Whadda do about alignment?
Discussion in 'Fred's House of Pancakes' started by Stevewoods, Jan 16, 2026.
  1. Stevewoods
    Stevewoods Senior Member
    662
    1,185
    Seattle, WA
    Poked about the Web. Advice on wheel alignment ranges from checking twice a year to doing nothing unless your rig battles you to stay on the straight and narrow or there is abnormal tire wear.
    I have been a do nothing guy, but had a flat on my Subaru Crosstrek and I needed to rotate tires anyway so took it to local Les Schwab Tire dealer and they took care of flat and rotation gratis, even though I bought the tires at Costco. But, they mentioned abnormal wear on front left tire and recommended four-wheel alignment for $132.
    I looked. The tires are a year and a half old, maybe 14K, Bridgestone dueler? You could make an argument, I suppose, but really while there was some minor wear...
    I have felt no pulling or anything, but told them to go ahead. Figured the rotation, which they normally charge $38 USD for and the flat, I don't know $20? Might as well be safe and come out sort of even.
    So, what is everyone's stance on alignment?
    #1 Stevewoods, Jan 16, 2026
  2. BiomedO1
    3,950
    2,078
    SacTown, Ca
    Unless I buy a new set of tires or hit something really hard - I usually leave the alignment alone.....
  3. futurist
    futurist Member
    55
    93
    United States
    2024 Prius
    If I see abnormal tire wear, feel abnormal behaviour on-road or both, just align it. They go out, you re-align, golden.
  4. cyberpriusII
    1,157
    1,822
    Mars Hotel
    Good price actually if you take as $132 for all three services. My tire guy, whom has retired told me long ago that you can have your car aligned and within a month or several it will technically be out of adjustment again, especially if you drive the roads I drive.
    Also, a driver gets used to any slight pull or other indication of misalignment. So, you needed the alignment, I am sure. Whether it bought you any more miles with the tire(s) or prevented the misalignment from affecting any other systems on the vehicle, who's to say.
    I have 60K and never have had it checked. Maybe I should
    kris
  5. VelvetFoot
    VelvetFoot Active Member
    1,061
    393
    New York State
    2026 Prius
    Measure it yourself and come up with your own conclusion.
    They'll just screw it up, potentially.
  6. Trollbait
    12,634
    In the past, I did an alignment when getting new tires. Now I check for uneven wear when rotating by actually measuring tread depth across the tire.
    Out of spec camber may not be noticed by driving. The Outback's rear camber can be 3 degrees from the factory, with no way to adjust without aftermarket parts.
  7. ETC(SS)
    7,286
    I check my alignment every time I drive the car.
    A more thorough inspection is done when I change the oil (@ 3k)...rotate the tires (every 5k) etc.....
    I haven't paid for an alignment in the last.....40 years?
  8. Stevewoods
    662
    1,185
    Seattle, WA
    Driving in heavy, freezing fog yesterday.
    Of course I slam into a pothole that could be stocked with trout.
    At least I was going 20MPH
