Drain plug under 12 battery
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Hayward101, Jan 16, 2026 at 6:53 PM.
  1. Hayward101
    Hayward101 New Member
    Friday
    I just replaced the 12V battery in my 2009 Prius. There was several inches of water in the compartment. I drained it and am planning to seal where the hatchback meets the roof since I read that is often the culprit. I realized I accidentally left the drain plug out under the battery. I'm not the most handy and it was challenging for me to get the battery out, can I just buy a plug that can be stuck in from the underneath side or do I have to take the battery back out? What kind of plug would be best? Thanks for any help.
    52,101
    you could clean the area and try something like gorilla tape. don't leave it open though, mice like easy entries
  3. Hayward101
    Friday
    Ok thanks I'll put some over it in the meantime.
  4. Tombukt2
    13,142
    2,360
    No do not do that leave all the rubber plugs out for Christ's sake they're supposed to be removed at PDI they shouldn't be they're.. eve water should pass not stand. every where those plugs should be carefully removed . Unless you driving thru floods regularly. Even then water needs to pass.
  5. dolj
    dolj Senior Member
    8,461
    4,296
    Wellington, New Zealand
    That can't be right. Every Prius (not to mention every other Toyota model) I have seen has all those plugs installed. I do not believe that every Toyota employee who is doing PDIs has misunderstood the factory process.
    Sure, leave it out temporarily if you have a leak to avoid standing water. However, once the leak is fixed and you no longer have water accumulating, then it is okay to reinstall the bung.
    Mendel Leisk and Hayward101 like this.
  6. Tombukt2
    13,142
    2,360
    Water needs an interstate to travel thru you're vehicle . Not starting and Znd collect water shows up thru season changes etc leave em out in rear . Like you're boat wen emptying
  7. dolj
    dolj Senior Member
    8,461
    4,296
    Another unintelligible reply, but no thanks.
    I have no interstate flowing through my car and I am not my vehicle, nor am I boat, whether emptying or not.
    I am quite satisfied with it all plugs installed as delivered.
