is planning the Corolla PHEV. The market for Prius is going to MUCH smaller, hopefully they keep it around or do something to differentiate it.
