Trying to figure out what these parts are
Discussion in 'Gen 3 Prius Main Forum' started by mhdriver, Jan 8, 2026.
  1. mhdriver
    mhdriver Member
    158
    61
    florida
    Ok, I bought a new EGR valve for my 2015 Prius. Pretty obvious what the valve and flat gaskets are, but the red rubber gasket has me baffled. Where does it go?
    #1 mhdriver, Jan 8, 2026
  2. Tombukt2
    13,453
    2,418
    You got it apart yet this is the new stuff. Whenspart you use what's needed . If it ain't they're coming out it probably ain't going in..
  3. ASRDogman
    ASRDogman Senior Member
    7,832
    3,990
    Rubber one with the tab goes on the intake manifold.
  4. Mendel Leisk
    41,923
    It’s the gasket between EGR pipe and intake manifold.
  5. mhdriver
    mhdriver Member
    158
    61
    florida
    I found it now. Thanks guys! I did get another intake manifold as well. So I'm doing egr cooler, egr valve, egr intake manifold, pvc valve, water pump rotor. Otherwise, is there anything else I should do while I've got this much stuff off?
  6. Mendel Leisk
    41,923
    All new? What was the dollar tally for those, close to a grand USD? Or some was salvage?
  7. indel
    indel Member
    279
    88
    Northwest Indiana
    If you are doing all those things, you might as well do the egr cooler? Yes, it's the most expensive part of the train, but also second to none in terms of clogging.
  8. mhdriver
    mhdriver Member
    158
    61
    florida
    I did get an egr cooler and pipe (salvage). Cleaned in my parts washer, it all looks great. It was all under $600 . The EGR kit was a close out from a Toyota dealer at an amazingly cheap price. Got the intake manifold new off Ebay. Next time around i'm going with an oil catch can as well.
    Mendel Leisk and indel like this.
  9. mhdriver
    mhdriver Member
    158
    61
    florida
    I got the cooler. off Ebay and cleaned it in my parts washer. It's as clean as a whistle.
  10. Mendel Leisk
    41,923
    In hindsight: cleaning your original cooler would have worked out about the same? ;)
  11. mhdriver
    mhdriver Member
    158
    61
    florida
    Probably, but I don't know how long it would take to clean and I can't afford downtime. This way, I'll have a clean cooler and EGR valve and manifold when I do it again in 50k miles. Hoping I can get several more good years out of this car.
    mjoo and Mendel Leisk like this.
  12. mhdriver
    mhdriver Member
    158
    61
    florida
    d
    Just built a 30 x 80 garage. Will be putting a 4 post lift in there, so much of this will become easier. I'm going to be working a hospice job where I'll drive extensively and get reimbursed for mileage. In a Prius, that's a winning game :).
  13. ASRDogman
    7,832
    3,990
    PCV Valve while the intake manifold is off....
  14. mhdriver
    mhdriver Member
    158
    61
    florida
    Yes, that's on my list. Will start this job on Monday. Hoping not to take more than 2 days. I've watched enough YouTube to have a bit of confidence :).
    ASRDogman likes this.
  15. mhdriver
    mhdriver Member
    158
    61
    florida
    Would you guys advise replacing the coolant hoses? They don't seem brittle, but I do think I've got a very small leak somewhere in the system. No exaust getting in coolant. 205k miles.
