Should I replace my 2yr old TPMS when changing tires?
Discussion in 'Gen 3 Prius Main Forum' started by Somu, Dec 31, 2025.
  1. VelvetFoot
    VelvetFoot Active Member
    850
    302
    New York State
    2026 Prius
    My observation is to believe the TPMS, lol.
  2. Somu
    Somu New Member
    Thanks all for the detailed responses. I will stick to what is in them, given that these were the OE TPMS sensors that I bought from Toyota ... And this was more of a preemptive request on my part rather than something the installer said (my install in set for next week), as I try to anticipate things I possibly would need...
    Wishing you all a very happy, healthy and prosperous new year!!!
  3. Mendel Leisk
    41,629
    There can be glitches:
    A year or two back the TPMS light came on, on our ‘10, tire pressures were fine, and I figured one or more of them had battery failure.
    About a week later light went off, nothing untoward since.
    similar happened just a few years after purchase (new): light came on when we were on vacation. Pulled into a gas station, all pressures fine, bumped the pressures 3~4 pounds, light went out. I set them all to usual pressures, cold, a few days later, light did not return.
    Seanathon and priumium like this.
  4. priumium
    priumium Member
    312
    76
    Sweden
    2013 Prius Plug-in
    As I understand it, TPMs is only mandatory in US and perhaps some other clone countries?
    Anyhow, the general sensor concept is sound - if you don’t have to replace tyres every winter. Then it becomes an expense, since the G3 does not auto learn new IDs, as modern (2018 for Toyota..) models do.
    You may clone any IDs easily and cheaply with i-venu/thinkcar app and S3 sensors. You may tape over the light. You may replace the batteries. You may cut the warning light via above mentioned loop.
    Georgina Rudkus likes this.
  5. priumium
    priumium Member
    312
    76
    Sweden
    2013 Prius Plug-in
    Indeed, this TPMs concept is very much non-fool-proof. It’s an old-way communication tech.
    The light tends to go on due to;
    1. Battery saving / Sleeping TPMs that only wake above some unknown tire rotation threshold.
    2. Temperature changes to below -2°C
    3. General confusion in the ECU/system, ie delay in picking up IDs and assuming ID1-4 is the same within error threshold (20 mins) (validated for me via obd reading, two and some times three tires show identical pressure - with two decimal points. Unlikely correct…).
    The plug-in G3 I purchased autumn 2025 had one sensor actually missing/broken off. The others were Toyota OE from the factory and still works on both sets of tires, thirteen years later.
    G2 does not have TPMs, atleast not in Europe.
    #25 priumium, Jan 2, 2026
  6. ASRDogman
    ASRDogman Senior Member
    7,647
    3,936
    You do not HAVE to have the sensors, nor do you NEED to replace them.
    It's not a safety issue, if they fail, nothing happens.
    They are not required by law, at least not in America.
    It's one of those things you can wait until they fail to replace them. You can do them one at a time
    if you want. Likely when one fails, other will not be far behind. So when one fails, if you replace them
    all, you likely won't have to worry about them for several years...
  7. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,475
    2,442
    Taylors, SC
    Those states requiring functional TPMS systems in their inspection routinely check to just see if the light on the dash is lit.
    All the car owner needs to do is to turn off the light.
  8. priumium
    priumium Member
    312
    76
    Sweden
    2013 Prius Plug-in
    No European State will require this feature.
    It was forced upon Toyota, based on the above mentioned ”law”… and they implemented this globally to avoid lawsuits..
    It’s just so banal and SAD the G3 had the lamest possible implementation = No auto learn ID. Alpha version.
    #29 priumium, Jan 8, 2026 at 11:22 AM
  9. VelvetFoot
    850
    302
    New York State
    2026 Prius
    See "Ford Exploder"
    priumium likes this.
  10. priumium
    priumium Member
    312
    76
    Sweden
    2013 Prius Plug-in
    The term "Ford Exploder" is a derogatory nickname for the Ford Explorer, stemming from high-profile rollovers and tire failures in early models (especially the 1990s), leading to safety concerns and lawsuits.
    VelvetFoot likes this.
  11. fuzzy1
    10,516
    ... and Google says "... the Ford Explorer-Firestone tire controversy was a direct and significant catalyst for the federal requirement for Tire Pressure Monitoring Systems (TPMS). "
    There were numerous responsible parties in this scandal: Ford, Firestone, Ford, vehicle owner/drivers, hot climates, Ford, ...
  12. rjparker
    10,228
    6,386
    The tires in question were from Firestone whose radial tire problems started two decades earlier in the form of their first attempt to copy Michelin's radial tires, the Firestone 500.
    People died in the seventies as well. TPMS systems were not a snap decision.
    Seanathon likes this.
  13. Seanathon
    Seanathon Junior Member
    27
    Orange, CA
    Thank you for an actual source. I learned something today.
    Goes to show, many features in cars are not from the generosity of the manufacturers, it's required by law.
    For example, when I was looking at EVs, a couple of dealers bragged about the generous 8 year, 100k warranty. I noticed it was a pattern for almost all makes, save for a few like Hyundai/Kia which was 10 years. Turns out, the 8 year/100k is required by law.
    Same story with vehicle stability control (VSC), backup cameras, etc.
    Mendel Leisk and priumium like this.
  14. Mendel Leisk
    41,629
    Yeah, many of the features and benefits, they're either forced to do, or it's actually a cost-cutting measure. Loading basic functions into a $&%*! touchscreen is an example of the latter.
