58 mpg On First Tank
Discussion in 'Gen 5 Prius Fuel Economy & Prime EV Range' started by VelvetFoot, Nov 15, 2025.
  1. VelvetFoot
    VelvetFoot Active Member
    848
    301
    New York State
    2026 Prius
    Dealer-filled first tank.
    Went until light came on when it said I could go 30 miles more.
    559 miles, 9.64 gal
    The tank capacity is 11.3 gals?
    I don't think I'm going to test it though. :)
    I kind of babied it, but not super extreme.
    edit: The tank apparently holds 11.4 gals, per the manual:
    edit 2: Apparently 1.6 gal when the light comes on. At 50 mpg, that'd be...80 miles. If not on an uphill slope assuming the fuel pickup is in the front, lol.
    edit 3: The car computer said 2 mpg higher on the tank.
    #1 VelvetFoot, Nov 15, 2025
    lostsoul likes this.
  2. sclevine
    sclevine Active Member
    162
    155
    Northeast Florida
    2024 Prius
    Congrats! I can't seem to ever get that high, but when I baby it I do get in the mid 50s. But I think the LE's do get a couple higher MPG then the XLE's due to the tire size.
    Yeah the light comes on very early. Just like you'll notice that you'll get about 70-90 miles before the fuel gauge starts to show below Full, I believe similarly you'd get about 70-90 miles once you get below Empty/0 MTG. Not the warning light, but 0 MTG. I'll sometimes let it get to around 0 MTG before I fill and it generally takes 9.5 gallons or so.
    I have my display above steering wheel set to show me MPG for current tank. If it shows me my MTG for the tank is say 55.5, then I know I easily can go 550 miles before refilling, regardless of what the MTG estimates. But I don't really test it below 0 MTG. Again, if I refill at 0 MTG it will take 9.5 gallons (give or take) at that point. Far from the 11.4 capacity. Scanning my Fuelly, I have only had 1 instance where I had a fill up over 10 gallons.
    Also, if your tank is mostly highway driving at high speeds, not only will your MPG be much lower, but the light comes on even earlier than necessary, and at 0 MTG it will take even less - like 9ish gallons.
    VelvetFoot likes this.
  3. VelvetFoot
    848
    301
    New York State
    2026 Prius
    Our experiences match up pretty well. I did drive a little bit after the light came on. :)
  4. bisco
    52,070
    great mpg's, congrats!
  5. VelvetFoot
    848
    301
    New York State
    2026 Prius
    Thanks!
    I'm not being quite so careful now.
    Should a goal be to keep the EV light lit up as much as possible, or could that lessen the life of the traction battery?
  6. bisco
    52,070
    it won't hurt the battery, but it actually reduces mpg's, because it takes more energy to replenish the battery than it does to drive hv.
    for best mpg's, the goal should be to stay in hv, or you can research 'pulse and glide' for eco nuts.
    some say, 'just drive it'
    PrimeDan likes this.
  7. VelvetFoot
    848
    301
    New York State
    2026 Prius
    By that you mean ice and motor are running simultaneously?
  8. bisco
    52,070
    sometimes. the system takes care of itself. so you won't be pure ev too often, but depending on the input from the go pedal, the required energy and the battery state of charge, the software is providing the best mpg's possible for a computer.
    naturally, there will be times when the battery needs to be bled down. in that case, the software will keep it in ev, or even run the engine to bleed off excess regeneration when going down a mountain.
    basically, it just means on't try to keep it in ev. :)
  9. VelvetFoot
    848
    301
    New York State
    2026 Prius
    I find if I back off on the go pedal I can induce "EV mode", ie, the green light come on. I'm wondering if that's a bad thing. I imagine the system knows how to protect itself, but there was a statement in the manual about the life of the traction battery depending on the manner of driving.
  10. bisco
    52,070
    that's just a legal statement for people who think their battery is not performing and want it replaced under warranty.
    if they thought there was anything an owner could do to damage the battery, they would mention it.
    there's nothing wrong with what you're doing as long as you are just gliding. if you find yourself pressing the pedal once you'veinduced ev to try and speed up or not lose spedd, that's where you start to lose mpg's, but it won't hurt the battery.
    the worst thing for the batteries is heat. people who have to leave it parked all day in the sun in warm climates.
  11. VelvetFoot
    848
    301
    New York State
    2026 Prius
    Thanks!
  12. broderp
    broderp Junior Member
    OH
    2024 Prius
    Limited AWD-e
    To the OP, what trim is your Prius? Sounds like a very solid number to start off with!
    My best so far is 55.1 mpg with my 24' LIMITED AWD. It's been getting cold here lately and the number has dropped to about 50 mpg per tank, which is around my overall average of about 51-52 mpg. Last winter it went down to about 47 mpg during the coldest part of winter.
    The Prius lies to me about range, but I'm guessing it has to do with a safety margin that is built in. When I fill up (I use the same gas station, the same pump and auto fill the tank using the slowest setting. I don't ever pump more in or 'top it off'.)
    My Prius gives me a full range of about 470 miles. When I drive to empty (less than 20 miles range) my 10.6 gallon tank only takes about 8.5 gallons of gas to fill up meaning have about 2 gallons still in the tank or about 94-110 miles of range left. So my actual range is closer to 560 miles per tank.
    I will now drive home (23 miles) with nearly no range left with out worrying about gas until I get to my favorite gas station in my home city. Yesterday I drove home with 8 miles range left, drove the 23 miles and filled up with 8.55 gallons.
  13. VelvetFoot
    848
    301
    New York State
    2026 Prius
    Thanks! It's an LE.
    I've got about 250 left to go on my second tank, with the gauge saying 61.7 mpg.
    I consistently let the pump shut off and give it one more shot...for better or worse. There doesn't seem to be a slow setting on NY pumps-they want you to have your hand on the nozzle, lol.
    I must admit I still can't help babying it, especially when I'm not impeding anyone. I do keep pace with traffic on the interstate, but in the slow lane, and I don't do too much highway driving.
    55.1 on a Limited AWD is darn good, I believe. That's got the 19" wheels too and the AWD is a drag as well.
    It might be colder here than where you are, so I'm happy.
    I'll let it drop down to zero and then fill up, even if I have drive around aimlessly. Hey, I'm retired.
    I love the way the car drives. It takes curves and traffic circles just fine, and does have the power to merge and pass when needed.
    The amazing thing is this mileage is with plenty of hills thrown in. I love it.
    2023p and Tande like this.
  14. VelvetFoot
    848
    301
    New York State
    2026 Prius
    2nd tank.
    Filled up about 2 miles after 0, or "Refuel Now".
    Put in 10.179 gallons, in the 11.4 gal tank, so 1.2 gal theoretically left, and at 50 mpg, 60 mile additional range after "empty".
    I traveled 617 miles, so 60.6 mpg.
    The car computer read 1.5-2 mpg higher last two tanks.
    I'm just gonna go with that and not do any more arithmetic. :)
    otatrant likes this.
  15. HamiltonPrius
    HamiltonPrius Member
    188
    93
    Parts unknown in Virginia
    2026 Prius
    First tank 52 mpg on the button. I’m happy with that being it’s been cold every day causing the gas engine to run more than normal. I would expect better once the weather breaks.
  16. VelvetFoot
    848
    301
    New York State
    2026 Prius
    Yep. My last tank was 55.
    Everything is more reluctant to move.
    Apropos of nothing, I have one hill that I coast down part way. I have to say, it's a good coaster.
    I wonder if a winter fuel formulation they use also has an impact, although I have not done any research at all on this.
    2023p likes this.
  17. Gokhan
    Gokhan Senior Member
    6,292
    2,519
    Paramount CA
    The mpg will vary greatly with speed and humidity, both of which affect the drag.
    I am unhappy when my fuel economy is less than 70 mpg (75 mpg on the display) for my 2021 Prius Prime Limited. That said, I do hypermile. Those who attempt to hyperspace instead will observe far less mpg.
  18. HamiltonPrius
    188
    93
    2026 Prius
    55.12 mpg on 2nd tank, up from 52 …exactly what the heads up number was.
  19. VelvetFoot
    848
    301
    New York State
    2026 Prius
    My display seems to be 1.5-2 mpg high. You have an XLE, with the lux wheels (lol). Maybe that's why.
    HamiltonPrius likes this.
  20. VelvetFoot
    848
    301
    New York State
    2026 Prius
    Mine seems to be consistent. Yesterday's fillup:
    55.4 actual
    57.3 display
