Park and drive the engine RPM fluctuates 3rd Generation Toyota Prius
Discussion in 'Gen 3 Prius Main Forum' started by josin, Jan 6, 2026.
  1. josin
    josin New Member
    New Zealand
    2014 Prius Alpha
    I’m currently driving a 2014 Toyota Prius Alpha and have been experiencing an issue. When I release the accelerator pedal, the car surges unexpectedly. Additionally, while in park, the engine RPM fluctuates. During these surges, the hybrid system stops charging. There are no fault codes displayed.
    Do you have any advice on how to resolve this?
    Here are the diagnostic steps I’ve already tried without success:
    Removed and cleaned the throttle body and airflow sensors
    Disconnected the airflow sensor and O₂ sensor
    Removed the intake manifold and replaced the manifold gasket
    Cleaned the EGR internal passage
    Cleaned the PCV valve
    Verified air-fuel ratio sensor and O₂ sensor values (all within range)
    Observed throttle idle switching on and off
    Noted that catalyst temperature was slightly high
    Any guidance or suggestions would be greatly appreciated.
    #1 josin, Jan 6, 2026
  2. Brian1954
    Brian1954 Senior Member
    2,396
    960
    South Central PA, USA
    Have you looked at the short and long term fuel trims?
    josin likes this.
  3. ChapmanF
    18,513
    Can you elaborate on what you mean by 'surges'?
    By how much does the RPM fluctuate, and on what sort of time scale?
    The car does not constantly charge the traction battery. When it is adequately charged, the car stops sending charging current to it, which reduces the load on the engine, which is a change that can be heard.
    From what you have said so far, I am not able to be sure whether you are describing normal behavior or something worth being concerned about.
    josin and PrimeDan like this.
  4. josin
    josin New Member
    New Zealand
    2014 Prius Alpha
  5. josin
    josin New Member
    New Zealand
    2014 Prius Alpha
    Sorry, Im not sure how to check
    #5 josin, Jan 8, 2026
  6. CR94
    CR94 Senior Member
    2,741
    1,198
    Northwestern S.C.
    Is the behavior you're describing a change from previous normal behavior, or have you not had the car long enough to be familiar with normal behavior?
    When the car is in Park, the engine normally shouldn't be running at all, much less surging, unless the engine is cold, the battery has been discharged down to two "bars" or less on the charge level display, or you're in maintenance mode.
