Which 12V OEM battery is better for Prius 2nd Gen?
Discussion in 'Gen 2 Prius Main Forum' started by sach0325, Dec 30, 2020.
  1. Kermit80526
    Kermit80526 Junior Member
    How are you venting this battery?
  2. PriusCamper
    PriusCamper Senior Member
    13,018
    5,290
    Pacific Northwest, USA
    VRLA means there's a vent port on the battery if it has to vent so you can connect to that... But truth is VW and many other auto makers have had batteries inside the cabin of their vehicles for 80 years without a vent. There's only one time on New Jersey turnpike when cause of death couldn't exclude the battery, but it could not prove it either.
  3. Jtaylor1111
    Jtaylor1111 New Member
    Vermont
    2003 Prius
    I have a 2003 Prius and have been using the Optima Yellow Top 51R batteries (after installing the kit several years ago to adapt to this battery) but have found that they are not good batteries and die right after their warranty runs out (just after 3 yrs) and also need constant charging in the winter (in Vermont) when it is cold or if we haven't driven in over a week. They are also very expensive (over $300). I would like to get the one that you recommend (12 Volt (12V) 55 Amp (55Ah) VRLA AGM Sealed Lead Acid Battery 55 AMPS HIGH CAP), and just add longer bolts and washers, but do you (PriusCamper) or anyone else know I will have any unforeseen issues with it? Thank you!!
  4. dolj
    dolj Senior Member
    8,550
    4,343
    Wellington, New Zealand
    Nobody could say for sure, but if you are confident the size of this battery will fit in the battery compartment without any issues, then a 55Ah AGM battery should in theory be superior to a 35/36 Ah standard flooded lead/Acid battery.
  5. GreenApp
    GreenApp Junior Member
    43
    Not to hijack this thread, but has anyone put a LiFePO4 battery in their car as 12v replacement? They're getting cheap! 50ah like $120. My only fear is maximum amp draw tripping the bms (usually 1c/50amp). Anyone have any idea what maximum amp draw/charge to the 12v system?
  6. pasadena_commut
    pasadena_commut Senior Member
    2,806
    838
    Southern California
    Toyota Prius Gen2 Inverter - openinverter.org wiki
    says up to 100A at 12V from the inverter.
    I would worry though that the LFP "12V" is not close enough in voltage characteristics to the expected AGM voltages to work properly. For instance, and just making these numbers up, if the LFP is nominally 13.5V fully charged and 13.2V fully discharged then the car will see 13.2V and think it is a fully charged AGM, when it is instead a completely discharged LFP.
    If you want a cheaper 12V AGM than the OEM one look at the Walmart battery.
  7. GreenApp
    43
    I've only seen bms cutoff at around 11.6v for LifePO4, but LiFePO4 is 13.5 resting fully charged. I could see a scenario where one could deep-discharge the battery often, and have it not recharge quickly enough by the DC-DC converter. Or worse, have the BMS cut voltage and you're dead in the water. Much to think about!
    I think there are other members who have replaced their AGM with LiFePO4 as well perhaps they can chime in.
    I may experiment with a 50ah LiFePO4 to test, my only worry is charge/discharge rate. I know the DC-DC converter can go 60-70 amps on a low-voltage AGM for a few minutes from another member at Prius 12 volt charging current | PriusChat
    #27 GreenApp, Apr 3, 2024
  8. highmilesgarage
    highmilesgarage Active Member
    491
    182
    Kansas City
    I have the Duracell AGM battery which you can buy in Batteries Plus stores. I recovered the battery when I bought my Prius used (totally dead) took me 2 days to fully charged it. It's like 2+ years old now without any issues.
  9. qmanqman
    qmanqman Active Member
    439
    152
    CO
    Hit the local UPullandPay. They sell batteries cheap.
  10. pasadena_commut
    2,806
    838
    Southern California
    I have looked at the local LKQ on several occasions and there has never been a Prius 12V on the shelf. Not saying one cannot be found eventually, but at least in my area it is not a reliable way of obtaining a Prius 12V.
  11. oschn
    oschn Junior Member
    25
    The original Toyota battery is also VRLA, yet it has a vent hole and ahose sticking to the outside world! So are you saying this battery doesn't have any vent holes?
    Also: in Central Europe winters can be cold and summers can get hot. 0-110 °F. Is it suited for those conditions, or what were your experiences so far? I am inclined to give it a try.
  12. PriusCamper
    13,018
    5,290
    Not sure which battery you're referring to, but ones without an apparent vent hole usually have an area of plastic that is thinner and will fail in that location and vent there during a highly unlikely catastrophic failure. The venting system is solely for battery failure, not for regular use.
    The ones I buy have a place where you could put a vent tube with slight modification, but it's not necessary.
  13. oschn
    oschn Junior Member
    25
    The one 55 Ah battery that you promoted earlier in this thread.
    Yeah, I'd just feel more comfortable having one as I'll only open the battery compartment every couple of years. So do you think it is easy to do for your 55 Ah model?
