Coolant leaking at heater pipe, at engine block
Discussion in 'Prius v Technical Discussion' started by poway, Jan 10, 2026 at 7:12 PM.
  1. poway
    poway Junior Member
    Pensacola FL
    Coolant leaking out of this circle of this heating pipe. Leak is at the engine block. EGR assembly removed. At the local Toyota Parts counter they say pipe is not sold separately. Must purchase engine block, although they sell internal washer. Is this pipe removable? If so how? And I would you handle the reinstall of the pipe with a new washer. Thanks!
  2. Mendel Leisk
    41,639
    It’s leaking here?
    what’s the miles?
  3. ChapmanF
    18,310
    I could have sworn those hose nipples are in the cylinder head, not the block.
    I still think I'm right about that ... but I've looked in the 2010 repair manual (the PDF floating around, which might not be complete) and not found anything about removing or installing those nipples. (I think in other generations I did see some instructions like that in the manual ... I think the nipples got pressed in.)
    There are instructions for installing the spark plug tubes, but not for those nipples, that I can find. That would lend support to the idea that Toyota sells the cylinder head with those nipples already in place, and doesn't sell them separately.
    But maybe someone will chime in who has had a head sent out for machining.
  4. Mendel Leisk
    41,639
  5. poway
    poway Junior Member
    Pensacola FL
  6. poway
    poway Junior Member
    Pensacola FL
    Thank you both. Any thoughts on how to proceed?
  7. ChapmanF
    18,310
    Could involve buying a cylinder head. Bit pricey.
    Maybe could involve buying a cheap trashed cylinder head with a good hose nipple and trying to transplant that. But if Toyota isn't selling the nipples separately, that might be a hint that getting them removed from the head or installed in it could be something easier in the factory than in the field.
    poway likes this.
  8. bisco
    52,090
    salvage cylinder head?
    poway likes this.
  9. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,476
    2,443
    Taylors, SC
    As a machinist, it would not me hard to make a nipple which might even be better than OEM.
    Air_Boss likes this.
  10. Mendel Leisk
    41,639
    I think you'd want to be REAL sure, it's not just seeping from the hose. It's the braided one, right?
    I don't think you've mentioned the miles?
  11. Air_Boss
    Air_Boss Senior Member
    4,207
    1,186
    New Yawk
    Cut the tube flush with head, internally thread the tube, install threaded replacement.
    The threaded replacement will slightly expand the tube and seal the leak.
  12. poway
    poway Junior Member
    Pensacola FL
    Great idea! Where do I buy a threaded replacement? Home. depot etc?
  13. poway
    poway Junior Member
    Pensacola FL
    It's a replacement engine supposedly with 80,000 miles. Car has 230K on it.
  14. Air_Boss
    4,207
    1,186
    New Yawk
    With the proviso that I didn't design the head or cooling system, this is an arms length/shade tree/bush fix/field repair, YMMV, etc...
    Primary risk in this approach: the head is so thin at the point the tube is press-fit into the head that the existing and replacement tube threaded lengths are marginal, an insufficient number of mating threads, and won't provide much lateral load bearing strength. Won't know until measuring the existing configuration.
    If the above looks riskable/doable, I would thread a piece of slightly (1/8" or 3mm OD) oversized aluminum pipe.
    With a micrometer, measure the internal diameter ** and depth ** of the existing tube where it enters the head.
    Choose a replacement aluminum pipe whose external diameter is slightly (1/8" or 3mm) larger than the above internal measurement, and whose length is as the existing tube external length ** plus the depth of the existing tube into the head **.
    Internally fine tap the existing tube just short of the depth of the internal depth.
    (Take care to try to capture debris from the threading process. It is working in coolant, not oil, so not an existential concern.
    May also want to try to slightly recess the tube where it enters the head with a 45 or 60 degree chamfer to allow for tighter sealing at the head face.)
    Externally fine thread the new pipe to match the above internal thread and say 1/8" shorter depth so as to leave a shoulder that seals to the head
    Reassemble with Teflon pipe tape.
    Pieces of pipe are available at a good hardware store, plumbing supply store, maybe HD or Lowes.
    Leak test results.
    Don't quote me...
  15. poway
    poway Junior Member
    Pensacola FL
    yes, unfortunately it's at the block.
  16. poway
    poway Junior Member
    Pensacola FL
    Thank you! Have you ever done this? It looks good on paper.
  17. ChapmanF
    18,310
