Compass screen is sometimes blank
Discussion in 'Gen 5 Prius Technical Discussion' started by theRob, Jul 15, 2023.
  1. theRob
    theRob Active Member
    103
    119
    2023 Prius
    Is anyone else having this issue? Compass screen doesn’t seem to be reliable. Anyone know what would be the cause of this? I tried to look in the manual and the only mention of the compass is on page 95 and does not really say anything else about it.
  2. aforkosh
    aforkosh Active Member
    413
    272
    Oakland, CA
    2023 Prius
    Last month, it did go out on me and then come back. I was traveling in rural and mountainous areas with spotty cell phone reception. Except for short intervals, I was not in deep canyons where GPS might be iffy. It would be nice to see the prerequisites for the compass to work.
    theRob likes this.
  3. theRob
    103
    119
    2023 Prius
    After more than almost 3 years with this car, I can safely say the compass is completely useless. It is blank for me at least 80-90 percent of the time.
  4. mingc
    mingc Member
    Portland, OR
    2023 Prius
    XLE AWD-e
    According to the manual, the compass is linked to the Navigation system. I don't have a subscription to Toyota's Navigation system but I've seen the compass appear when I have Android Auto connected. I assume it also appears when Apple CarPlay is connected. I don't think it'll appear if none of those services are connected.
  5. VelvetFoot
    VelvetFoot Active Member
    851
    302
    New York State
    2026 Prius
    I don’t have Toyota nav either. CarPlay. Will try driving around with phone location off and see what happens.
  6. VelvetFoot
    851
    302
    New York State
    2026 Prius
    Turned off phone. Took 20 minute drive. Compass worked perfectly. I suspect telematics, ie, DCM. May try disconnecting dcm fuse.
    edit: Or perhaps it just uses the gps in the head unit. Who knows?
    #6 VelvetFoot, Jan 4, 2026
    mingc likes this.
  7. theRob
    103
    119
    2023 Prius
    I don’t have Toyota navigation system subscription either but I’m always connected to CarPlay. The compass just only work sometimes.
    mingc likes this.
  8. mingc
    mingc Member
    Portland, OR
    2023 Prius
    XLE AWD-e
    Same. I did not connect the phone on my drive this morning and the compass worked perfectly fine (without Toyota Nav as well). So, the compass doesn't need Toyota Nav, Android Auto or Apple CarPlay to work. I guess you have a problem, @theRob.
    #8 mingc, Jan 5, 2026 at 5:49 PM
  9. theRob
    103
    119
    2023 Prius
    I finally figured it out. I use Waze all the time in CarPlay and I noticed today if I start navigating on Waze the compass goes blank on the MID. Then once hit stop in Waze the compass come back on the MID instantly. I honestly never put the 2 and 2 together. I thought the compass on the MID was its own thing separate from the infotainment system. Kinda wish it was. Also would be nice that instead of the compass going blank on the MID, it would show some indication on the screen that it is being used by infotainment system.
    So I guess every time “it was not working” was simply because I was navigating on Waze.
    VelvetFoot and mingc like this.
  10. KMO
    KMO Senior Member
    1,974
    699
    Finland
    2023 Prius Prime
    I misunderstood this thread being about the real compass screen on the multimedia display in the in-car navigation system (a view alternative to using the map), so I didn't look at it earlier.
    The "compass screen" on the MID isn't a compass screen - it's a navigation-linked display. So it is separate from the "infotainment" system - it is driven by whatever is providing navigation, as a secondary display.
    When you see a compass on it, it's because the in-car navigation is selected, and it chooses to show that when it doesn't have any turn or other information to show - so all the time when not navigating, I think.
    If you want to use this "Waze", I would hope the car lets it ask for a compass on the display like the in-car system does, or would let it draw one itself. Have you checked to see if Waze has any options for what to show on secondary displays?
    Actually, is Waze managing to use the MID display at all for route info, or is it always blank?
  11. VelvetFoot
    851
    302
    New York State
    2026 Prius
    I waived any kind of Toyota Connect when I bought the car, so no subscribed navigation system.
    As I said earlier, the compass on the MID works even with the phone turned off.
    Unlike the original poster, I barely ever look at the compass, lol.
    What I do notice is that when I am using Apple Maps through CarPlay, I will get a pop-up on the MID showing when my next turn is. I like that-I can turn off the multimedia display, which I do a lot.
    To get rid of the direction pop-up, you have to push the return (?) button on the steering wheel.
    Perhaps if I had the compass displayed on the MID, instead of what's playing on the radio, or economy stats, or whatever, I'd see the same behavior as well, as far as the compass goes.
    Maybe there is a way to suppress the direction pop-up on the MID, but as I said, I like it.
    With the phone off, the compass is probably getting gps info from the head unit. Of course, it makes you wonder what else gets that info, lol.
    EDIT: On a side note, I just discovered Voice Control. That, along with SIRI, is a subject more suitable for the Pancakes section. :)
  12. KMO
    KMO Senior Member
    1,974
    699
    Finland
    2023 Prius Prime
    The subscription is to provide map data over the network.
    The car always has the actual navigation system - the variation is whether it has 32GB or so for built-in map storage (like in Europe, and optionally in Japan) so doesn't need subscription, or relies on on-line maps (USA, and in base Japanese versions).
    The navigation system doesn't need any map data to obtain position and direction, so can do so regardless of subscription.
    Clearly it's generous enough to show you the compass on the sub display - will it show you the longitude/latitude + compass display on the multimedia screen? Or are you blocked out from the navigation UI with a subscription message so you can't get there?
    Going back to Waze - a bit of research suggested that as of last year it did start supporting secondary (instrument panel) displays with CarPlay, but I couldn't find any indication of Toyota compatibility, or how much you could choose what it would show on them.
  13. VelvetFoot
    851
    302
    New York State
    2026 Prius
    This
    I would prefer a standalone system like all the Garmin's I've had.
  14. Gokhan
    Gokhan Senior Member
    6,296
    2,520
    Paramount CA
    The GPS cannot determine which direction the vehicle’s nose points. There should be a magnetometer in the multimedia head unit to determine the nose direction using Earth’s magnetic field. All smartphones have that.
    That said, my Gen 4 Prius Prime’s compass works very well. In my 1985 Corolla LE, I used to stick a compass ball floating in a liquid-filled bulb on the windshield.
  15. VelvetFoot
    851
    302
    New York State
    2026 Prius
    When the GPS unit is moving, yes it can. I'm pretty sure my car (not handheld) Garmins did not have magnetometers, but it did compass. Not to say the Gen 5 head unit doesn't have a magnetometer like phones.
  16. Gokhan
    6,296
    2,520
    Paramount CA
    Yes, you can see the movement direction but not the nose direction. You could be moving backward for example or sliding sideways on the ice.
  17. KMO
    KMO Senior Member
    1,974
    699
    Finland
    2023 Prius Prime
    The car doesn't have a magnetometer, but it does have a gyro, which is effective enough at tracking direction through manoeuvres, combined with the GPS movement information.
  18. VelvetFoot
    851
    302
    New York State
    2026 Prius
    Again, I'm not a compass guy, but this again requires movement of the car.
    When I go to the car, sans cell phone, the compass shows the correct orientation. Did it just display the last reading? Possibly. You'd have to put the car on dollies and move it on its axis to test, I guess. :)
    The DCM (Telematics) has a full fledged cell chip, so that would have it too. I guess its fuse could be removed temporarily, which may or may not disable it. I just can't get myself to tear things apart to unplug and bypass it - maybe in the summer when it has more miles. Maybe not. :)
    I think it's part of the head unit.
    On a side note, I think you can still buy the rear view mirrors with a compass built in.
