Recharging HV battery after car sat for 2+ years?
Discussion in 'Generation 1 Prius Discussion' started by AlsoJakob, Nov 16, 2025.
  1. AlsoJakob
    AlsoJakob New Member
    Portland, OR
    2001 Prius
    I’ve got my hands on a 2001 Prius that a coworker had sitting for 2+ years after the cat was stolen. I’m trying to recharge/recondition the HV battery with a CQ3 hobby charger and so far it has been going well.
    Modules 1-22 bounced back beautifully with 5000+mAh discharges and holding steady at ~8v but 23-38 are all reading under 1v at the module. Can these be recharged/reconditioned or should I just replace them?
  2. dolj
    dolj Senior Member
    8,502
    4,314
    Wellington, New Zealand
    I think the only way is to try and see. I would charge up to 7.2 V at 325 mA, rest it for 5 - 10 mins, then do your regular charging regime.
    It will either work or it won't. You haven't lost anything trying.
    AlsoJakob likes this.
  3. AlsoJakob
    Portland, OR
    2001 Prius
    Update: replaced the weak modules and balanced the pack. Dr. Prius shows a clean bill of health :)
    ammdb and dolj like this.
  4. indel
    indel Member
    257
    81
    Northwest Indiana
    Can you describe your process in detail?
  5. AlsoJakob
    Portland, OR
    2001 Prius
    Sure thing! I’ll write it up tonight with photos when I’m off work.
    indel likes this.
  6. dabard051
    dabard051 Tinkerer-in-Charge
    260
    97
    Rochester, NY USA
    2002 Prius
    <bump> congrats on revitalizing your traction (HV) battery.
    Happy new year (2026)...
    Come spring, I suggest you again pull the HV battery and clean all the grotty stuff off the contacts to the battery harness.
    When you have the sense side taken apart, pull the plug where the sense harness goes into the battery control module and clean up (as best you can) all the pins on the battery control computer orange connector to the battery.
    This part (82165-47030) is NO LONGER AVAILABLE in the Toyota parts system, so plan on taking extremely good care of the one functioning sense harness that you currently have.
