My 2012 wants a Remote Start installed... in 2026.
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Myself248, Dec 28, 2025.
Tags:
  1. Myself248
    Myself248 Junior Member
    32
    Royal Oak, MI
    ...and the internet is full of dead links and out-of-stock parts.
    What's my best option here? I would prefer to do my own installation if possible, mostly because of a pathological hatred of T-taps. The OEM fob is fine, I don't need a lot of range.
    (Background: I never saw the need for a remote start, but lately my commute involves getting on a highway about 1500 feet after starting the car. That's brutal on a cold engine, and sitting in it while it warms up seems silly. Remote start suddenly makes sense, but because I didn't do it 13 years ago, it's slim pickin's to find parts that're still available and documented.)
    I've found that I can buy a new-old-stock OEM PT398-47110, but I'm hard-pressed to figure out whether it requires any sort of software tweaks to enable it after installation. (I have an old copy of TechStream and the clear VCI cable.) Any clarity here would be appreciated.
    I've found a lot of references to the Directed DBALL, but it seems to have been discontinued back when dinosaurs roamed the earth, and it seems to need an XKLOADER2 to program it. I can find both units (and the TLTH2 harness) on eBay, but good luck finding the software. There are new Directed products that seem to do the same thing, but their site isn't exactly open about documentation. (I need an installer login?) Is that just how this industry is?
    52,074
    block heater?
    Georgina Rudkus and Mendel Leisk like this.
  3. Myself248
    32
    Royal Oak, MI
    Installed one of those years ago (notably, it requires no software configuration), and it's great in my driveway at home (I have the outlet on a timer and everything), but it's not an option at the hotel where I'm staying for work, sadly.
    I appreciate the out-of-the-box thinking though!
  4. ASRDogman
    ASRDogman Senior Member
    7,647
    3,936
    The engine can handle the cold. It will warm up faster under normal driving and you'll have heat.
    You could wait until the engine warms up, at idle, but you don't need too.
  5. Prodigyplace
    12,593
    11,791
    Central Virginia
    On the Prius, is there really THAT much difference between the normal engine idle vs highway driving? Just do not be too aggressive initially and you should be OK, IMO. the Prius engine already tries to get up to temperature as fast as it can once it starts.
  6. Leadfoot J. McCoalroller
    8,112
    7,591
    Pennsylvania
    2018 Prius c
    More or less.
    It's a heck of a lot cheaper to provide technical support to a few professional installers than the general public. Given that most people don't install their own to begin with, they aren't even going against the flow to do it this way.
    If it were me I'd skip the whole thing. It's not like you're driving a carbureted cast iron engine from the 1940s. There really have been a lot of advancements in engineering since then, might as well take advantage of them.
    Another thought: just go around the block once before you get on the highway. Nobody's forcing you to take the shortest possible route.
  7. Mendel Leisk
    41,629
    FWIW, my block heater was replaced by dealership due to recall (fire hazard), and the new one is noticeably weaker. I’ve seen mention online it’s been revised from 400 to 200 watts. Even increasing plugged-in time from my old 2-hour time to 4 hours, pretty anemic.
  8. ASRDogman
    7,647
    3,936
    Yes, it idles at a lot higher RPM than a none hybrid car.
    Today's engines and oils don't need the old warm up time like the ones from the 60-70's.
    Prodigyplace likes this.
  9. Mendel Leisk
    41,629
    Of interest (maybe): for the first block or two, driving after cold-start, the engine provides no motivation, it’s purely electric. You can verify: step on the gas and the car accelerates, but the engine, while running at fast idle, doesn’t change its tone.
  10. BiomedO1
    3,779
    1,968
    SacTown, Ca
    In my experience; most hotels in snow regions usually has several dedicated spaces for plugging-in - ask the front desk personnel.
    Not sure about the gen3, but on the gen4 - hitting the front windscreen defrost will force engine startup cycle. Once it's on; it will complete the ICE warm-up cycle before shutting-down. That's if the software hasn't detected that it's so cold that it needs to start the engine to warm the battery pack.
    You may also want to crawl under the car to check the exhaust gas heat exchanger flap is free and working properly. If that flap is frozen in the open position - it's going to take longer to warm the system.
    Hope this helps....
  11. priumium
    priumium Member
    312
    76
    Sweden
    2013 Prius Plug-in
    In Northern Europe this is daily winterlife indeed.
    https://www.defa.com/defa-mobile-services/ for example.
    It’s not a genius concept, unless you manage to get 220V - or have failover batteries ready…
    (Do note G3 Prius has a oe 700W heater which makes defrosting fast).
  12. Myself248
    32
    Royal Oak, MI
    Whoah, thanks for the heads-up! I found the recall and it sounds like some blocks were made with holes that don't fit the heater snugly? I installed mine myself (after buying it from this very website in 2013), and it felt pretty snug, so I'm not worried, but yeah it's definitely 400 watts, I see that in HomeAssistant every time I turn on the plug in the morning an hour before leaving home. I can't imagine that 200 would do much of anything at all, I'd be looking at an aftermarket lower-heater-hose insert or something.
    Precisely the reason I don't want to womp on it first thing after start, yeah. It clearly really super seriously does not want to put torque on the engine until it warms up a certain amount, which is significantly longer than my on-ramp.
    Hey now, what're you doing here with your common sense?!
    Going around the block, or just puttering down the surface streets parallel to the highway, and taking the next on-ramp..... That would be so much simpler and cheaper than the aftermarket remote start I just installed before coming back here and reading this thread with all that sense-talking in it.
    At least it gave me a good excuse to vacuum out the driver's floor. Ew.
  13. Prodigyplace
    12,593
    11,791
    Central Virginia
    Apparently, some clueless people do. I have a software update recall on my 2025 Camry and there are 2 ways to avoid display issues with the rear camera.
    1. The camera image can freeze if you do not wait at least 3 seconds between power on and putting in Reverse.
    2. If you turn the car on and off in less than 13 seconds, you may get a black screen the next time the vehicle is turned on.
    Apparently there were enough complaints about both conditions to trigger a recall.
  14. Leadfoot J. McCoalroller
    8,112
    7,591
    Pennsylvania
    2018 Prius c
    Haha! I figured if you were already committed to burning gas to solve the problem, why not do it with what you already had? Especially if the hotel is (as is implied) a temporary address.
    ...but congrats on the project all the same!
  15. restllonell
    restllonell Junior Member
    US
    @Myself248
    Funny thing is I'm in your situation currently only I have a 2013 and looking to get an OEM remote start installed. Yeah you have to use tech stream for the programming to your vehicle. I've found the remote start modules for cheap, but can't find the T harness anywhere. I've found the OEM install instructions but can't find the harness on alldata or mitchell to figure out the pin out. I'm looking to either get a harness from a parts Prius or buy the OEM new unit and replicate the harness...I also have a ct200 I'm trying to do this too. Does anyone have a harness available to sell or give pin out info for?
  16. Prodigyplace
    12,593
    11,791
    Central Virginia
    The information SHOULD be available in TIS.
  17. restllonell
    US
    Thank you for this information!
  18. Prodigyplace
    12,593
    11,791
    Central Virginia
    TIS
  19. Abarnabe
    Abarnabe Active Member
    169
    100
    Netherlands
    I just plugged an electric pellet stove starter in to the prius block, it does the same as a block heater, but for a fraction of the price
    there are options for 120, 240 and 380 v and wattage around 350w
    https://a.aliexpress.com/_Exuv8OY
