Help: 2019 prius 155k - 1-2 second shake when starting up
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by franksrental, Jan 5, 2026.
  1. franksrental
    franksrental Junior Member
    29
    usa
    Hi everyone,
    I recently drove my father's Prius for the first time in over a year and noticed the car shakes or rattles slightly during every startup.
    For context, I own a Gen 3 Prius that I purchased used, and I had to replace the engine due to the infamous 'rattle of death'/EGR problem. Now I'm wondering if my dad's car is experiencing the same issue. From what I've read, Gen 4 models aren't supposed to have this problem—or at least it's very uncommon. His car only has 155k miles on it, though I should mention the maintenance history has been poor: the spark plugs still haven't been changed, oil changes happen every 15k+ miles, and I'm not sure what else has been neglected.
    I'd really appreciate any insight you can offer! Of course, I'm trying to convince my father that regular maintenance is essential, but getting him to listen is another story.
    Thanks in advance for your help!
  2. franksrental
    29
    usa
    forgot to mention that the coolant level was at the minimum so there has been some leaking. thanks again for reading! Also I read about the possible catalythic converter leak besides the head gasket issue...
  3. bisco
    52,334
    if the coolant hasn't been changed yet, it could be a normal level for 155k.
    ifit were mine, i would do all the standard maintenance for time and miles, and throw in engine items that aren't on the list, like throttle body cleaning.
    if it is still rattling, then a head gasket check is appropriate. you can find methods on youtube, like boroscope.
    top up the coolant, and keep an eye on it.
  4. franksrental
    29
    usa
    thanks so much bisco, so worst case it could be the head gasket even with 155k and 6 year old?
  5. bisco
    52,334
    any car with 155k is a possible head gasket issue, but unlikely
  6. BiomedO1
    4,058
    2,136
    SacTown, Ca
    Get all the maintenance up to date and change both coolants. Pay special attention to the old spark plug condition and keep track of where each plug comes from. Post pictures of the ends of each plugs.
    It may just be condensation in the combustion chamber, but 15K mile oil changes is really pushing it - especially if you use cheap oil. IMHO.
    Get that coolant level topped off right away, because that's a sure way to blow a head gasket - since the dummy lamp doesn't go off until 248+F, NO beeps or alarms; you just need to notice it lit!!!
    #6 BiomedO1, Jan 7, 2026
    Bill Norton likes this.
  7. Brian1954
    Brian1954 Senior Member
    2,385
    958
    South Central PA, USA
    Let me correct that for you. In a Gen 3 Prius, the high temperature light goes on at 248F. I am guessing that a Gen 4 is similar.
    BiomedO1 likes this.
  8. BiomedO1
    4,058
    2,136
    SacTown, Ca
    Sorry; typing that while my coffee was brewing.:eek:o_O:whistle: Already corrected it once - had typed 485F and caught it before posting - still didn't feel right; just thought it was because I hadn't had my coffee yet.:ROFLMAO::LOL::D:LOL:
    @Brian1954 Thanks for the correction
  9. Bill Norton
    Bill Norton Senior Member
    2,208
    744
    MONW, Ks.
    2019 Prius
    L Eco
    Good Grief...:eek:
    What a design decision to Not ALERT the driver with a loud warning that the Engine is Over Heating..:mad:
    I at least get a gentle beep when the fuel light comes on.
    I guess that's more important than letting you know your engine is about to self-destruct.o_O
  10. BiomedO1
    4,058
    2,136
    SacTown, Ca
    Worse; I don't believe it's logged either, when you do a history search of the OBD2 error codes:(
    If that 'design feature' wasn't incorporated - How would they sell you another car?o_O:cry::rolleyes::D:whistle:
    IMHO; anyone with >150K miles should either monitor their ECT, with a real gauge or preemptively replace that electronic coolant pump; if they want to side-step a head gasket issue.
  11. Mendel Leisk
    41,849
    Were 2019's out of the production period where the Exhaust Heat Recovery system was springing coolant leaks? I think so, but not sure.
  12. BiomedO1
    4,058
    2,136
    SacTown, Ca
    I believe they were, but Toyota is one of those companies that does mid-year changes - so an early 2019 may actually be assembled in 2018. Only the vin or door tag would clarify that, but I would still test for that failure.
