2023+ Prius LE (Gen5) - Rear passenger seat 3D printed cup holders
Discussion in 'Gen 5 Prius Accessories and Modifications' started by Edge 3D Solutions, Jan 13, 2026 at 2:19 PM.
  1. Edge 3D Solutions
    Edge 3D Solutions New Member
    Tuesday
    Virginia
    2024 Prius
    I wanted to share a small project I’ve been working on for the Gen 5 Prius LE that focuses on improving rear seat usability without permanent modification.
    This design replaces the factory rear center console USB charger cover using the same OEM-style clip-in mounting, so it can be installed or removed without altering the vehicle. The goal was to add usable rear seat cup holders while keeping a factory-like appearance and full access to the USB charging port.
    After a few design iterations and fitment testing, the final version has been installed and tested in a 2024 Gen 5 Prius LE. The cup holders are modular and swappable to accommodate different drink sizes, and the clip tolerances were refined to improve fit and durability.
    Installation was straightforward overall, though one of my early trim removal pry tools didn’t hold up as expected, which led to a small redesign on that part. I’m continuing to refine that part based on real-world use.
    I’m sharing this here mainly to document the design approach and see if others ran into similar rear seat cup holder limitations on the Gen 5. Happy to answer questions about fitment, materials, or the design process.
    PrimeDan and tat2boy like this.
  2. Blackat
    Blackat Active Member
    467
    326
    Colorado
    2023 Prius
    Limited AWD-e
    Noice!
    I've made my G5 a 2 seater mostly so I wouldn't utilize it.
    HamiltonPrius likes this.
  3. VelvetFoot
    VelvetFoot Active Member
    876
    314
    New York State
    2026 Prius
    Alas, but are the rear seats usable? :)
  4. HamiltonPrius
    HamiltonPrius Member
    192
    93
    Parts unknown in Virginia
    2026 Prius
    With all due respect I don’t see a need/market for such a niche product but maybe I’m wrong.
    #4 HamiltonPrius, Jan 17, 2026 at 10:59 AM
  5. RobotBastard
    RobotBastard Junior Member
    Connecticut
    2024 Prius
    Hey, that's a neat idea. Good job!
