Cannot get prius into neutral. All gears flashing
Discussion in 'Gen 2 Prius Technical Discussion' started by andy song, Dec 24, 2025.
  1. andy song
    andy song Junior Member
    Hi all
    Bought a 2008 prius with 263k
    Previous owner said it drove fine 4 years ago but has been sitting
    We put a new hybrid battery pack we had from another in
    We put a new 12v in
    The car just flashes the gear selectors
    Won't go into neutral
    The relays of the hybrid battery do not click
    I checked all the micro fuses in the engine fuse box and they are all good (including the AM2 fuse)
    Anyone have the same thing?
    52,361
  3. mr_guy_mann
    mr_guy_mann Senior Member
    4,087
    1,997
    NJ-USA
    x2 to bisco.
    Could be lots of things. Getting codes from all ecu's with a capable scantool would help narrow down the possibilities.
    That said, wouldn't be surprised if there was a corroded blue wire at a connector at the "rear" of the underhood fuse box. Located under the black plastic cover. It's not an uncommon fault that takes the "TCM" (transmission park mechanism) offline.
  4. Tombukt2
    13,355
    2,405
    What is your vote meter say that the new hybrid battery pack from other has on it rt now ? Those relays have to click or you're essentially locked out for some reason . I would think the car would tell you. usually when you're locked out of ready mode well. Things ain't ready to be readied apparently . 4 or 5 books is the size of this cars service manual and lotsa reading . Of all the things that can lock you out. Electronically that is
  5. andy song
    We bought the hybrid battery brand new from the Toyota dealer. The voltage checked 218v at the battery side of the relay with the orange service plug in. The car won't go into ready so the car side of the relay shows no voltage. But we just want to get the car into Neutral so we can tow it back home. We haven't even gotten to the point where we want to get it started yet.
  6. bisco
    52,361
    would the orange safety plug affect this?
  7. Brian1954
    Brian1954 Senior Member
    2,396
    960
    South Central PA, USA
    Try putting the car into IG-ON, which is two pushes of the start button without your foot on the brake. Then try putting into neutral.
  8. pasadena_commut
    pasadena_commut Senior Member
    2,813
    840
    Southern California
    Expanding on that slightly...
    It is easy to either forget to put the safety plug back in or to not seat that plug properly. When that happens starting the car gives a whole lot of dash lights and a whole lot of nothing in terms of being able to move. When this happens the CEL should light and code P0A0D is set. I don't recall if some other follow on codes are also set.
    Also, I don't think you are supposed to flat tow a Prius in neutral. Put it on a trailer if you want to move it more than a few feet. For instance:
    Best practices for towing a Prius? | PriusChat
    #8 pasadena_commut, Dec 26, 2025
  9. andy song
    I tried that but all the gears light up and blinks and won't go into neutral
  10. andy song
    No it shouldn't because I can scan the hybrid battery using Dr Prius and can see the pack voltage
    If the orange plug was unplugged the pack would be cut in half and would not show the voltage on the scanner
  11. pasadena_commut
    2,813
    840
    Southern California
    If this is your immediate problem I don't see what the issue is.
    You are not supposed to flat tow a Prius in neutral, like with a cable behind another vehicle.
    Even if the car won't go into neutral a flat bed tow truck can load it, either by dragging it up wheels locked with a winch, or better, using wheel dollies. Same thing if you brought your own trailer. If they couldn't do this they would be useless for moving many collision damaged vehicles.
    Once you have the vehicle transported back home, presumably where you have a work space and more tools, then you can figure out the electrical problem.
  12. pasadena_commut
    2,813
    840
    Southern California
    Did the OP do anything about the 4 year old fuel? I would think that a Prius full of garbage gas would probably go into Ready but when the motor failed to start pretty much immediately throw one or more codes and possibly drop right back out of that state. The battery relays should click though, and one would certainly hear the transaxle spinning the ICE and the sounds of the ICE motor choking on the swill it was drinking.
    Other things that I would do before trying to turn this car on are check the oil level and the air filter. The oil is probably still there but a car that has sat for four years is likely to have a rodent hotel in the air filter box. Probably best not to suck rodent poop etc. into the motor.
  13. andy song
    The car does not go into Ready. The car doesn't even get to the point where the engine starts so the gas has nothing to do with it
    We do not even get to that point
    The car comes on like normal. But after 8-10 seconds all the gear selectors start flashing. The car never goes into Ready.
    So far we have tried switching thr following items from a running prius
    Shifter
    Parking button
    The entire block where the AM2 fuse goes
    The entire block next to that
    We checked all the fuses in the main fuse box and they all are good
  14. Tombukt2
    13,355
    2,405
    Relays probably aren't clicking the three click ion click out click on is what I hear like 20 yrs now. the min 8 get in one these its first thing my heads looking for those relay clicks ? Lock out!
  15. ChapmanF
    18,513
    The orange plug has the two contacts you're thinking of, and the other two contacts you're not thinking of.
    The two you're not thinking of are the small, low-voltage, safety interlock contacts for confirming to the car that the plug is properly installed. Those two do not mate until the handle on the orange plug is slid all the way home as the last step of putting the plug in.
    If the plug is in place but those contacts aren't mated, you will show battery voltage just fine, but the car will have a P0A0D code and won't go READY.
    People miss that so often it's a very frequent topic here.
  16. andy song
    The orange plug is pushed in
    There is no P0A0D code
    The contacts for the power out of the HV battery do not click
    I can see the pack voltage on Dr Prius so the pack is connected correctly as I can see 218v on the total voltage
    It seems like the transmission has an error as the gears are flashing after 8 seconds. It looks normal until it starts to flash
  17. Tombukt2
    13,355
    2,405
    If I'm not mistaken the flashing means you are locked out for safety's sake . Usually things like battery isolation will cause like same issues . The clue is that your relays aren't clicking in the back at all you say that's interesting usually I've noticed not the case they click differently and close or stay closed or locked out . Normally it's like click open CLick closed and click back open and hold . Ready to ready. Then does ready and it's displayed. You missing the last click holding and the ready it seems like
  18. mr_guy_mann
    4,087
    1,997
    NJ-USA
    Which is why you should get a capable scantool to see which systems have what codes. The Autel AP200 probably costs less than the parts you've put on already.
    Guessing can work... unless it doesn't.
    It could be some kind of TCM fault (or comm error).
    Brian1954 likes this.
  19. trsandy2000
    trsandy2000 Junior Member
    29
    Pull the battery voltage ECU and check the connector pins for any burnt spots.
    Just a thought. I'm not a pro mechanic like these great guys on here but I have had that problem.
