How did Toyota f*** up the Gen 5 so badly?
Discussion in 'Gen 5 Prius Main Forum' started by T.S. Elliot, Jan 18, 2026.
  1. bisco
    52,395
    Camry sales vs Prius sales = hmmm...
  2. Gokhan
    Gokhan Senior Member
    6,545
    2,613
    Paramount CA
    #22 Gokhan, Jan 20, 2026
  3. Trollbait
    12,688
    Prius sales started dropping with the gen3. Then Toyota released the Corolla hybrid; the hatchback and wagon also are hybrid in other markets. It was either change the Prius's role and design or cancel it. By sales, it seems to be working.
  4. Winston Smith
    Winston Smith Active Member
    407
    283
    OH
    2024 Prius
    LE AWD-e
    Car niches are fascinating. I think it is here that I read someone lament that the Gen5 had too much power.
    We can acknowledge that the Prius niche had a very strong identity partly because it was weird and expensive. You'll be able to read owners of prior generations on Porsche, Honda or Corvette fora lamenting the changes to their cherished labels.
    If you liked your Prius, but you wanted a bigger car with a better value, they made it but called it a Camry.
    If you liked your Prius, but wanted a useable hatch area, easier entry and a rear seat that could be used by adults, they made it but called it a Corolla Cross.
    If you hated the Prius and Co-Exist stickers but liked the drivetrain and efficiency, they made a Prius just for you in a plain vanilla wrapper and called it a Corolla.
    My first Toyota was a current generation Corolla hatch. Whatever committee designed that thing did a great job. There are no surprises and it was 0% weird.
    mva likes this.
  5. villageidiot2
    villageidiot2 Junior Member
    35
    2024 Prius
    This is a bit misleading. The Prius is supply constrained as it’s only produced in one factory in Japan for the entire global supply.
  6. Mendel Leisk
    41,909
    Someone here linked a video of 5th gen Prius AWD test (a little buried in a full review). It was very negative, barely accomplished anything, with the front wheels on rollers. When he disabled traction control and floored it (in power mode, not that it would make any diff) he finally got rolling.
    Up here in Canada the ONLY option for a reg 5th gen prius is AWD and 19" rims, woohoo.
  7. Blackat
    Blackat Active Member
    479
    342
    Colorado
    2023 Prius
    Limited AWD-e
    Lol. Someone who doesn't understand how the AWD system works on the actual road. I saw the video, he puts the cars on rollers. There are no rollers on an actual road and he doesn't have dedicated winter tires. There's no test on actual snowy roads to show stopping or curve handling.
    I use it all the time here in the CO mtns to stay out of the ditch.
    YMMV
    #27 Blackat, Jan 20, 2026
    Mendel Leisk and Gokhan like this.
  8. rjparker
    10,522
    6,604
    It provides better stability and better traction on slippery surfaces, not rollers. With snow and ice storms now a regular thing in South Texas, it is very useful and I am glad our newer hybrid has it full time.
  9. Gokhan
    6,545
    2,613
    Paramount CA
    Come on now, Mendel. You know better than that.
  10. Trollbait
    12,688
    The AWD isn't a full time system. There can be lag between the call for power to the rear and before it gets it. That said, it is an improvement over the previous E-four system it terms of power and speeds it works at. I'm sure it provides aid on the road as intended.
  11. Tande
    Tande Active Member
    550
    337
    Mich.
    Well.....FWIW, we have both, a Gen. 4 & a Gen. 5 .......wish I could have purchased a NEW Gen. 4 .....
    dagaph and Gokhan like this.
  12. Winston Smith
    407
    283
    OH
    2024 Prius
    LE AWD-e
    I watched that video before I bought. That's essentially a rock crawling test. It shows what would happen if you had a wheel or wheels in the air. If you are doing that in a Prius, something somewhere is terribly wrong.
    AWD doesn't magically create grip, but it does mitigate the worst traits of front wheel drive in many conditions. In ultra slippery condition where almost any power or lateral acceleration are too much, it feels like front wheel drive. I was happy not to hit the light pole last weekend in a sleet storm on my 20,000 mile worn OE tires.
    However,
    If you watch the graphic while you drive, the rear is very involved at lower speeds and less involved at higher speeds. I have a hazy memory of it not engaging at all over 62mph.
    In snow an rain it helps, but it also changes the way the front and rear balance in turns in rain or snow, and the EPA figures show the weight penalty. I haven't watched this video in months, but I think this video was good on the subject.
    #32 Winston Smith, Jan 20, 2026
  13. VelvetFoot
    VelvetFoot Active Member
    1,229
    480
    New York State
    2026 Prius
    I love my Gen 5.
    There...I fed the troll.
    mva and HamiltonPrius like this.
  14. Gokhan
    6,545
    2,613
    Paramount CA
    I really like my 2021 Prius Limited in aqua color. It was the best car for me at the time of the purchase. It had freshly received TSS 2.0. Since it is the Limited trim, it has BSM/RCTA and parking sensors, like the Gen 5. It is very roomy inside. And the color is the best color Toyota had in recent years.
    Sure, if I had the money, I could have upgraded to a Gen 5 to get TSS 3.0, which seems to be a bit better than TSS 2.0. I would lose the cabin space and visibility, though. And the Gen 5 has a more modern exterior look, even though I really like the Gen 4 Prius Prime's look. (I don’t like the looks of the Gen 4 Prius HEV.)
    Would the upgrade justify the cost? Probably not. Cars are improving exponentially these days, and Gen 6 will make Gen 5 obsolete in terms of driving automation and technology. On the other hand, Gen 5 was an incremental upgrade over Gen 4. Gen 6 will be a major upgrade. And by Gen 6, there might be better alternatives to Prius, not to mention HEVs and PHEVs are being replaced by BEVs.
  15. Mendel Leisk
    41,909
    The aforementiioned AWD test could simulate if you'd for example got the front end into black ice, slush in a parking spot, and are trying to reverse out? Sure rollers are an extreme case, but the rear wheels didn't manage much if at all. Snow tires shouldn't be needed in the conditions he tested, bare pavement, moderate temps.
    I agree he was that knowledgeable, going on about the drive modes being a factor. Still...
  16. Winston Smith
    407
    283
    OH
    2024 Prius
    LE AWD-e
    I wonder if that test with both front wheels sitting in rollers illustrates some sort of ECU programming artifact. It showed almost no power being sent to either rear wheel.
    In ice and snow, the car clearly sends more power to the rear. Someone has a video in which he does forward facing donuts in a snowy parking lot by keeping the steering wheel at full lock.
  17. notspam3
    notspam3 Member
    96
    52
    Toronto
    2024 Prius Prime
    XSE Premium
    Are you using A.I. to generate your post texts?
  18. dagaph
    dagaph Junior Member
    55
    Montreal
    2024 Prius Prime
    XSE
    Exactly. There are way too many people on here say that roller test has no application in real life when their can-do-no-wrong Gen5 Prius fails it, but Subaru which is considered to have a very capable AWD consistently aces these roller tests. So draw your own conclusion if the roller test has any application in real life.
    Tekz likes this.
  19. Tekz
    Tekz New Member
    British Columbia
    2026 Prius Plug-in
    agreed! Owners drive on roads while reviewers drive on rollers!
  20. Winston Smith
    407
    283
    OH
    2024 Prius
    LE AWD-e
    I didn't read anyone suggesting that the test has no application. Rather what the car does on the rollers may not indicate what the programming does with all four wheels on snow and ice. You can see the difference between a roller test result and a snow test result.
    The Subaru system is substantially different for several reasons, not the least of which is that the rear wheels are connected to the engine. While that system isn't like a locked four wheel drive, there is a lot of internet video showing it to be pretty competent off road.
    The Toyota system is very open and just an electric motor powering the rear wheels.
    There's a lot of distance between thinking the Toyota system can do no wrong and thinking that it doesn't really propel the car any differently than FWD.
    One of the differences between the Gen4 and Gen5 Prius is the size and power of the rear motor. On my way to the office through the snowpocalypse, giving it the beans above 55mph has the display show the rear drive engaging completely. I don't vouch for the accuracy of that display.
    #40 Winston Smith, Jan 26, 2026
    Blackat likes this.
