Removing corrosion in connection points
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by brka-brkb, Jan 7, 2026.
  1. brka-brkb
    brka-brkb New Member
    New York
    Hello!
    My 2005 Prius is showing P3000 and C1310 codes with the red triangle, and it appears from my research that corrosion in one or more of these connection points is a possible cause:
    - Copper bus bar
    - Sensing harness
    - Fan connector
    - HV ECU pins
    - 12V battery terminal
    Of these parts, where can I buy the fan connector and HV ECU pins (connector), as I can't seem to find them on eBay or Amazon like I did with other parts?
    And if the corrosion is minor, how would I go about cleaning them, especially in narrow spaces? I assume some sort of specialized brush like this one would be needed, and for cleaning chemical, would something like these be okay to use?
    Thank you!
  2. dolj
    dolj Senior Member
    8,495
    4,313
    Wellington, New Zealand
    I can only speak to this point.
    Most people just cut this connector out and solder the wires together. If you want to keep the ability to plug/unplug this connection, just buy a 3-pin waterproof connector and cut out the old one.
  3. mr_guy_mann
    mr_guy_mann Senior Member
    4,071
    1,988
    NJ-USA
    You need a more capable scantool.
    C1310 is a code in ABS that says "there's a problem in the Hybrid Control ecu".
    P3000 is a code in Hybrid Control that says "there's a problem in the High Voltage battery ecu".
    There are a few INF detail codes for the P3000, but now you need to check the HV battery ecu for codes before replacing parts.
    #3 mr_guy_mann, Jan 7, 2026
    Brian1954 likes this.
  4. Brian1954
    Brian1954 Senior Member
    2,351
    947
    South Central PA, USA
  5. brka-brkb
    New York
    Sorry about the double post. I wasn't sure if my latest post on the older thread would receive readership or not. Thank you for your responses!
