My 12V Battery is dying
Discussion in 'Gen 5 Prius Care, Maintenance and Troubleshooting' started by priusasa, Dec 13, 2025.
  1. BiomedO1
    4,149
    2,174
    SacTown, Ca
    According to the Napa website that's a 70Ah battery; whereas Toyota specifies 45Ah minimum. So not sure what your asking? Does it not strap-down properly?
    https://www.napaonline.com/en/p/BAT7548
  2. priusasa
    priusasa Member
    104
    53
    2023 Prius
    So my battery group size is LN3 as you can see
    But manual says "Use a battery that the case size is same as previous one (LN1)
    So, this car is Toyota Certified and I think they should have used the correct battery type at least. When I research more information about it, it should not able to fit there but its there. Interesting.
  3. Mendel Leisk
    41,909
    Are the dimensions roughly the same, the fiddly-design Toyota hold-down bracket fits (maybe with a washer or two)? It meets or exceeds electrical spec's? Then it's "correct".
  4. priusasa
    priusasa Member
    104
    53
    2023 Prius
    I am not sure how they fit it there, but other features exceeds since LN3 actually is bigger battery. So according to manual, its the only "size" is wrong.
    When I first realized that, which is today, I though that they are completely diffrent and you should not use different group type. But it was actually just a dimention thing.
  5. BiomedO1
    4,149
    2,174
    SacTown, Ca
    It does exceed OEM specifications; so the real questions is: does it strap-down and vent properly in it's OEM position? The 2023 Prius battery got moved back into the trunk; correct? If that battery is under the hood, you can forget about item #2.
    1. If it isn't properly strapped-down; it can rock around, loosen and/or break connections.
    2. It needs to vent properly, since it's technically located in the cabin. There should be a vent hose connected to the battery so it can vent hydrogen out of that compartment (by-product of charging) - explosive hazard.
    If that battery doesn't meet either of the above criteria, you've got a very good claim against the dealership for something that will actually meet both those criteria. That would make it a consumer protection and safety issue claim.
    Good Luck.......
    #65 BiomedO1, Dec 31, 2025
  6. CooCooCaChoo
    CooCooCaChoo Senior Member
    961
    542
    Cow-lee-fornia
    2023 Prius
    Yeah, OEMs are Panasonic or some other Japanese brand, not Napa. You could hassle them to replace it, but most likely they won't budge because it's working and not defective.
  7. Mendel Leisk
    41,909
    FWIW, the Toyota designed battery hold-down bracket is incredibly intolerant of any variation in battery height. Just a mm or two, and the damn thing is rocking, requiring washer(s) under the bracket, or shims under the battery. Not sure why they had to be clever, the usual hold-down bracket style has long rods with a hook at the bottom that hooks down there, and generous thread length at the top, that a washer and nut have at least an inch travel.
    #67 Mendel Leisk, Dec 31, 2025
    VelvetFoot likes this.
  8. VelvetFoot
    VelvetFoot Active Member
    1,226
    480
    New York State
    2026 Prius
    I went to this site, the first hit in a search, and observed that the only difference between L1 and L3, dimensionally is the length. L1 is 207mm and L3 is 274mm. I went out to the garage and measured. 274mm MIGHT be able to be squeezed in there. (I have my NOCO trickle charger (I did that on purpose) in there. I have no idea what the bottom tray looks like and what they may have done to it to make it fit though. Perhaps someone else knows.
    Did you take the battery out? It looks that way.
    edit: On the other hand, whatever they did, you can fit a higher capacity battery in there now. I'm on shaky ground, but it looks like it's a maintenance free battery and the NAPA site says it's a flooded wet battery, so does it still need that drain tube?
    edit2: I came up with this for the battery carrier. No idea if I'm correct. Perhaps one could just bend the right lip so it's flat. Still, would be very tight based on my measurements.
    #68 VelvetFoot, Jan 1, 2026
  9. priusasa
    priusasa Member
    104
    53
    2023 Prius
    Hello again. I found out the problem. Nevermind about the 12v battery conversation. The battery was fine. Yes I measured 11.85V (a few times), but it was not because the battery was bad. I measured it from a connected positive/negative cable from the 12v battery. Not from the battery itself. The battery is 12.45V after sitting for 12 hours. So it has more than half a lifetime. The reason I got 11.85V is because the positive and negative cable was not connected well. I mean they connected fine but it's the corrosion that builds in time. This is my guess, but I do not have any other explanation. I also cleaned the positive / negative heads, it was a little bit dirty. Now I got better result after clean. So this is your reminder that you might want to clean your pos / neg ports.
    The problem is: my INTEGRATED CAPACITOR (INTEGRATION CONTROL SUPPLY) is bad.
    How do I know? I used techstream and got these codes:
    I can not clear the code. And when I did a utility test using techstream, it said the integration control supply is abnormal. It's this piece. https://ebay.us/m/4HEF6j
  10. bisco
    52,393
    congrats on finding the issue. that sounds like a very unusual failure!
  11. VelvetFoot
    1,226
    480
    New York State
    2026 Prius
  12. priusasa
    priusasa Member
    104
    53
    2023 Prius
    I ordered Techstream cable and they also send you a CD for the software. That is not offical. But it works. I can see the error codes that regular cheap obd 2 doesnt show.
    For the other person who had the same problem, yes its almost the same. Same part is faulty. Only the way that part is faulty is different. I have B22E000 code and he has B230562. Today I gave the car to the service. Lets see what they are going to say.
  13. VelvetFoot
    1,226
    480
    New York State
    2026 Prius
    following.... :)
    edit: I hadn't noticed that. His was some kind of internal fault and yours is a general deterioration of the "sub battery"-is the sub battery another name for capacitor?
    What's function anyway-a short term backup to the aux battery maybe losing voltage or something? Have you noticed any systems affected, like the other poster's adaptive cruise?
    It'd be nice to see a system description, somewhere.
    #73 VelvetFoot, Jan 20, 2026
  14. priusasa
    priusasa Member
    104
    53
    2023 Prius
    They just called me and want to charge 1700 dollar for the sub battery. Now they will charge me for diagnostic fee also which I already knew what the problem was. Its sad that I got this car a year ago toyota certified and it gave me his problem and it's not under warranty. I have power train and hybrit battery warranty at the moment.
    I had bumper to bumper when I purchase the car, at 48k mileage. And I got this problem since 60.8k mileage. So it just passed
  15. BiomedO1
    4,149
    2,174
    SacTown, Ca
    I'd try to negotiate with management and maybe file something with Toyota corporate. You pay for the part, they eat the labor cost. I'd also point out the non-OEM battery fix; what else did they not do by the book????
    You don't know unless you ask......
    FWIW: they're suppose to have a 3 year 36K mile bumper to bumper warranty and 5 year 60K mile power train. That component would probably covered under the bumper to bumper, because it isn't part of the power train.
    Good Luck......
    #75 BiomedO1, Jan 20, 2026
  16. priusasa
    priusasa Member
    104
    53
    2023 Prius
    The advisor gave me a number to call, so I called Toyota and explained that it should be under one of two warranties I have. First of all, it says "Shift system malfunction" Shift system means the transmission, this is under powertrain warranty. right now when I am driving, if 12v battery fails, I am not able to shift the gears because of that malfunction.
    And the other thing is, Toyota Techstream app shows one of those codes that under "Hybrit Control" section. I shared the screenshot above. So I was also thinking that 100k hybrit system warranty might cover that too.
    The guy on the phone was very nice and he contacted with the Toyota Woburn service department and called me back. He said that the service will call me and explain why its not under warranty. He said they will call me in 48 hours and if not, call him back.
    So, that sub battery thing is in gray area where warranty covers it or not.
    Everybody around me are surprized that I can not even pass the inspection with an 2023 year car and I need to go back to the dealer and they have to fix. I can try to fix by myself, I need to take the whole center console apart and take that part and assembly and find the failed condansator and replace it etc. But I will try to make the dealer fix it under warranty. This is not the broken button or ac failure etc. This part is related to the transmission.
    What do you guys think? Am I overreacting?
    #76 priusasa, Jan 20, 2026
  17. BiomedO1
    4,149
    2,174
    SacTown, Ca
    You've also posted to another thread, also a 2023 Prius - I'd ask Toyota corporate if there's a TSB or batch issue with that part run. Where's there's smoke; there may be fire.....
  18. VelvetFoot
    1,226
    480
    New York State
    2026 Prius
    Crazy. 1700 bucks.
    So the "sub battery" is a capacitor for "just in case"? Maybe they saved a couple pounds a larger 12 v battery would weigh, and design It so it stays charged, lol.
    Used car? I wonder why the large battery was put in (by the previous owner)?
  19. priusasa
    priusasa Member
    104
    53
    2023 Prius
    There was no large 12V battery. It was my mistake and I just confused myself. The battery size was fine. But I purchased a new 12V amg battery and insert it. Off course it didnt fix the issue. I explained above why I thought the battery was bad.
    bisco and VelvetFoot like this.
  20. BiomedO1
    4,149
    2,174
    SacTown, Ca
    More than likely it's a kick-starter/booster for when everything powers-up at once. Kinda like the starting cap. for your home AC compressor motor. It smooths out the sag in voltage; so that the ECU's are happy and the sensors don't send false information.
