Powering Hybrid Battery Fan Externally
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by indel, Jan 12, 2026.
  1. indel
    indel Member
    283
    89
    Northwest Indiana
    I will soon be reconditioning my Prius battery and will take it out of the car to do so. That means, I will need to power the battery fan externally with a 12V power supply. Luckily, I have a spare Prius 12V battery laying around and it's putting out 12.5V consistently.
    1. Is it okay to use this battery to power the fan?
    2. What are the specs on the fan power connector? I would like to put together a harness that goes from the battery to the fan connector. Do they make any specific connectors on the battery end for applications like this?
    I found a video which suggests a frequency meter is needed to select fan speed on later generation Prii. I assume Gen 3 does not have such a function and the fan runs at a constant speed. Correct?
  2. Tombukt2
    13,802
    2,504
    Most people just put a big shot v
    Fan over the rack. I thought. At least that's what I see at my buddies set up wer he does this like production . 18 inch fan above table the racks are on wen charging in singles or complete racks of modules . And it's conditioned space the shop is .
  3. PriusCamper
    PriusCamper Senior Member
    13,402
    5,412
    Pacific Northwest, USA
    Or you could find a Gen2 Prius cooling fan at the junk yard... It will run straight off a 12v power supply. @ChapmanF pointed out the Gen3 wiring for the cooling fan on here once, but I don't remember what he said?
  4. indel
    indel Member
    283
    89
    Northwest Indiana
    Yes I saw a couple of videos with that setup. But I feel like the factory cooling mechanism is much better at this.
  5. indel
    indel Member
    283
    89
    Northwest Indiana
    Perhaps I am not understanding what you are saying, but what would be the advantage?
  6. PriusCamper
    13,402
    5,412
    @ChapmanF can explain better, but a gen2 fan is just two wires and gen3 fan is three wires so it's more complicated than a simple + and - connection to get the fan to run.
  7. indel
    indel Member
    283
    89
    Northwest Indiana
    Gotcha. Sorry I just realized that you said Gen 2. Even if I went that route, I would then have to swap in the new fan in place and swap it out when I am done reconditioning.
    Does 3 pins mean the option to control the speed?
  8. rjparker
    10,992
    6,890
    Gen3 has a variable speed battery cooling blower with pulse width modulation control.
    #8 rjparker, Jan 12, 2026
  9. Tombukt2
    13,802
    2,504
    You're going to have to have the fan attached and all the duct work for cooling . All has to be removed to reaccess. The table fan notta. And uhhh big cfms more air from 18 incher with nothing fitted . And it's winter in many garages !
  10. Albert Barbuto
    Albert Barbuto Active Member
    114
    106
    Northeast USA
    To prevent the slow degradation of module capacity, I do a once a year deep discharge of the entire pack, in the car. The cardboard box, along with a small fan, keeps the pack completely cold.
    indel likes this.
  11. ChapmanF
    18,952
    rj showed the wiring for the gen 3 fan. That SI0 terminal is for speed control, via a pulse train, with the property that the more time the pulse train stays low, the faster the fan. So just tying SI0 to ground, as the "Bench Test while Disconnected from Harness" drawing shows, is enough to run the fan at high speed.
    indel likes this.
