How did Toyota f*** up the Gen 5 so badly?
Discussion in 'Gen 5 Prius Main Forum' started by T.S. Elliot, Jan 18, 2026.
  1. T.S. Elliot
    T.S. Elliot Member
    Desolation Row (MN)
    I just helped my dad buy a new AWD LE yesterday. Checked it out today and got to drive it. I would think the only redeeming quality is AWD? I feel no need to get into the specifics, but if you know, you know. What is going on? Has Toyota fallen off? It's as if every single auto manufacturer has gotten together and decided that instead of competing against one another, they can all just make the exact same dog s*** cars and the consumer will have no choice but to buy them. I have no idea what my dad sees in newer cars. He has a 2nd gen ridgeline that is the sourest lemon I've ever seen in a car, let alone a Honda. And he's totally ok with it, refuses to make Honda buy it back. "They'll fix it eventually". If they couldn't fix it the first 3 times it means they have no idea what's wrong, let a lone a fix.
    #1 T.S. Elliot, Jan 18, 2026
  2. hill
    8,933
    Neighbor purchased a 57 Chevy brand new. Warranty was 90 days. If there's a notion that cars aren't better, one has to explain how some warranties - or at least parts of cars are warrantied for 10 years or more nowadays. By the early '70s, warranties were a whopping 12 months. Having just purchased a 14 month old Chevy vega, Lessons Learned. It blew up shortly thereafter.
  3. bisco
    52,405
    seeing that you have a gen 2, you may not realize that Prius has gone downhill with each generation.
    I won't get into specifics, but my 04 and 08 were better than my 12, and I took a pass on gen 4, and a hard pass on gen 5.
    that's when I went with a Bev
    Merkey likes this.
  4. dolphinsil
    dolphinsil Junior Member
    2024 Prius Prime
    XSE
    What is a bev?
  5. Paul Gregory
    Paul Gregory Senior Member
    2,246
    595
    Alberta
    2024 Prius Prime
    XSE
    According to my research, You can get either AWD of a plug-in hybrid, but not both, due to space considerations. I'll gladly take the plug-in feature, as I don't find the AWD to be much more useful than FWD.
  6. CooCooCaChoo
    CooCooCaChoo Senior Member
    961
    542
    Cow-lee-fornia
    2023 Prius
    Your complaints about the car are completely absent. What exactly is wrong with the Gen 5 that you find troubling?
    Tande, 2023p, RRxing and 2 others like this.
  7. schja01
    schja01 Senior Member
    1,844
    1,226
    Chicagoland
    2024 Prius
    Limited AWD-e
    My first and best car I've ever owned was a used 57 Chevy. Of course I was a bit younger back then.
    I used that car to commute to my best ever job. An engineer of the miniature train at the Kiddie Park a few miles down the road. Those were the days.
    #7 schja01, Jan 19, 2026
    VelvetFoot likes this.
  8. T.S. Elliot
    T.S. Elliot Member
    Desolation Row (MN)
    The car is too low making it difficult to get in and out of. The speedometer is blocked entirely by the steering wheel. The only part that isn't blocked is the KM/h. Which in and of itself is completely stupid. Why would you show two numbers at the same time? The cruise control doesn't have a classic Toyota stalk and is super confusing. The shift knob is at your elbow instead of your hand so you have to reach in an awkward position to use it. The gen 2 has it in a totally natural position. In fact you can shift, steer, and operate cruise control with one hand at the exact same time with your hand in the same position it would rest naturally. Do I want to normally do that? No, but I can. The center console is smaller. The visibility is way worse. The cargo hatch is smaller despite having a two inch longer wheelbase. It doesn't have a rear wiper nor a spare tire. They removed the door handles from the rear doors. It doesn't have a spare tire. The smart key doesn't operate on the hatch nor the passenger side.
  9. RRxing
    RRxing Senior Member
    2,555
    1,828
    NEPA
    Seems like your dad doesn’t have the same issues with the car as you. The LE is the base model, not too many bells and whistles.
  10. ChapmanF
    18,570
    I don't think it did in the lower trims on earlier gens either ... I think all-doors smart key was either a higher-trim-level perk, or an option.
    Tideland Prius likes this.
  11. Winston Smith
    Winston Smith Active Member
    408
    284
    OH
    2024 Prius
    LE AWD-e
    It is low, but this isn't a concealed trait.
    That will depend on your height.
    I do find the characters on the stalks obscured by the wheel, as if the wheel and stalk combination are a parts bin mismatch.
    There is some variability in the instrument layout. I only have one speed display, but I'm sure I set it up that way.
    I don't know when Toyota last had a stalk control CC. Stalks for CC are great, but the wheel buttons can't confuse you if you are used to their locations.
    Unless you need blocks on the pedals and live in a tree making cookies, there isn't any sense in which the shift knob is at your elbow.
    Did the Gen2 have a CVT? How much shifting were you doing?
    I got the LE specifically for the smaller center screen.
    The visibility is awful. The A pillars are too thick. Rearward visibility is even worse.
    For the foot print, the interior space is poor. Is this a Toyota weakness? It seems even more noticeable in the Camry. A VW Golf seems larger than a Camry on the inside, but is smaller on the outside.
    Don't worry about the rear wiper; the window it would wipe isn't that useful. Omitting the spare is a well covered subject and is ridiculous.
    They're there, but are relocated. Don't hate it because it's beautiful.
    The key works by a fob button on the LE. I'm guessing Toyota springs for the touch lock/unlock on higher trims. I've never noticed on the passenger side, but have noticed this when trying to open the rear driver's side door to toss something in before getting in myself.
    Welcome to the charm of a cheap $30k car.
    Bob P., mva, Trollbait and 1 other person like this.
  12. T.S. Elliot
    T.S. Elliot Member
    Desolation Row (MN)
    The probability of needing to cancel cruise, drop 'er into B, and be on a curve at the exact same time is astronomically low, but never zero. Yeah by console I meant center glove box, I agree the screens don't matter.
    All BS aside, how's the long-term reliability on the gen 5's? Anyone got a high mileage one yet? If these could make it to half a mil w/o major repairs...
  13. Blackat
    Blackat Active Member
    480
    342
    Colorado
    2023 Prius
    Limited AWD-e
    Sounds like a you problem
  14. Gokhan
    Gokhan Senior Member
    6,558
    2,615
    Paramount CA
    Yes, my Gen 4 Prius Prime feels like an SUV inside with a very high ceiling and decent visibility, but most new cars are small inside with minimal visibility now, not just Gen 5 Prius. I was in a Hyundai Kona SUV a few weeks ago, and my head was almost touching the ceiling, and I am short.
    You can adjust the seat and steering wheel position to fully see the meter gauge. The default position will not work for all heights.
    The smart key works on other doors on higher trim levels.
    So, yes, Gen 5 is smaller inside with less visibility, but it is improved in most other ways compared to previous generations.
  15. TinyTim
    TinyTim Active Member
    388
    238
    Seattle
    My thoughts on the Gen5. It should have been 10-15% bigger than the Gen 4. It should have had AWD standard. A Prius is a hauler vehicle. That's not the primary purpose but loading up is something the Prius does well. People even sleep in a Prius. I think of a Prius as a little Toyota low rider pickup of old. But it's a car first. If the Prius would get 75-80 miles on electric (plugin). You would have the best of both worlds. Unlimited range and the ability to treat it like a true electric car around the city. The Plugin should be standard as well on a Prius.
    The Gen 5 Prius looks great and they added a bunch of horsepower. No need for all the bells and whistles. Just the basics. AWD standard would make it the ultimate snowbird.
    If Toyota wanted to make the Prius a true statement car. Remember the old Nissan Maxima? The 4 dour sports car. The Gen 6 Prius could be that wolf in sheep's clothes car. The Prius is already the most reliable Japanese car that exists. Car prices need to come back down to reality.
  16. Gokhan
    6,558
    2,615
    Paramount CA
    For those who want a larger car, there are the new Gen 6 RAV4 HEV and PHEV. They are a technological upgrade over the Gen 5 Prius HEV and PHEV with their TSS 4.0 and Arene-based displays and multimedia. They even come with an integrated dashcam. They will be available at dealers in a few weeks, but expect long waitlists until next year.
  17. hill
    8,933
    Let's see how many 1000s of customers they lose/chase away as stealerships charge 10 thou$and over MSRP - like they did when the 1st Plug in Rav4 came out. Nothing kills a wait list faster & paying 4 figures over MSRP on an already expensive right. LOL
    GcinFl and Gokhan like this.
  18. rjparker
    10,557
    6,623
    The big draw of the new Rav4 will be a better ride and lower wind noise which was a CRV advantage in the past. Plus more power and an available fwd to keep the now 100% hybrid cost competitive with the earlier conventional low end Rav4s.
    Rav4s will continue to beat CRVs in mpg.
    Since Rav4s are made in the US and Canada they will be available compared to the plugin which will still be made in Japan.
    A downside of the new Rav4 is the nearly complete mfd control of ac and heat.
    #18 rjparker, Jan 19, 2026
    Tideland Prius and hill like this.
  19. rjparker
    10,557
    6,623
    For my money the 2.5L Camry LE hybrid is a far superior car for thousands less. More room, more power, great mpg.
  20. Gokhan
    6,558
    2,615
    Paramount CA
    But no hatch like the Prius, which is a mini SUV, or any SUV. The hatch is the Prius’s main draw. Whoever invented the sedan did a great disservice to mankind. That is one reason sedans are now very unpopular.
