2004 aftermarket HID Ballast intermittent with noise
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by El_jai, Jan 14, 2026.
  1. El_jai
    El_jai Junior Member
    San Antonio
    5 months ago I had escalating intermittent HID bults going out (flip off and on would work) until one stopped working entirely even with new bulbs, swapped Ballast side to side and defect followed Ballast. I replaced with 3rd party ballast and kept new bulbs in and worked until last week. Looks like the other Ballast went out and bulb burned up. I swapped back in my "old" bulbs back while I wait for new ones, and old ballast is intermittent, and will only stay on a few seconds.
    All that is normal for HID and Ballasts failing, the one weird thing is sometimes when I turn off lights and turn them back on even the bult with new ballast won't turn on and it makes a noise like a slight buzzer. If I turn them off and then turn the car off and turn car back on light will turn back on. but has anyone ever heard a light buzz or something?
  2. Tombukt2
    13,198
    2,386
    Common for hid old lights in parking lots on poles used to go same before LED. D4 to LED conversions in you're future if you want to stop playing with this issue .
  3. El_jai
    San Antonio
    Yeah I'm about done with HID bulbs and Ballasts, after 4 sets of bulbs in 2 years.
    Tombukt2 likes this.
